path: root/arch/blackfin/cpu
2012-02-12linkage.h: move from blackfin to common includesMacpaul Lin
1. Add linkage.h support from blackfin to common include, which is a reduced version from Linux. 2. Add architecture part support of linkage.h into blackfin 3. Fix include path of in blackfin related to linkage.h due to header file movement. Signed-off-by: Macpaul Lin <macpaul@andestech.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-11-18Blackfin: traps: fix up printf warnings from debugMike Frysinger
Cast uint32_t to void* for %p, and use %zu for size_t. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-09-29Blackfin: uart: implement loop callback for postMike Frysinger
This allows the Blackfin UART driver to be tested via post. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-08-02Merge branch 'master' of git://git.denx.de/u-boot-blackfinWolfgang Denk
* 'master' of git://git.denx.de/u-boot-blackfin: Blackfin: jtag-console: fix timer usage Blackfin: switch to common display_options() Blackfin: serial: move early debug strings into .rodata section Blackfin: adi boards: also set stderr to nc with helper Blackfin: update anomaly lists to latest public info Blackfin: serial: convert to bfin_{read,write} helpers Blackfin: split out async setup Blackfin: adi boards: enable pretty flash progress output Blackfin: drop unused dma.h header from start code Blackfin: portmux: allow header to be included in assembly files Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: enable mmc_spi support Blackfin: cm-bf537e/cm-bf537u/tcm-bf537: update network settings Blackfin: sync MMR read/write helpers with Linux Blackfin: gpio: optimize free path a little Blackfin: post: setup default CONFIG_SYS_POST_WORD_ADDR Blackfin: uart: fix printf warning Blackfin: add init.elf helper code Blackfin: dont reset SWRST on newer bf526 parts Blackfin: adi boards: enable multi serial support by default Blackfin: uart: add multiple serial support Blackfin: uart: move debug buffers into local bss
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-12Blackfin: jtag-console: fix timer usageMike Frysinger
Reported-by: Graeme Russ <graeme.russ@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: serial: move early debug strings into .rodata sectionMike Frysinger
Rewrite the assembly serial_early_puts() helper to place the strings in the .rodata section rather than embedding them directly in the .text section. Using .text is a little simpler, but it doesn't let people execute out of internal L1 sram (since core reads don't work on those regions). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: serial: convert to bfin_{read,write} helpersMike Frysinger
Since the serial struct declares the sizes for us, no need to hardcode them in the accessor functions. Let the bfin_{read,write} helpers do it for us. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: split out async setupMike Frysinger
We really only need to tweak the async banks in the initcode if the processor is booting out of it, otherwise we can wait until later on in the CPU booting setup. This also makes testing in the sim and early bring up over JTAG work much smoother when the initcode gets bypassed. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: drop unused dma.h header from start codeMike Frysinger
2011-07-12Blackfin: gpio: optimize free path a littleMike Frysinger
When we aren't doing resource tracking, the gpio_free() function is a stub that simply returns, so pull this logic up a level and make it an inline stub in the header. Now we don't have to waste time at any of the call sites. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: uart: fix printf warningMike Frysinger
The code uses %i to printf a size_t when it should use %zu, otherwise we get a warning from gcc about it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: add init.elf helper codeMike Frysinger
This creates a standalone ELF that executes just the Blackfin initcode. This is useful for people who want to program the low level aspects of the CPU (memory/clocks/etc...) and can easily be used with JTAG for quick booting while developing. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: dont reset SWRST on newer bf526 partsMike Frysinger
The bug in the BF526 rom when doing a software reset exists only in older silicon versions, so don't clear SWRST on newer parts. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: uart: add multiple serial supportMike Frysinger
This brings CONFIG_SERIAL_MULTI support to the Blackfin on-chip UARTs. Ends up adding only ~512bytes per additional UART. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-07-12Blackfin: uart: move debug buffers into local bssMike Frysinger
There's no need for these saved buffers to be global symbols, or in the data section. So mark them static to move them into the bss. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03Blackfin: use on-chip reset func with newer partsMike Frysinger
Turns out the documentation is wrong and doing "RAISE 1" does not result in a software reset, only a core reset. So when the on-chip rom has a functioning reset helper, use it. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-06-03Blackfin: use common LDSCRIPT logicMike Frysinger
Now that common code is a bit smarter when it comes to default LDSCRIPT values, rename the default Blackfin file and drop the Blackfin-specific config.mk logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-13gpio: generalize for all generic gpio providersMike Frysinger
The Blackfin gpio command isn't terribly Blackfin-specific. So generalize the few pieces into two new optional helpers: name_to_gpio() - turn a string name into a GPIO # gpio_status() - display current pin bindings (think /proc/gpio) Once these pieces are pulled out, we can relocate the cmd_gpio.c into the common directory. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: replace "bfin_reset_or_hang()" with "panic()"Kyle Moffett
