path: root/arch/m68k
2011-01-19Replace "FLASH" strings with "Flash" or "flash"Peter Tyser
There's no compelling reason to have the output on bootup or the "flinfo" command print "flash" in uppercase, so use the proper case where appropriate. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-12-22Merge branch 'next' of ../nextWolfgang Denk
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-28do_reset: unify duplicate prototypesMike Frysinger
The duplication of the do_reset prototype has gotten out of hand, and they're not all in sync. Unify them all in command.h. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-20Merge branch 'master' of git://git.denx.de/u-boot-armWolfgang Denk
2010-10-19board_init_r: Removed unused cmdtp variableRichard Retanubun
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02 removed compiler warning for (now) unused cmd_tbl_t* cmdtp
2010-10-18boot: change some arch ifdefs to feature ifdefsJohn Rigby
The routines boot_ramdisk_high, boot_get_cmdline and boot_get_kbd are currently enabled by various combinations of CONFIG_M68K, CONFIG_POWERPC and CONFIG_SPARC. Use CONFIG_SYS_BOOT_<FEATURE> defines instead. CONFIG_SYS_BOOT_RAMDISK_HIGH CONFIG_SYS_BOOT_GET_CMDLINE CONFIG_SYS_BOOT_GET_KBD Define these as appropriate in arch/include/asm/config.h files. Signed-off-by: John Rigby <john.rigby@linaro.org> Acked-by: Wolfgang Denk <wd@denx.de>
2010-10-06PCU_E: remove code for yet another corpseWolfgang Denk
The PCU_E board has long reached EOL, and support for it is no longer relevant in current versions of U-Boot. Remove it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-23Remove unused CONFIG_SERIAL_SOFTWARE_FIFO featureStefan Roese
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO feature from U-Boot. It has only been implemented for PPC4xx and was not used at all. So let's remove it and make the code smaller and cleaner. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-09-19common: move TOTAL_MALLOC_LEN to include/common.hHeiko Schocher
Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19relocation: fixup cmdtableHeiko Schocher
fixup_cmdtable() did all work for fixing up the cmdtable, if CONFIG_RELOC_FIXUP_WORKS is not defined. CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked with Graeme Russ, and he will fix this soon. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-09miiphy: constify device nameMike Frysinger
The driver name does not need to be writable, so constify it. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-05-28add CONFIG_SYS_FEC_FULL_MII for MCF5445xWolfgang Wegner
This patch adds support for full MII interface on MCF5445x (in contrast to RMII as used on the evaluation boards). Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
2010-05-28add CONFIG_SYS_FEC_NO_SHARED_PHY for MCF5445xWolfgang Wegner
This patch adds the possibility to handle seperate PHYs to MCF5445x. Naming is chosen to resemble the contrary CONFIG_FEC_SHARED_PHY in the linux kernel. Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
2010-05-28add missing PCS3 for MCF5445xWolfgang Wegner
This patch adds the code for handling PCS3 (DSPI chip select 3) in cpu_init.c and m5445x.h Signed-off-by: Wolfgang Wegner <w.wegner at astro-kom.de>
2010-04-13m68k: Move cpu/$CPU to arch/m68k/cpu/$CPUPeter Tyser
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
