path: root/arch/m68k/include/asm/coldfire
2012-09-20Flex bus definition update for Coldfire 5253.Jason Jin
originally work by Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> ---- The defines in arch/m68k/include/coldfire/flexbus.h are not compatible with the 5235 processor. The registers in struct fbcs are different sizes from those in the 5235. Also, the defines are a little different. This is what I have so far. Comments? ---- Reformat the patch manually by Jason Jin Signed-off-by: Jate Sujjavanich <jsujjavanich@syntech-fuelmaster.com> Signed-off-by: Jason Jin <Jason.jin@freescale.com>
2012-09-20ColdFire: Queued SPI driverRichard Retanubun
This patch adds a driver for Freescale Colfire Queued SPI bus. Coded to work with 8 bits per transfer to use with SPI flash. CPOL, CPHA, and CS_ACTIVE_HIGH can be configured. Tested with MCF5270 which have 4 chip selects. Activate by #define CONFIG_CF_QSPI in board config. Signed-off-by: Richard Retanubun <richardretanubun@ruggedcom.com>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