The bfin_reset_or_hang function unnecessarily duplicates the panic() logic based on CONFIG_PANIC_HANG. This patch deletes 20 lines of code and just calls panic() instead. This also makes the following generic-restart conversion patch simpler. Signed-off-by: Kyle Moffett <Kyle.D.Moffett@boeing.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: turn off caches when self initializingMike Frysinger
When bootstrapping ourselves on the fly at runtime (via "go"), we need to turn off the caches to avoid taking software exceptions. Since caches need CPLBs and CPLBs need exception handlers, but we're about to rewrite the code in memory where those exception handlers live, we need to turn off caches first. This new code also encourages a slight code optimization by storing the MMR bases in dedicated registers so we don't have to fully load up the pointer regs multiple times. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-04-08Blackfin: BF50x: new processor portMike Frysinger
2011-04-08Blackfin: serial: clean up muxing a bitMike Frysinger
2010-12-21Move DECLARE_GLOBAL_DATA_PTR to file scopeJohn Rigby
It can be optimised out by the compiler otherwise resulting in obscure errors like a board not booting. This has been documented in README since 2006 when these were first fixed up for GCC 4.x. Signed-off-by: John Rigby <john.rigby@linaro.org> Fix some additional places. Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-By: Albert ARIBAUD <albert.aribaud@free.fr>
2010-11-19Blackfin: drop initcode.o from combined objectMike Frysinger
We explicitly link in the initcode.o in the Blackfin linker script, so there is no need to merge it into the main common object for the linker to pull in itself. This also fixes duplicate symbol errors with the new partial linking logic. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-14Blackfin: workaround anomaly 05000440Mike Frysinger
We cannot rely on the syscontrol rom func to program PLL_DIV with anomaly 05000440 is in effect, so manually program the MMR when necessary. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: accept upper case pin namesMike Frysinger
The intention all along was to accept pin names irrelevant of their case. But I guess I forgot to test/implement support for that. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: return gpio value to callerMike Frysinger
Make the GPIO command usable in a scripting environment by returning the GPIO value rather than always 0. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-10-02Blackfin: cmd_gpio: document/extend input sub-optionMike Frysinger
The input sub command was missing from the help text, and it didn't show the actual value currently read on the GPIO. This allows people to read the value of input pins. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-29Blackfin: gpio: use common usage funcMike Frysinger
2010-07-25Blackfin: jtag-console: handle newline stuffingMike Frysinger
Serial devices currently have to manually stuff \r after every \n found, but this is a bit more difficult with the jtag console since we process everything in chunks of 4 bit. So we have to scan & stuff the whole string rather than what most serial drivers do which is output on a byte per byte basis. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-25Blackfin: jtag-console: add debug markersMike Frysinger
While we're in here, add some useful debug points. We need custom debug statements because we need the output to only go to the serial port. If we used the standard debug helpers, the output would also go to the stdout (which would be the jtag console) and make it hard to figure out what is going where exactly. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-25Blackfin: jtag-console: robustify against missing peerMike Frysinger
If the other side isn't listening, we should reset the state to ignore the whole message and not just the part we missed. This makes it easier to connect at any time to the jtag console without worrying about the two sides getting out of sync and thus sending garbage back and forth. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-13Blackfin: serial: convert to portmux frameworkMike Frysinger
Use the new portmux framework to handle the details when possible. Unfortunately, we cannot yet use this in the standalone initialization logic, so we need to keep around the old portmux writes for now. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: unify custom gpio commandsMike Frysinger
Now that we have a unified gpio layer, the misc partial gpio commands can be unified and made complete (support all possible gpios). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: import gpio/portmux layer from LinuxMike Frysinger
The current pinmux handling has spread throughout Blackfin drivers and board code and is getting hideous to maintain. So import the gpio and portmux layer from the Blackfin Linux code. This should spur a serious of cleanups across the Blackfin tree. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: set up simple NMI handlers for anomaly 05000219Mike Frysinger
Older on-chip Blackfin bootroms do not create a dummy NMI handler, so set up one ourselves when anomaly 05000219 applies. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: expand EVT1 usage documentation a bit moreMike Frysinger
2010-07-05Blackfin: implement bootcount supportMike Frysinger
The default storage location for bootcount is EVT0. This version uses one 32bit value and combines the magic/count value in the upper/lower 16bits. If there is demand for more, should be easy to do. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-07-05Blackfin: clean up trace buffer handling when crashingMike Frysinger
Avoid banging on the trace MMRs when debugging is disabled, avoid calling the funcs multiple times in a row, disable the trace buffer earlier in the exception handler to avoid eating more user entries, and dump the buffer before calling the kgdb hook. This way we maximize useful debugging info up front rather than needing external tools (like gdb/serial/etc...). Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2010-04-13blackfin: Move cpu/blackfin/* to arch/blackfin/cpu/*Peter Tyser
