path: root/arch/m68k
2012-09-26malloc: remove extern declarations of malloc_bin_reloc() in board.c filesDaniel Schwierzeck
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations in various board.c files to get rid of one checkpatch.pl warning. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
2012-09-20Flex bus definition update for Coldfire 5253.Jason Jin
originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> ---- The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with the 5235 processor. The registers in struct fbcs are different sizes from those in the 5235. Also, the defines are a little different. This is what I have so far. Comments? ---- Reformat the patch manually by Jason Jin Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-20ColdFire: Queued SPI driverRichard Retanubun
This patch adds a driver for Freescale Colfire Queued SPI bus. Coded to work with 8 bits per transfer to use with SPI flash. CPOL, CPHA, and CS_ACTIVE_HIGH can be configured. Tested with MCF5270 which have 4 chip selects. Activate by #define CONFIG_CF_QSPI in board config. Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
2012-09-20ColdFire: Clean up checkpatch warnings for MCF54451 and MCF54455Alison Wang
Signed-off-by: Alison Wang <b18965@freescale.com>
2012-09-20ColdFire: Clean up checkpatch warnings for MCF547x and MCF548xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF523xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF532x/MCF537x/MCF5301xAlison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF52x2Alison Wang
2012-09-20ColdFire: Clean up checkpatch warnings for MCF5227xAlison Wang
2012-09-20ColdFire: Add clear and set bits macros for ColdFire platformAlison Wang
2012-09-20ColdFire: Update the bitops for ColdFire platformAlison Wang
This patch uses the general ffs definition to replace the platform ffs definition. This patch also fixes the build error by adding hweightN definition for m5329evb and m5373evb. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-03m68k: Change memsz to a signed char to avoid warningSimon Glass
There doesn't seem to be any reason for using uchar here, so change it to char. This fixes a warning: pointer targets in passing argument 1 of 'sprintf' differ in signedness Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-12-05m68k: fix ambiguous bit testingMike Frysinger
Building for some m68k boards results in the warning: cpu_init.c: In function 'cpu_init_f': cpu_init.c:287: warning: suggest parentheses around operand of '!' or change '&' to '&&' or '!' to '~' Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23m68k: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23m68k: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Jason Jin <jason.jin@freescale.com>
2011-10-19ColdFire: Add $(obj) before cpu lib to correct buildstany MARCEL
Missing $(obj) prevented the build of ColdFire boards in a directory than sources Signed-off-by: Stany MARCEL <stany.marcel@novasys-ingenierie.com>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-09-04ColdFire:Clean up the CONFIG_STANDALONE_LOAD_ADDR usageJason Jin
Remove the additional linker options for CONFIG_STANDALONE_LOAD_ADDR Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Add mb for 5253 dram initializationJason Jin
The dram initialization sequence should be in order. This patch add mb for the dram intialization code to make sure the compiler do not disorder the code. Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire:Update the timer_init since it was unified.Jason Jin
2011-09-04ColdFire: Cleanup for partial linking and --gc-sectionsJason Jin
Introduce the --gc-sections for ColdFire platform and clean up the corresponding lds file. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-09-04ColdFire: Update compile flags for each CPUsJason Jin
Remove compiler version check for gcc 4.1 in config.mk. Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2011-07-28cleanup: Fix typos and misspellings in various files.Mike Williams
Recieve/Receive recieve/receive Interupt/Interrupt interupt/interrupt Addres/Address addres/address Signed-off-by: Mike Williams <mike@mikebwilliams.com>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-04-27Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2011-04-27Don't grab memory for LCD if FB address is definedMinkyu Kang
If FB address is defined specific address then don't grab memory for LCD Signed-off-by: Minkyu Kang <mk7.kang@samsung.com> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: Kim Phillips <kim.phillips@freescale.com> Cc: Andy Fleming <afleming@gmail.com> Cc: Kumar Gala <kumar.gala@freescale.com>
2011-04-25Stop passing around bootmem_base value.Grant Likely
For the calls to boot_relocate_fdt(), boot_get_cmdline(), and boot_get_kbd(), the value of bootmem_base is always obtained by calling getenv_bootm_low(). Since the value always comes from the same source, the calling signature for those functions can be simplified by making them call getenv_bootm_low() directly. Signed-off-by: Grant Likely <grant.likely@linaro.org>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-19Replace "FLASH" strings with "Flash" or "flash"Peter Tyser
There's no compelling reason to have the output on bootup or the "flinfo" command print "flash" in uppercase, so use the proper case where appropriate. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-12-22Merge branch 'next' of ../nextWolfgang Denk
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-20Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-19board_init_r: Removed unused cmdtp variableRichard Retanubun
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02 removed compiler warning for (now) unused cmd_tbl_t* cmdtp
2010-10-18boot: change some arch ifdefs to feature ifdefsJohn Rigby
The routines boot_ramdisk_high, boot_get_cmdline and boot_get_kbd are currently enabled by various combinations of CONFIG_M68K, CONFIG_POWERPC and CONFIG_SPARC. Use CONFIG_SYS_BOOT_<FEATURE> defines instead. CONFIG_SYS_BOOT_RAMDISK_HIGH CONFIG_SYS_BOOT_GET_CMDLINE CONFIG_SYS_BOOT_GET_KBD Define these as appropriate in arch/include/asm/config.h files. Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Wolfgang Denk <wd@denx.de>
