path: root/arch/m68k
2016-01-20m68k: M54418TWR: drop board/freescale/m54418twr/config.mkMasahiro Yamada
The board/freescale/m54418twr/config.mk defined TEXT_BASE, which has the same value as CONFIG_SYS_TEXT_BASE. The TEXT_BASE is referenced by two files: - arch/m68k/cpu/mcf5445x/start.S and include/ - include/configs/M54418TWR.h Replace the references with CONFIG_SYS_TEXT_BASE and delete board/freescale/m54418twr/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Angelo Dureghello <angelo at sysam.it>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-12-13m68k: add private libgccangelo@sysam.it
Add private libgcc Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-11-09Replace "extern inline" with "static inline"Måns Rullgård
A number of headers define functions as "extern inline" which is causing problems with gcc5. The reason is that starting with version 5.1, gcc defaults to the standard C99 semantics for the inline keyword. Under the traditional GNU inline semantics, an "extern inline" function would never create an external definition, the same as inline *without* extern in C99. In C99, and "extern inline" definition is simply an external definition with an inline hint. In short, the meanings of inline with and without extern are swapped between GNU and C99. The upshot is that all these definitions in header files create an external definition wherever those headers are included, resulting in multiple definition errors at link time. Changing all these functions to "static inline" fixes the problem since this works as desired in all gcc versions. Although the semantics are slightly different (a static inline definition may result in an actual function being emitted), it works as intended in practice. This patch also removes extern prototype declarations for the changed functions where they existed. Signed-off-by: Mans Rullgard <mans@mansr.com>
2015-11-05m68k: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-08-12m68k: cache: add an empty stub functions for invalidate/flush dcacheWu, Josh
Since some driver like ohci, lcd used dcache functions. But m68k don't implement the invalidate_dcache_range()/flush_dcache_range() functions. To avoid compiling errors this patch adds an weak empty stub function for all m68k cpu. Also each cpu can implement its own implementation. If not implemented then by default is using an empty function. Signed-off-by: Josh Wu <josh.wu@atmel.com> Acked-by: Angelo Dureghello <angelo@sysam.it>
2015-05-12arch: Make board selection choices optionalJoe Hershberger
By making the board selections optional, every defconfig will include the board selection when running savedefconfig so if a new board is added to the top of the list of choices the former top's defconfig will still be correct. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Stephen Warren <swarren@wwwdotorg.org> Cc: Tom Rini <trini@konsulko.com>
2015-04-23m68k: add architecture-specific u-boot.ldsangelo@sysam.it
Add architecture-specific u-boot.lds and remove all board-specific u-boot.lds. All the .text customization that was board-specific have been moved inside the related include/configs, inside a LDS_BOARD_TEXT define. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: merge per-CPU config.mk into arch/m68k/MakefileMasahiro Yamada
Collect CPU specific flags into the single place. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf547x_8x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf547x_8x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf523x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
Move the CPU type config options from include/configs/M5235EVB.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf523x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf5227x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
Move the CPU type config options from include/configs/M52277EVB.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf5227x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf5445x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf5445x/config.mk. Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf5445x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf532x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf532x/config.mk. Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf532x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf530x: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf530x/config.mk. Move the CPU type config options from include/configs/amcore.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf530x/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: mcf52x2: move CPU type to Kconfig and refactor config.mkMasahiro Yamada
