functions
- move blackfin specific cpu init code from blackfin board.c to cpu.c
- remove blackfin specific board init code and invoke generic board_f fron cpu init entry
- rename section name bss_vma to bss_start in order to match the generic board init code
- add a fake relocate_code function to set up the new stack only
Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
gd->bd->bi_baudrate is a copy of gd->baudrate.
Since baudrate is a common feature for all architectures,
keep gd->baudrate only.
It is true that bi_baudrate was passed to the kernel in that structure
but it was a long time ago.
Cc: Tom Rini <trini@ti.com>
Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
With d6a320d we moved some clock externs out of blackfin_local.h and
into clock.h but now need to include <asm/clock.h> in more drivers to
avoid warnings.
Cc: Sonic Zhang <sonic.zhang@analog.com>
Current code uses gd->baudrate before setting its value.
Besides, I got below build warning which is introduced by
commit ddb5c5be "blackfin: add baudrate to bdinfo".
board.c:235:3: warning: passing argument 1 of 'simple_strtoul' makes pointer from integer without a cast [enabled by default]
include/vsprintf.h:27:7: note: expected 'const char *' but argument is of type 'unsigned int'
This patch ensures we get the baudrate setting before using it.
Signed-off-by: Axel Lin <axel.lin@ingics.com>
Cc: Henrik Nordström <henrik@henriknordstrom.net>
- Enable hw_watchdog_init() in watchdog.h if CONFIG_HW_WATCHDOG is defined.
- Move blackfin hw watchdog driver to the generic driver folder.
- Call hw_watchdog_init() from blackfin board init code.
- Reuse macro CONFIG_WATCHDOG_TIMEOUT_MSECS
- Update README.watchdog accordingly
Signed-off-by: Bob Liu <lliubbo@gmail.com>
Delete all occurrences of hang() and provide a generic function.
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
[trini: Modify check around puts() in hang.c slightly]
This should be in arch_global_data but was dropped in the change-over.
BF60x support 16K, 64K, 16M and 64M cplb pages, this patch add support for them.
So that bf609-ezkit can use it's 128M memory.
Signed-off-by: Sonic Zhang <sonic.adi@gmail.com>
Set up clocks, DDR controller, Nor flash controller, reboot,
serial port. Add new SPI boot modes.
This doesn't need to be a long, so change it.
Also adjust bi_baudrate to be unsigned.
Remove the parts depending either on disabled CONFIG_SERIAL_MULTI
or ifdefs around CONFIG_SERIAL_MULTI parts since CONFIG_SERIAL_MULTI
is now enabled by default.
Cc: Marek Vasut <marek.vasut@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Kill multiple occurances and redeclaration of MK_STR
in favor of __stringify().
All arches init this the same way, so move the logic into the core
net code to avoid duplicating it everywhere else.
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
This field gets read in one place (by "bdinfo"), and we can replace
that with getenv("ipaddr"). After all, the bi_ip_addr field is kept
up-to-date implicitly with the value of the ipaddr env var.
We don't need these setup manually, so let the bss do the rest. On
Blackfin systems, we clear the bss before executing any C code that
would use these, so this should be fine.
This changes the board code to use the new getenv_ulong() function.
* 'master' of git://git.denx.de/u-boot-blackfin:
Blackfin: jtag-console: fix timer usage
Blackfin: switch to common display_options()
Blackfin: serial: move early debug strings into .rodata section
Blackfin: adi boards: also set stderr to nc with helper
Blackfin: update anomaly lists to latest public info
Blackfin: serial: convert to bfin_{read,write} helpers
Blackfin: split out async setup
Blackfin: adi boards: enable pretty flash progress output
Blackfin: drop unused dma.h header from start code
Blackfin: portmux: allow header to be included in assembly files
Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support
Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings
Blackfin: sync MMR read/write helpers with Linux
Blackfin: gpio: optimize free path a little
Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR
Blackfin: uart: fix printf warning
Blackfin: add init.elf helper code
Blackfin: dont reset SWRST on newer bf526 parts
Blackfin: adi boards: enable multi serial support by default
Blackfin: uart: add multiple serial support
Blackfin: uart: move debug buffers into local bss
This patch removes the architecture specific implementation of
version_string where possible. Some architectures use a special place
and therefore we provide U_BOOT_VERSION_STRING definition and a common
weak symbol version_string.
CC: Mike Frysinger <vapier@gentoo.org>
CC: Peter Pan <pppeterpppan@gmail.com>
Use common code to output the version string rather than doing it
ourselves.
This brings CONFIG_SERIAL_MULTI support to the Blackfin on-chip UARTs.
Ends up adding only ~512bytes per additional UART.
If the part has no external memory configured, then there will be no os
log for us to check, and any attempt to access that memory will trigger
hardware errors.
The recent global data changes (making the size autogenerated) broke the
board info handling on Blackfin ports as we were lying and lumping the
bd_t size in with the gd_t size. So use the new dedicated bd_t size to
setup its own address in memory.
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code.
CONFIG_SYS_GBL_DATA_SIZE has always been just a bad workarond for not
being able to use "sizeof(struct global_data)" in assembler files.
Recent experience has shown that manual synchronization is not
reliable enough. This patch renames CONFIG_SYS_GBL_DATA_SIZE into
GENERATED_GBL_DATA_SIZE which gets automatically generated by the
asm-offsets tool. In the result, all definitions of this value can be
deleted from the board config files. We have to make sure that all
files that reference such data include the new <asm-offsets.h> file.
No other changes have been done yet, but it is obvious that similar
changes / simplifications can be done for other, related macro
definitions as well.
Acked-by: Kumar Gala <galak@kernel.crashing.org>
The CONFIG_BFIN_CPU option is largely used in the build system, so move
it out of the board config.h and into the board config.mk. It'd be nice
to keep everything in the config.h, but the patch to extract that value
early was rejected.
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
The bi_cpu field of the board data is already set to the relevant cpu
string, so there is no need for us to use the define directly.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
