path: root/arch/m68k/include
2020-02-20dma-mapping: add <asm/dma-mapping.h> for all architecturesMasahiro Yamada
To avoid "asm/dma-mapping.h: No such file or directory" error, we need something. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2020-01-10m68k: Drop CONFIG_MCFPIT supportTom Rini
All platforms currently use the "MCFTMR" DMA timer rather than the PIT timer, so drop the MCFPIT code. Cc: Huan Wang <alison.wang@nxp.com> Cc: Angelo Dureghello <angelo@sysam.it> Cc: TsiChung Liew <Tsi-Chung.Liew@nxp.com> Cc: Wolfgang Wegner <w.wegner@astro-kom.de> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Angelo Dureghello <angelo@sysam.it>
2020-01-10m68k: add dm fec supportAngelo Durgehello
Add architecture-related code for dm fec support. Signed-off-by: Angelo Durgehello <angelo.dureghello@timesys.com>
2019-05-24m68k: add dspi chip-select supportAngelo Dureghello
Signed-off-by: Angelo Dureghello <angelo@sysam.it> Changes for v5: - new patch
2018-09-16m68k: ColdFire mcf5441x, add eSDHC supportAngelo Dureghello
This patch adds mcf5441x eSDHC support for the mcf5441x family. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2018-09-16m68k: fix multiple memory accesses on swap operationsAngelo Dureghello
On a u32 val = __sw32(*addr); multiple memory accesses are not welcome, since "addr" may be an IO peripheral register address. This patch changes __sw16/32 to perform a single memory access for the source value. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2018-09-16m68k: fix mcf5441x total interrupt numberAngelo Dureghello
2018-09-10arch: types.h: factor out fixed width typedefs to int-ll64.hMasahiro Yamada
All architectures have the same definition for s8/16/32/64 and u8/16/32/64. Factor out the duplicated code into <asm-generic/int-ll64.h>. BTW, Linux unified the kernel space definition into int-ll64.h a few years ago as you see in Linux commit 0c79a8e29b5f ("asm/types.h: Remove include/asm-generic/int-l64.h"). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-06-18m68k: Remove empty #ifdef/#ifndef blockChris Packham
Whatever code this was guarding has been removed so remove the guards too. Signed-off-by: Chris Packham <judge.packham@gmail.com>
2018-01-30Convert CONFIG_SYS_BOOT_GET_{CMDLINE, KBD} to KconfigDerald D. Woods
This converts the following to Kconfig: CONFIG_SYS_BOOT_GET_CMDLINE CONFIG_SYS_BOOT_GET_KBD Signed-off-by: Derald D. Woods <woods.technical@gmail.com>
2017-10-02m68k: Use asm-generic/io.hPaul Burton
Convert the m68k architecture to make use of the new asm-generic/io.h to provide address mapping functions. As the generic implementations are suitable for m68k this is primarily a matter of emoving code. Feedback from architecture maintainers is welcome. Signed-off-by: Paul Burton <paul.burton@imgtec.com> Cc: Huan Wang <alison.wang@freescale.com> Cc: Angelo Dureghello <angelo@sysam.it> Acked-by: Angelo Dureghello <angelo@sysam.it> Tested-by: Angelo Dureghello <angelo@sysam.it>
2016-10-19efi: Use asmlinkage for EFIAPISimon Glass
This is required for x86 and is also correct for ARM (since it is empty). Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Bin Meng <bmeng.cn@gmail.com> Signed-off-by: Alexander Graf <agraf@suse.de>
2016-09-23Remove arch/${ARCH}/include/asm/errno.hMasahiro Yamada
Unlike Linux, nothing about errno.h is arch-specific in U-Boot. As you see, all of arch/${ARCH}/include/asm/errno.h is just a wrapper of <asm-generic/errno.h>. Actually, U-Boot does not export headers to user-space, so we just have to care about the consistency in the U-Boot tree. Now all of include directives for <asm/errno.h> are gone. Deprecate <asm/errno.h>. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
2016-08-15net: mii: Changes not made by spatchJoe Hershberger
If the functions passed to the registration function are not in the same C file (extern) then spatch will not handle the dependent changes. Make those changes manually. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> For the 4xx related files: Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Bin Meng <bmeng.cn@gmail.com>
2016-05-27m68k: Drop unused code in u-boot.hSimon Glass