This commit intends to stop grepping CPU type in arch/m68k/cpu/mcf52x2/config.mk. Move the CPU type config options from include/configs/*.h to arch/m68k/Kconfig and refactor the CPU flags select in arch/m68k/cpu/mcf52x2/config.mk. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Alison Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it>
2015-03-28m68k: remove arch/m68k/lib/board.cMasahiro Yamada
All the M68000 boards have switched to Generic Board. This file is no longer necessary. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Cc: Huan Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-28generic-board: move __HAVE_ARCH_GENERIC_BOARD to KconfigMasahiro Yamada
Move the option to Kconfig renaming it to CONFIG_HAVE_GENERIC_BOARD. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-05m68k: add generic-board supportangelo@sysam.it
Add generic-board support for the m68k architecture. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-05m68k: add mcf5307 cpu supportangelo@sysam.it
Add Freescale MCF5307 cpu support. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-05m68k: add amcore board supportangelo@sysam.it
Add Sysam Amcore m68k-based board support. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-01-13m68k: remove TASREG boardMatthias Fuchs
Signed-off-by: Matthias Fuchs <matthias.fuchs@esd.eu> Acked-by: Stefan Roese <sr@denx.de>
2014-12-08Kbuild: introduce Makefile in arch/$ARCH/Daniel Schwierzeck
Introduce a Makefile under arch/$ARCH/ and include it in the top Makefile (similar to Linux kernel). This allows further refactoringi like moving architecture-specific code out of global makefiles, deprecating config variables (CPU, CPUDIR, SOC) or deprecating arch/$ARCH/config.mk. In contrary to Linux kernel, U-Boot defines the ARCH variable by Kconfig, thus the arch Makefile can only included conditionally after the top config.mk. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Acked-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-07-30kconfig: delete redundant CONFIG_${ARCH} definitionMasahiro Yamada
CONFIG_${ARCH} is defined by Kconfig. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2014-07-30kconfig: switch to KconfigMasahiro Yamada
This commit enables Kconfig. Going forward, we use Kconfig for the board configuration. mkconfig will never be used. Nor will include/config.mk be generated. Kconfig must be adjusted for U-Boot because our situation is a little more complicated than Linux Kernel. We have to generate multiple boot images (Normal, SPL, TPL) from one source tree. Each image needs its own configuration input. Usage: Run "make <board>_defconfig" to do the board configuration. It will create the .config file and additionally spl/.config, tpl/.config if SPL, TPL is enabled, respectively. You can use "make config", "make menuconfig" etc. to create a new .config or modify the existing one. Use "make spl/config", "make spl/menuconfig" etc. for spl/.config and do likewise for tpl/.config file. The generic syntax of configuration targets for SPL, TPL is: <target_image>/<config_command> Here, <target_image> is either 'spl' or 'tpl' <config_command> is 'config', 'menuconfig', 'xconfig', etc. When the configuration is done, run "make". (Or "make <board>_defconfig all" will do the configuration and build in one time.) For futher information of how Kconfig works in U-Boot, please read the comment block of scripts/multiconfig.py. By the way, there is another item worth remarking here: coexistence of Kconfig and board herder files. Prior to Kconfig, we used C headers to define a set of configs. We expect a very long term to migrate from C headers to Kconfig. Two different infractructure must coexist in the interim. In our former configuration scheme, include/autoconf.mk was generated for use in makefiles. It is still generated under include/, spl/include/, tpl/include/ directory for the Normal, SPL, TPL image, respectively. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Simon Glass <sjg@chromium.org>
2014-07-22m68k: define __kernel_size_t as unsinged int againMasahiro Yamada
Commit ddc94378d changed the definition of __kernel_size_t from unsigned int to unsigned long. It is true that it fixed warnings on some crosstools but it increased warnings on the others. The problem is that we cannot see consistency in terms of the typedef of __kernel_size_t on M68K architecture. However, I'd like to suggest to have __kernel_size_t to be unsigned int again. Rationale: [1] Linux Kernel defines __kernel_size_t on M68K as unsigned int. Let's stick to the Linux's way. [2] We want to build boards with popular pre-built toolchains, not the one locally-built by indivisuals. I think m68-linux-gcc which can be downloaded from www.kernel.org is the candidate for our _recommended_ toolchains. With this patch, all the m68k boards can be built without any warnings. Give it a try with the following crosstools: https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.6.3/ x86_64-gcc-4.6.3-nolibc_m68k-linux.tar.xz or https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.9.0/ x86_64-gcc-4.9.0-nolibc_m68k-linux.tar.xz (The latter is newer.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Jason Jin <Jason.jin@freescale.com>
