path: root/arch/blackfin
2010-11-19Blackfin: drop initcode.o from combined objectMike Frysinger
We explicitly link in the initcode.o in the Blackfin linker script, so there is no need to merge it into the main common object for the linker to pull in itself. This also fixes duplicate symbol errors with the new partial linking logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-18Blackfin: make sure bss len is multiple of 4 bytesMike Frysinger
The Blackfin on-chip BootROM requires that fill operations (which is used for the bss) be aligned to 4 bytes (base addr and total len). Plus, the Blackfin early init asm code assumes the same thing. So rather than making things work for no real gain, make sure the bss len is padded to 4 bytes in the linker script. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-11-18Blackfin: stick ins/outs funcs into their own .text sectionMike Frysinger
This lets the linker garbage collect these functions when they aren't actually used by placing them into the standard .text.<func> section. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Blackfin: config.mk: drop manual stripping of config varsMike Frysinger
Now that the common code takes care of stripping away quotes and such from numeric options, we no longer need to do so ourselves. So drop the custom code we have in the Blackfin config.mk. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-27Blackfin: fix building after asm-offsets.h introMike Frysinger
Since some of the defines in our config.h use the generated defines, we need to include the generated header. This fixes building of the Blackfin start.S file (where the stack is setup). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-14Blackfin: workaround anomaly 05000440Mike Frysinger
We cannot rely on the syscontrol rom func to program PLL_DIV with anomaly 05000440 is in effect, so manually program the MMR when necessary. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-14Blackfin: update anomaly lists to latest sheetsMike Frysinger
2010-10-02Blackfin: fix MMC init output alignmentMike Frysinger
2010-10-02Blackfin: propagate target cpu defines when building embedded envMike Frysinger
Since we're no longer extracting the env from the target ELF file (since upstream wouldn't take that change), we're back to the problem of cpu defines not properly propagating to the env setup stage. So the embedded env built by the host compiler doesn't match the one that is linked into the u-boot env. Reported-by: Vivi Li <vivi.li@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: accept upper case pin namesMike Frysinger
The intention all along was to accept pin names irrelevant of their case. But I guess I forgot to test/implement support for that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: return gpio value to callerMike Frysinger
Make the GPIO command usable in a scripting environment by returning the GPIO value rather than always 0. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: document/extend input sub-optionMike Frysinger
The input sub command was missing from the help text, and it didn't show the actual value currently read on the GPIO. This allows people to read the value of input pins. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf561: merge headersMike Frysinger
Only the BF561 port was using the common dual core headers, so merge them into the BF561 specific headers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bf533: merge headersMike Frysinger
Only the BF533 port was using the common extended headers, so merge them into the BF533 specific headers. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: unify core MMRsMike Frysinger
2010-10-02Blackfin: bf52x: unify arch header duplicationMike Frysinger
2010-10-02Blackfin: bf537: unify arch header duplicationMike Frysinger
2010-10-02Blackfin: punt old *p style volatile MMR definesMike Frysinger
These are unused now, so punt them to clean things up. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: punt headers for non-existent BF541Mike Frysinger
There is no BF541 processor variant, so punt headers for it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: bfin_spi: add optional DMA supportMike Frysinger
This moves the last piece from the old spi_flash driver to the new SPI framework -- optional DMA RX support. This typically cuts speeds by ~40% at the cost of additional ~300 bytes. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: add support for BF51x partsMike Frysinger
2010-10-02Blackfin: add support for BF538/BF539 processorsMike Frysinger
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-21Blackfin: bfin_spi: use same gpio cs define as LinuxMike Frysinger
Linux uses an offset of 8 to switch from hardware cs to a gpio cs, so have u-boot use the same value. Also make sure it is public for boards to access. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-11Blackfin: re-use board data in cpu bannerMike Frysinger
The bi_cpu field of the board data is already set to the relevant cpu string, so there is no need for us to use the define directly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-11Blackfin: shutdown video DMA when booting LinuxMichael Hennerich
In case there is no frame buffer driver present in Linux to hand over the PPI LCD DMA upon boot, the DMA initiated by u-boot to display the splash screen runs unattended. Therefore always stop the video driver in u-boot before starting Linux. If people don't want this behavior, then they can simply stub out the video_stop() function in their board video driver. Signed-off-by: Michael Hennerich <michael.hennerich@analog.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-29Blackfin: gpio: use common usage funcMike Frysinger
2010-07-25Blackfin: jtag-console: handle newline stuffingMike Frysinger
Serial devices currently have to manually stuff \r after every \n found, but this is a bit more difficult with the jtag console since we process everything in chunks of 4 bit. So we have to scan & stuff the whole string rather than what most serial drivers do which is output on a byte per byte basis. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-25Blackfin: jtag-console: add debug markersMike Frysinger
While we're in here, add some useful debug points. We need custom debug statements because we need the output to only go to the serial port. If we used the standard debug helpers, the output would also go to the stdout (which would be the jtag console) and make it hard to figure out what is going where exactly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-25Blackfin: jtag-console: robustify against missing peerMike Frysinger
If the other side isn't listening, we should reset the state to ignore the whole message and not just the part we missed. This makes it easier to connect at any time to the jtag console without worrying about the two sides getting out of sync and thus sending garbage back and forth. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: bf561: use DMA for Core B L1 regionsMike Frysinger
The L1 regions of Core B are not directly accessible from Core A, so we need to use DMA to get at them. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: serial: convert to portmux frameworkMike Frysinger
Use the new portmux framework to handle the details when possible. Unfortunately, we cannot yet use this in the standalone initialization logic, so we need to keep around the old portmux writes for now. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: unify custom gpio commandsMike Frysinger
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: import gpio/portmux layer from LinuxMike Frysinger
The current pinmux handling has spread throughout Blackfin drivers and board code and is getting hideous to maintain. So import the gpio and portmux layer from the Blackfin Linux code. This should spur a serious of cleanups across the Blackfin tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: set up simple NMI handlers for anomaly 05000219Mike Frysinger
Older on-chip Blackfin bootroms do not create a dummy NMI handler, so set up one ourselves when anomaly 05000219 applies. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: update anomaly lists to latest sheetsMike Frysinger
2010-07-05Blackfin: expand EVT1 usage documentation a bit moreMike Frysinger
2010-07-05Blackfin: implement bootcount supportMike Frysinger
The default storage location for bootcount is EVT0. This version uses one 32bit value and combines the magic/count value in the upper/lower 16bits. If there is demand for more, should be easy to do. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: clean up trace buffer handling when crashingMike Frysinger
Avoid banging on the trace MMRs when debugging is disabled, avoid calling the funcs multiple times in a row, disable the trace buffer earlier in the exception handler to avoid eating more user entries, and dump the buffer before calling the kgdb hook. This way we maximize useful debugging info up front rather than needing external tools (like gdb/serial/etc...). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