Since generic board init is enabled, this is not used. Drop it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Angelo Dureghello <angelo@sysam.it>
2016-05-17Merge git://git.denx.de/u-boot-dmTom Rini
2016-05-17m68k: add malloc memory for early mallocangelo@sysam.it
To use serial uclass and DM, CONFIG_SYS_MALLOC_F must be used. So CONFIG_SYS_GENERIC_GLOBAL_DATA has been undefined and call to board_init_f_mem() is added for all cpu's. Signed-off-by: Angelo Dureghello <angelo@sysam.it> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-17dm: fsl_i2c: Rename I2C register structuremario.six@gdsys.cc
Signed-off-by: Mario Six <mario.six@gdsys.cc>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-09Replace "extern inline" with "static inline"Måns Rullgård
A number of headers define functions as "extern inline" which is causing problems with gcc5. The reason is that starting with version 5.1, gcc defaults to the standard C99 semantics for the inline keyword. Under the traditional GNU inline semantics, an "extern inline" function would never create an external definition, the same as inline *without* extern in C99. In C99, and "extern inline" definition is simply an external definition with an inline hint. In short, the meanings of inline with and without extern are swapped between GNU and C99. The upshot is that all these definitions in header files create an external definition wherever those headers are included, resulting in multiple definition errors at link time. Changing all these functions to "static inline" fixes the problem since this works as desired in all gcc versions. Although the semantics are slightly different (a static inline definition may result in an actual function being emitted), it works as intended in practice. This patch also removes extern prototype declarations for the changed functions where they existed. Signed-off-by: Mans Rullgard <mans@mansr.com>
2015-11-05m68k: Use the generic bitops headersFabio Estevam
The generic bitops headers are required when calling logarithmic functions, such as ilog2(). Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2015-03-05m68k: add generic-board supportangelo@sysam.it
Add generic-board support for the m68k architecture. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2015-03-05m68k: add mcf5307 cpu supportangelo@sysam.it
Add Freescale MCF5307 cpu support. Signed-off-by: Angelo Dureghello <angelo@sysam.it>
2014-07-22m68k: define __kernel_size_t as unsinged int againMasahiro Yamada
Commit ddc94378d changed the definition of __kernel_size_t from unsigned int to unsigned long. It is true that it fixed warnings on some crosstools but it increased warnings on the others. The problem is that we cannot see consistency in terms of the typedef of __kernel_size_t on M68K architecture. However, I'd like to suggest to have __kernel_size_t to be unsigned int again. Rationale: [1] Linux Kernel defines __kernel_size_t on M68K as unsigned int. Let's stick to the Linux's way. [2] We want to build boards with popular pre-built toolchains, not the one locally-built by indivisuals. I think m68-linux-gcc which can be downloaded from www.kernel.org is the candidate for our _recommended_ toolchains. With this patch, all the m68k boards can be built without any warnings. Give it a try with the following crosstools: https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.6.3/ x86_64-gcc-4.6.3-nolibc_m68k-linux.tar.xz or https://www.kernel.org/pub/tools/crosstool/files/bin/x86_64/4.9.0/ x86_64-gcc-4.9.0-nolibc_m68k-linux.tar.xz (The latter is newer.) Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Simon Glass <sjg@chromium.org> Cc: Jason Jin <Jason.jin@freescale.com>
2014-06-19m68k:correct io macros about endianChao Fu
M68k is big endian cpu ,so use be_out and be_in in big endian. Signed-off-by: Chao Fu <b44548@freescale.com>
2014-06-11m68k: Fix warnings with gcc 4.6Simon Glass
Most of the warnings seem to be related to using 'int' for size_t. Change this and fix up the remaining warnings and problems. For bootm, the warning was masked by others, and there is an actual bug in the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2013-11-08include: delete include/linux/config.hMasahiro Yamada
