Declare malloc_bin_reloc() in malloc.h and remove all extern declarations
in various board.c files to get rid of one checkpatch.pl warning.
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Cc: Andreas Bießmann <andreas.devel@gmail.com>
Cc: Jason Jin <Jason.jin@freescale.com>
Cc: Macpaul Lin <macpaul@andestech.com>
Cc: Daniel Hellstrom <daniel@gaisler.com>
Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
All arches init this the same way, so move the logic into the core
net code to avoid duplicating it everywhere else.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
There doesn't seem to be any reason for using uchar here, so change it
to char. This fixes a warning:
pointer targets in passing argument 1 of 'sprintf' differ in signedness
This changes the board code to use the new getenv_ulong() function.
This is long over due. All but two net drivers have been converted, but
those have now been dropped.
The only thing left to do is actually delete all references to NET_MULTI
and code that is compiled when that is not defined. So here we scrub the
core code.
Signed-off-by: Jason Jin <Jason.jin@freescale.com>
If FB address is defined specific address then don't grab memory for LCD
Cc: Albert Aribaud <albert.aribaud@free.fr>
Cc: Stefan Roese <sr@denx.de>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Kumar Gala <kumar.gala@freescale.com>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
There's no compelling reason to have the output on bootup or the
"flinfo" command print "flash" in uppercase, so use the proper case
where appropriate.
By now, the majority of architectures have working relocation
support, so the few remaining architectures have become exceptions.
To make this more obvious, we make working relocation now the default
case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC.
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
CONFIG_SYS_INIT_RAM_END was a misnomer as it suggests this might be
some end address; to make the meaning more clear we rename it into
CONFIG_SYS_INIT_RAM_SIZE
No other code changes are performed in this patch, only minor editing
of white space (due to the changed length) and the comments was done,
where noticed.
Note that the code for the PATI and cmi_mpc5xx board configurations
looks seriously broken. Last known maintainers on Cc:
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Martin Winistoerfer <martinwinistoerfer@gmx.ch>
Acked-by: Kumar Gala <galak@kernel.crashing.org>
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02
removed compiler warning for (now) unused cmd_tbl_t* cmdtp
The PCU_E board has long reached EOL, and support for it is no longer
relevant in current versions of U-Boot. Remove it.
This patch removes the completely unused CONFIG_SERIAL_SOFTWARE_FIFO
feature from U-Boot. It has only been implemented for PPC4xx and was not
used at all. So let's remove it and make the code smaller and cleaner.
Acked-by: Detlev Zundel <dzu@denx.de>
Portions of this work were supported by funding from
the CE Linux Forum.
fixup_cmdtable() did all work for fixing up the cmdtable,
if CONFIG_RELOC_FIXUP_WORKS is not defined.
CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked
with Graeme Russ, and he will fix this soon.
the CE Linux Forum.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