2014-07-07m68k: Fix incorrect memory access on M5235Vasili Galka
The csarX and cscrX registers in the fbcs_t struct are 16-bit for CONFIG_M5235 and 32-bit wide otherwise. The code in cpu_init.c accessed them always as 32-bit, effectively creating a wrong memory access on M5235. Fixed that by choosing out_be16/out_be32 depending on whether CONFIG_M5235 is defined or not. Cc: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-07-07m68k: Fix bug, "address of" operator was forgottenVasili Galka
in_be16() shall be passed a pointer to register and not its value. This is clearly a typo resulting in a wrong memory access, so fix it. Cc: Alison Wang <b18965@freescale.com>, Jason Jin <Jason.jin@freescale.com> Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-06-19m68k: Remove CONFIG_CMD_BEDBUG related codeVasili Galka
This flag does not compile on m68k since 2003 (8bde7f7) when a required "cmd_bedbug.h" header was removed. Eleven years passed, lets clean up a little... Signed-off-by: Vasili Galka <vvv444@gmail.com>
2014-06-19m68k:correct io macros about endianChao Fu
M68k is big endian cpu ,so use be_out and be_in in big endian. Signed-off-by: Chao Fu <b44548@freescale.com>
2014-06-19m68k: eliminate a warning in cpu_initMasahiro Yamada
2014-06-11m68k: Fix warnings with gcc 4.6Simon Glass
Most of the warnings seem to be related to using 'int' for size_t. Change this and fix up the remaining warnings and problems. For bootm, the warning was masked by others, and there is an actual bug in the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-29m68k: powerpc: Clean up do_mdm_initSimon Glass
This code seems unnecessarily complex. We really just need to check the global_data. Now that is it all in one place, and not arch-specific, this is pretty easy. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2014-03-12kbuild: rename OBJTREE to objtreeMasahiro Yamada
Prior to Kbuild, $(OBJTREE) was used for pointing to the top of build directory with absolute path. In Kbuild style, $(objtree) is used instead. This commit renames OBJTREE to objtree and delete the defition of OBJTREE. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-12kbuild: rename TOPDIR to stctreeMasahiro Yamada
Prior to Kbuild, $(TOPDIR) or $(SRCTREE) was used for pointing to the top of source directory. (No difference between the two.) In Kbuild style, $(srctree) is used instead. This commit renames TOPDIR to srctree and delete the defition of TOPDIR. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-03-04m68k: merge compile flags -ffixed-d7 -sep-dataMasahiro Yamada
All arch/m68k/cpu/*/config.mk define the same flags PLAGFORM_REFLFLAGS += -ffixed-d7 -msep-data Move it to arch/m68k/config.mk Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Jason Jin <Jason.jin@freescale.com>
2014-02-19kbuild: use Linux Kernel build scriptsMasahiro Yamada
Now we are ready to switch over to real Kbuild. This commit disables temporary scripts: scripts/{Makefile.build.tmp, Makefile.host.tmp} and enables real Kbuild scripts: scripts/{Makefile.build,Makefile.host,Makefile.lib}. This switch is triggered by the line in scripts/Kbuild.include -build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build.tmp obj +build := -f $(if $(KBUILD_SRC),$(srctree)/)scripts/Makefile.build obj We need to adjust some build scripts for U-Boot. But smaller amount of modification is preferable. Additionally, we need to fix compiler flags which are locally added or removed. In Kbuild, it is not allowed to change CFLAGS locally. Instead, ccflags-y, asflags-y, cppflags-y, CFLAGS_$(basetarget).o, CFLAGS_REMOVE_$(basetarget).o are prepared for that purpose. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Gerhard Sittig <gsi@denx.de>
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-01m68k: convert makefiles to Kbuild styleMasahiro Yamada
2013-10-14Coding Style cleanup: replace leading SPACEs by TABsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> [trini: Drop changes for PEP 4 following python tools] Signed-off-by: Tom Rini <trini@ti.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-07-23i2c, soft-i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to soft_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