Linux Kernel abolished include/linux/config.h long time ago. (around version v2.6.18..v2.6.19) We don't need to provide Linux copatibility any more. This commit deletes include/linux/config.h and fixes source files not to include this. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-07-24Merge branch 'master' of git://git.denx.de/u-boot-i2cTom Rini
The sandburst-specific i2c drivers have been deleted, conflict was just over the SPDX conversion. Conflicts: board/sandburst/common/ppc440gx_i2c.c board/sandburst/common/ppc440gx_i2c.h Signed-off-by: Tom Rini <trini@ti.com>
2013-07-23i2c, fsl_i2c: switch to new multibus/multiadapter supportHeiko Schocher
- added to fsl_i2c driver new multibus/multiadpater support - adapted all config files, which uses this driver Signed-off-by: Heiko Schocher <hs@denx.de> Cc: Simon Glass <sjg@chromium.org> Cc: Stephen Warren <swarren@wwwdotorg.org>
2013-06-27Fix MCF5235 SDRAM base address macroSteve deRosier
SDRAMC_DARCn_BA() macro worked fine when the BA is 0x00000000 even though the macro is incorrect. It causes the BA to be set incorrctly for other base addresses. This patch fixes the macro so that base addresses other than zero can be used with the MCF5235. Signed-off-by: Steve deRosier <derosier@gmail.com>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04m68k: Use generic global_dataSimon Glass
Move m68k over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04m68k: Move CONFIG_EXTRA_CLOCK to arch_global_dataSimon Glass
Move inp_clk, vco_clk and flb_clk into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04ppc: m68k: Move i2c1_clk, i2c2_clk to arch_global_dataSimon Glass
Move these fields into arch_global_data and tidy up. This is needed for both ppc and m68k since they share the i2c driver. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-12-11Add strcasecmp() and strncasecmp()Simon Glass
strncasecmp() is present as strnicmp() but disabled. Make it available and define strcasecmp() also. There is a only a small performance penalty to having strcasecmp() call strncasecmp(), so do this instead of a standalone function, to save code space. Update the prototype in arch-specific headers as needed to avoid warnings. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-24ColdFire: Add MCF5441x CPU supportAlison Wang
Add MCF5441x CPU support. The MCF5441x devices are a family of highly-integrated 32-bit microprocessors based on the Version 4m ColdFire microarchitecture, comprising of the V4 integer core, memory management unit(MMU) and enchanced multiply-accumulate unit(EMAC). Signed-off-by: TsiChung Liew <tsicliew@gmail.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-10-19m68k: Change bi_baudrate and global data baudrate to intSimon Glass
These don't need to be longs, so change them. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-20Flex bus definition update for Coldfire 5253.Jason Jin
originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> ---- The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with the 5235 processor. The registers in struct fbcs are different sizes from those in the 5235. Also, the defines are a little different. This is what I have so far. Comments? ---- Reformat the patch manually by Jason Jin Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-20ColdFire: Queued SPI driverRichard Retanubun
This patch adds a driver for Freescale Colfire Queued SPI bus. Coded to work with 8 bits per transfer to use with SPI flash. CPOL, CPHA, and CS_ACTIVE_HIGH can be configured. Tested with MCF5270 which have 4 chip selects. Activate by #define CONFIG_CF_QSPI in board config. Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
2012-09-20ColdFire: Add clear and set bits macros for ColdFire platformAlison Wang
2012-09-20ColdFire: Update the bitops for ColdFire platformAlison Wang
This patch uses the general ffs definition to replace the platform ffs definition. This patch also fixes the build error by adding hweightN definition for m5329evb and m5373evb. Signed-off-by: Jason Jin <Jason.jin@freescale.com> Signed-off-by: Alison Wang <b18965@freescale.com>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2011-10-23m68k: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Jason Jin <jason.jin@freescale.com>
