path: root/arch/microblaze/config.mk
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-02-09microblaze: Move architecture to use generic board initMichal Simek
Compile code with -fPIC to get GOT. Do not build SPL with fPIC because it increasing SPL size for nothing. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2014-03-12kbuild: delete redundant LDSCRIPT definitionMasahiro Yamada
$(SRCTREE)/$(CPUDIR)/u-boot.lds is our default location of arch-specific linker script. Remove redundant definitions in arch/{arc,microblaze,openrisc}/config.mk. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Alexey Brodkin <Alexey.Brodkin@synopsys.com> Cc: Stefan Kristiansson <stefan.kristiansson@saunalahti.fi> Acked-by: Michal Simek <monstr@monstr.eu>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-08-02config: don't define CONFIG_ARCH_DEVICE_TREEStephen Warren
Now that nothing uses CONFIG_ARCH_DEVICE_TREE, stop defining it. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2012-09-11microblaze: Add support for device tree driven board configurationMichal Simek
This is minimum code required to be able to use device-tree for u-boot initialization. Currently only for device driver initialization. Linker script change ensures DTB to be aligned for both options CONFIG_OF_EMBED and CONFIG_OF_SEPARATE. Signed-off-by: Michal Simek <monstr@monstr.eu> Acked-by: Stephan Linz <linz@li-pro.net> CC: Simon Glass <sjg@chromium.org>
2012-07-09microblaze: Move individual board linker scripts to common script in cpu tree.Michal Simek
Unification for all microblaze boards. Signed-off-by: Michal Simek <monstr@monstr.eu>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
