path: root/arch/blackfin
2011-06-03Blackfin: use on-chip reset func with newer partsMike Frysinger
Turns out the documentation is wrong and doing "RAISE 1" does not result in a software reset, only a core reset. So when the on-chip rom has a functioning reset helper, use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03Blackfin: use common LDSCRIPT logicMike Frysinger
Now that common code is a bit smarter when it comes to default LDSCRIPT values, rename the default Blackfin file and drop the Blackfin-specific config.mk logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-13gpio: generalize for all generic gpio providersMike Frysinger
The Blackfin gpio command isn't terribly Blackfin-specific. So generalize the few pieces into two new optional helpers: name_to_gpio() - turn a string name into a GPIO # gpio_status() - display current pin bindings (think /proc/gpio) Once these pieces are pulled out, we can relocate the cmd_gpio.c into the common directory. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-04-08Blackfin: replace "bfin_reset_or_hang()" with "panic()"Kyle Moffett
The bfin_reset_or_hang function unnecessarily duplicates the panic() logic based on CONFIG_PANIC_HANG. This patch deletes 20 lines of code and just calls panic() instead. This also makes the following generic-restart conversion patch simpler. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: bootrom.h: sync with toolchainMike Frysinger
We need the updated LDR bit defines for our LDR utils. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: default to L1 bank A when L1 bank B does not existMike Frysinger
Some parts lack Bank B in L1 data, so have the linker script fall back to Bank A when that happens. This way we can still leverage L1 data. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: turn off caches when self initializingMike Frysinger
When bootstrapping ourselves on the fly at runtime (via "go"), we need to turn off the caches to avoid taking software exceptions. Since caches need CPLBs and CPLBs need exception handlers, but we're about to rewrite the code in memory where those exception handlers live, we need to turn off caches first. This new code also encourages a slight code optimization by storing the MMR bases in dedicated registers so we don't have to fully load up the pointer regs multiple times. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: only check for os log when we have external memoryMike Frysinger
If the part has no external memory configured, then there will be no os log for us to check, and any attempt to access that memory will trigger hardware errors. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: BF537: unify duplicated headersMike Frysinger
2011-04-08Blackfin: BF52x: unify duplicated headersMike Frysinger
2011-04-08Blackfin: drop duplicate system mmr and L1 scratch definesMike Frysinger
Common code already takes care of setting up these defines when a port hasn't specified them, so punt the duplicate values. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: BF50x: new processor portMike Frysinger
2011-04-08Blackfin: fix bd_t handlingMike Frysinger
The recent global data changes (making the size autogenerated) broke the board info handling on Blackfin ports as we were lying and lumping the bd_t size in with the gd_t size. So use the new dedicated bd_t size to setup its own address in memory. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: bf537: fix L1 data definesMike Frysinger
The __BFIN_DEF_ADSP_BF537_proc__ define isn't setup anymore, so use the one coming from the compiler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: serial: clean up muxing a bitMike Frysinger
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: unify bootmode based LDR_FLAGS setupMike Frysinger
Unify this convention for all Blackfin boards. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: drop CONFIG_SYS_TEXT_BASE from boardsMike Frysinger
We don't want/use this value for Blackfin boards, so punt it and have the common code error out when people try to use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: skip RAM display for 0 mem systemsMike Frysinger
2011-03-22Introduce a new linker flag LDFLAGS_FINALHaiying Wang
commit 8aba9dceebb14144e07d19593111ee3a999c37fc Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGS breaks the usage of --gc-section to build nand_spl. We still need linker option --gc-section for every uboot image, not only the main one. LDFLAGS_FINAL passes the --gc-sections to each uboot image. To get the proper linker flags, we use LDFLAGS and LDFLAGS_FINAL to replace PLATFORM_LDFLAGS in the Makefile of each nand_spl board. Signed-off-by: Scott Wood <scottwood@freescale.com> Signed-off-by: Haiying Wang <Haiying.Wang@freescale.com>
2011-01-25Divides variable of linker flags to LDFLAGS-u-boot and LDFLAGSNobuhiro Iwamatsu
Linker needs to use the proper endian/bfd flags even when doing partial linking. LDFLAGS_u-boot sets linker option which is called it when U-boot is built (u-boot final). LDFLAGS sets necessary option by partial linking (use in cmd_link_o_target). CC: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-19Blackfin: drop initcode.o from combined objectMike Frysinger
We explicitly link in the initcode.o in the Blackfin linker script, so there is no need to merge it into the main common object for the linker to pull in itself. This also fixes duplicate symbol errors with the new partial linking logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-18Blackfin: make sure bss len is multiple of 4 bytesMike Frysinger
The Blackfin on-chip BootROM requires that fill operations (which is used for the bss) be aligned to 4 bytes (base addr and total len). Plus, the Blackfin early init asm code assumes the same thing. So rather than making things work for no real gain, make sure the bss len is padded to 4 bytes in the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-18Blackfin: stick ins/outs funcs into their own .text sectionMike Frysinger
This lets the linker garbage collect these functions when they aren't actually used by placing them into the standard .text.<func> section. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Blackfin: config.mk: drop manual stripping of config varsMike Frysinger
Now that the common code takes care of stripping away quotes and such from numeric options, we no longer need to do so ourselves. So drop the custom code we have in the Blackfin config.mk. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-27Blackfin: fix building after asm-offsets.h introMike Frysinger
Since some of the defines in our config.h use the generated defines, we need to include the generated header. This fixes building of the Blackfin start.S file (where the stack is setup). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-14Blackfin: workaround anomaly 05000440Mike Frysinger
We cannot rely on the syscontrol rom func to program PLL_DIV with anomaly 05000440 is in effect, so manually program the MMR when necessary. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-14Blackfin: update anomaly lists to latest sheetsMike Frysinger
2010-10-02Blackfin: fix MMC init output alignmentMike Frysinger
2010-10-02Blackfin: propagate target cpu defines when building embedded envMike Frysinger
Since we're no longer extracting the env from the target ELF file (since upstream wouldn't take that change), we're back to the problem of cpu defines not properly propagating to the env setup stage. So the embedded env built by the host compiler doesn't match the one that is linked into the u-boot env. Reported-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: accept upper case pin namesMike Frysinger
The intention all along was to accept pin names irrelevant of their case. But I guess I forgot to test/implement support for that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: return gpio value to callerMike Frysinger
Make the GPIO command usable in a scripting environment by returning the GPIO value rather than always 0. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: document/extend input sub-optionMike Frysinger
The input sub command was missing from the help text, and it didn't show the actual value currently read on the GPIO. This allows people to read the value of input pins. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf561: merge headersMike Frysinger
Only the BF561 port was using the common dual core headers, so merge them into the BF561 specific headers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf533: merge headersMike Frysinger
Only the BF533 port was using the common extended headers, so merge them into the BF533 specific headers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: unify core MMRsMike Frysinger
2010-10-02Blackfin: bf52x: unify arch header duplicationMike Frysinger
2010-10-02Blackfin: bf537: unify arch header duplicationMike Frysinger
2010-10-02Blackfin: punt old *p style volatile MMR definesMike Frysinger
These are unused now, so punt them to clean things up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: punt headers for non-existent BF541Mike Frysinger
There is no BF541 processor variant, so punt headers for it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bfin_spi: add optional DMA supportMike Frysinger
This moves the last piece from the old spi_flash driver to the new SPI framework -- optional DMA RX support. This typically cuts speeds by ~40% at the cost of additional ~300 bytes. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: add support for BF51x partsMike Frysinger
2010-10-02Blackfin: add support for BF538/BF539 processorsMike Frysinger
