path: root/arch/blackfin/include/asm/config.h
2015-03-28generic-board: select SYS_GENERIC_BOARD for some architecturesMasahiro Yamada
We have done with the generic board conversion for all the boards of ARC, Blackfin, M68000, MicroBlaze, MIPS, NIOS2, Sandbox, X86. Let's select SYS_GENERIC_BOARD for those architectures, so we can tell which architecture has finished the conversion at a glance. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Alexey Brodkin <abrodkin@synopsys.com>
2014-11-10bfin: make the CPU macro of LDR target more genenricSonic Zhang
Remove BFIN from the CPU macro in Makefile. Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2014-08-07blackfin: convert blackfin board_f and board_r to use generic board init ↵Sonic Zhang
functions - move blackfin specific cpu init code from blackfin board.c to cpu.c - remove blackfin specific board init code and invoke generic board_f fron cpu init entry - rename section name bss_vma to bss_start in order to match the generic board init code - add a fake relocate_code function to set up the new stack only Signed-off-by: Sonic Zhang <sonic.zhang@analog.com>
2013-11-04config: remove platform CONFIG_SYS_HZ definition part 2/2Rob Herring
Remove platform CONFIG_SYS_HZ definition for configs a-z*. Signed-off-by: Rob Herring <rob.herring@calxeda.com>
2012-06-20CONFIG_SYS_BAUDRATE_TABLE: Add <config_fallbacks.h>, place thereTom Rini
We provide a default table of { 9600, 19200, 38400, 57600, 115200 } in <config_fallbacks.h> which mkconfig places after <configs/...h> in the generated config file. This is used when a board has not set its own table. Signed-off-by: Tom Rini <trini@ti.com>
2012-04-22Blackfin: move gd/bd to bss by defaultMike Frysinger
We don't need these setup manually, so let the bss do the rest. On Blackfin systems, we clear the bss before executing any C code that would use these, so this should be fine. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-16Blackfin: define CONFIG_SYS_CACHELINE_SIZEMike Frysinger
Common U-Boot API wants this define, so import asm/cache.h from Linux to provide suitable defines. Acked-by: Anton Staaf <robotboy@chromium.org> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: post: generalize led/button tests with GPIOsMike Frysinger
Make it easy for any Blackfin board to enable led/push button tests. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDRMike Frysinger
Set the default post word location to an L1 data location for all Blackfin parts so things "just work" for most people. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: fix bd_t handlingMike Frysinger
The recent global data changes (making the size autogenerated) broke the board info handling on Blackfin ports as we were lying and lumping the bd_t size in with the gd_t size. So use the new dedicated bd_t size to setup its own address in memory. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: move CONFIG_BFIN_CPU back to board config.hMike Frysinger
This is a revert of 821ad16fa9900c as Wolfgang doesn't like the new code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-27Blackfin: fix building after asm-offsets.h introMike Frysinger
Since some of the defines in our config.h use the generated defines, we need to include the generated header. This fixes building of the Blackfin start.S file (where the stack is setup). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: move CONFIG_BFIN_CPU to board config.mkMike Frysinger
The CONFIG_BFIN_CPU option is largely used in the build system, so move it out of the board config.h and into the board config.mk. It'd be nice to keep everything in the config.h, but the patch to extract that value early was rejected. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
