path: root/arch/blackfin
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-04blackfin: bf60x: add resume from hibernateSteven Miao
Add Bf60x resume from hibernate support Signed-off-by: Steven Miao <realmz6@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add hw watchdog supportBob Liu
Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: add bf6xx spi driverScott Jiang
Spi driver for bf60x is different from old one, so implement a new driver for it. Signed-off-by: Scott Jiang <scott.jiang.linux@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add rsi/sdh supportSonic Zhang
Add rsi/sdh support for bf60x. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add gpio supportBob Liu
2013-03-04blackfin: bf60x: support big cplb pageBob Liu
BF60x support 16K, 64K, 16M and 64M cplb pages, this patch add support for them. So that bf609-ezkit can use it's 128M memory. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add dma supportBob Liu
Add dma support for bf60x. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: add serial supportSonic Zhang
Add serial for bf60x. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: Port blackfin core architecture code to boot on bf60x.Sonic Zhang
Set up clocks, DDR controller, Nor flash controller, reboot, serial port. Add new SPI boot modes. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-03-04blackfin: bf60x: new processor header filesBob Liu
Add header files for blackfin new processor bf60x. Signed-off-by: Bob Liu <lliubbo@gmail.com> Signed-off-by: Sonic Zhang <sonic.zhang@analog.com> Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
2013-02-04blackfin: Use generic global_dataSimon Glass
Move blackfin over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19blackfin: Change global data baudrate to intSimon Glass
This doesn't need to be a long, so change it. Also adjust bi_baudrate to be unsigned. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15serial: Remove CONFIG_SERIAL_MULTI from remaining sourcesMarek Vasut
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI is now enabled by default. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Anatolij Gustschin <agust@denx.de> Cc: Stefan Roese <sr@denx.de>
2012-10-15serial: bfin: Flip the jtag serial console to CONFIG_SERIAL_MULTIMarek Vasut
Rework the emulation of serial console via JTAG from simple ad-hoc implementation of serial port routines to CONFIG_SERIAL_MULTI and enable CONFIG_SERIAL_MULTI unconditionally for blackfin. In order for the JTAG serial console to take precedence over all other serial ports available in system, implement override for default_serial_console call returning this JTAG serial console. This brings in a bit of a growth of size, but eventually will allow us to unconditionally enable CONFIG_SERIAL_MULTI throughout the whole U-Boot and maintain only one serial subsystem. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: bfin: Adjust serial_register_bfin_uart()Marek Vasut
Rename the serial_register_bfin_uart() to bfin_initialize_serial() to be consistent with the rest of the naming. Next, remove it's prototype from serial.h and properly insert it into serial.c as the rest of the serial initialization functions. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: Rename .init() and .uninit() in serial_deviceMarek Vasut
Rename .init() to .start() and .uninit() to .stop() in struct serial_device. This allows aligning struct serial_device with closer to struct stdio_dev. The real goal here is to allow these two structures to converge together and eventually make one to be a superset of the other. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-10-15COMMON: Use __stringify() instead of MK_STR()Marek Vasut
Kill multiple occurances and redeclaration of MK_STR in favor of __stringify(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Wolfgang Denk <wd@denx.de> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-01Consolidate bootcount code into drivers/bootcountStefan Roese
This patch moves all bootcount implementations into a common directory: drivers/bootcount. The generic bootcount driver is now usable not only by powerpc platforms, but others as well. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Valentin Longchamp <valentin.longchamp@keymile.com> Cc: Christian Riesch <christian.riesch@omicron.at> Cc: Manfred Rudigier <manfred.rudigier@omicron.at> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Rob Herring <rob.herring@calxeda.com> Cc: Reinhard Meyer <reinhard.meyer@emk-elektronik.de> Tested-by: Valentin Longchamp <valentin.longchamp@keymile.com> Tested-by: Christian Riesch <christian.riesch@omicron.at> Acked-by: Rob Herring <rob.herring@calxeda.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-03Blackfin: easylogo: add lzma logosMike Frysinger
The bf527-ezkit boards are getting too big to fit into their reserved flash space, so we need to use a lzma compressed logo. Since the video driver code is very similar, add lzma compressed support to all of the Blackfin video drivers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-04-22Blackfin: move gd/bd to bss by defaultMike Frysinger
We don't need these setup manually, so let the bss do the rest. On Blackfin systems, we clear the bss before executing any C code that would use these, so this should be fine. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-04-22Blackfin: gd_t: relocate volatile markingsMike Frysinger
This makes Blackfin behave the same as other ports, and fixes many gcc warnings that show up with 4.5+: board.c:40:1: warning: optimization may eliminate reads and/or writes to register variables Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12linkage.h: move from blackfin to common includesMacpaul Lin
1. Add linkage.h support from blackfin to common include, which is a reduced version from Linux. 2. Add architecture part support of linkage.h into blackfin 3. Fix include path of in blackfin related to linkage.h due to header file movement. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-02-12Blackfin: add in/out le32 variantsMike Frysinger
These are rarely used, but the post code does currently, so add small redirect hacks for that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-18Blackfin: cache result of cpp checkMike Frysinger
Avoid overhead of computing this value multiple times. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-18Blackfin: traps: fix up printf warnings from debugMike Frysinger
Cast uint32_t to void* for %p, and use %zu for size_t. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-18Blackfin: drop now unused local variableMike Frysinger
2011-10-23blackfin: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-16Blackfin: define CONFIG_SYS_CACHELINE_SIZEMike Frysinger
Common U-Boot API wants this define, so import asm/cache.h from Linux to provide suitable defines. Acked-by: Anton Staaf <robotboy@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05POST: add post_log_res field for post results in global dataValentin Longchamp
The current post_log_word in global data is currently split into 2x 16 bits: half for the test start, half for the test success. Since we alredy have more than 16 POST tests defined and more could be defined, this may result in an overflow and the post_output_backlog would not work for the tests defined further of these 16 positions. An additional field is added to global data so that we can now support up to 32 (depending of architecture) tests. The post_log_word is only used to record the start of the test and the new field post_log_res for the test success (or failure). The post_output_backlog is for this change also adapted. Signed-off-by: Valentin Longchamp <valentin.longchamp@keymile.com>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-09-29Blackfin: uart: implement loop callback for postMike Frysinger
This allows the Blackfin UART driver to be tested via post. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: generalize led/button tests with GPIOsMike Frysinger
Make it easy for any Blackfin board to enable led/push button tests. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: drop custom test listMike Frysinger
The few tests that are Blackfin-specific have been migrated to common code or been rewritten with the existing "bsp-specific" defines. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Use ALL-y style instead of ifeq blocks for better readabilityDaniel Schwierzeck
Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2011-07-12Blackfin: jtag-console: fix timer usageMike Frysinger
Reported-by: Graeme Russ <graeme.russ@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: switch to common display_options()Mike Frysinger
Use common code to output the version string rather than doing it ourselves. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: serial: move early debug strings into .rodata sectionMike Frysinger
Rewrite the assembly serial_early_puts() helper to place the strings in the .rodata section rather than embedding them directly in the .text section. Using .text is a little simpler, but it doesn't let people execute out of internal L1 sram (since core reads don't work on those regions). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: update anomaly lists to latest public infoMike Frysinger
