path: root/arch/microblaze/include/asm/microblaze_timer.h
2013-10-14Coding Style cleanup: remove trailing empty linesWolfgang Denk
2012-09-11microblaze: timer: Prepare for device-tree initializationMichal Simek
Fix CONFIG_SYS_HZ usage in board config. Do not use hardcoded value. Use CONFIG_SYS_HZ instead. Separate static configuration to single block. Signed-off-by: Michal Simek <monstr@monstr.eu>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
