path: root/arch/avr32
2012-09-02avr32: Remove redundant LDSCRIPT definitionBenoît Thébaudeau
AVR32's LD script uses a standard location that is now automatically detected by the main Makefile, so its definition in AVR32's config.mk is now obsolete and redundant. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-04avr32:board.c: fix compile warningAndreas Bießmann
This patch fixes following warning: ---8<--- board.c: In function 'board_init_r': board.c:257: warning: unused variable 's' --->8--- Patch de30122bb58fee7b0f94bcfabab595b6ad757336 missed to remove this variable too. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-13ATMEL: remove old atmel_mci driverSven Schnelle
All boards are using the gen_atmel_mci driver now, so no need to carry the old driver around. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-03-13ATMEL: use generic mmc frameworkSven Schnelle
gen_atmel_mci works on AVR32 as well, so no need to use the legacy mmc driver. This also has the nice side effect of being able to use SDHC cards an those boards. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-20AVR32: fix timer_init() functionSven Schnelle
timer_init() now returns an int (the error code) instead of void. This makes compilation fail with: interrupts.c:111: error: conflicting types for 'timer_init' /home/svens/u-boot/u-boot/include/common.h:246: error: previous declaration of 'timer_init' was here make[1]: *** [interrupts.o] Error 1 Signed-off-by: Sven Schnelle <svens@stackframe.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-17avr32:mmu.c: fix printf() length modifierAndreas Bießmann
avr32 uses unsigned long addresses, fix the printf() length modifier for that fact. Before this patch following warning occours: ---8<--- mmu.c: In function 'mmu_init_r': mmu.c:25: warning: format '%08x' expects type 'unsigned int', but argument 2 has type 'uintptr_t' --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> cc: Mike Frysinger <vapier@gentoo.org> cc: Thomas Chou <thomas@wytron.com.tw> cc: Reinhard Meyer <u-boot@emk-elektronik.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23avr32: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23avr32: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-08-01Unify timer_init() and cpu_init() prototypesWolfgang Denk
Clean up some duplicated prototype declarations. Get rid of now useless AVR32 initcalls.h file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Graeme Russ <graeme.russ@gmail.com>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-05-18avr32: add ATAG_BOARDINFOAndreas Bießmann
This patch adds a new ATAG_BORADINFO to U-Boot. This tag is intended to hand over the bd->bi_board_number to the linux kernel for early stage board information like a board revision or other kind of board specific decisions necessary before the linux peripherial drivers are up. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: use single linker scriptAndreas Bießmann
This patch move the atstk100x linker script to $(CPUDIR) and delete other pure copies of this file in each board directory. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32/config.mk: simplify PLATFORM_RELFLAGSAndreas Bießmann
This patch removes PLATFORM_RELFLAGS from board specific config.mk files and define them in arch specific config.mk file. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fix linkingAndreas Bießmann
This patch fixes following error: ---8<--- avr32-linux-ld: --gc-sections and -r may not be used together --->8--- Since 8aba9dceebb14144e07d19593111ee3a999c37fc all avr32 boards are broken due to linking error as seen above. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fixup definitions to ATMEL_BASE_xxxAndreas Bießmann
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
2011-04-12Make STANDALONE_LOAD_ADDR configurable per boardWolfgang Denk
Rename STANDALONE_LOAD_ADDR into CONFIG_STANDALONE_LOAD_ADDR and allow that the architecture-specific default value gets overwritten by defining the value in the board header file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Shinya Kuribayashi <skuribay@ruby.dti.ne.jp> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Tsi Chung Liew <tsi-chung.liew@freescale.com> Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-19board_init_r: Removed unused cmdtp variableRichard Retanubun
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02 removed compiler warning for (now) unused cmd_tbl_t* cmdtp
2010-09-19relocation: fixup cmdtableHeiko Schocher
fixup_cmdtable() did all work for fixing up the cmdtable, if CONFIG_RELOC_FIXUP_WORKS is not defined. CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked with Graeme Russ, and he will fix this soon. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-19arm: get rid of bi_envHeiko Schocher
bi_env is nowhere used, so delete it! Signed-off-by: Heiko Schocher <hs@denx.de> similar patch posted from Dirk Behme Tue Jul 27 18:36:09 CEST 2010 http://lists.denx.de/pipermail/u-boot/2010-July/074542.html
2010-09-19New implementation for internal handling of environment variables.Wolfgang Denk
Motivation: * Old environment code used a pessimizing implementation: - variable lookup used linear search => slow - changed/added variables were added at the end, i. e. most frequently used variables had the slowest access times => slow - each setenv() would calculate the CRC32 checksum over the whole environment block => slow * "redundant" envrionment was locked down to two copies * No easy way to implement features like "reset to factory defaults", or to select one out of several pre-defined (previously saved) sets of environment settings ("profiles") * No easy way to import or export environment settings ====================================================================== API Changes: - Variable names starting with '#' are no longer allowed I didn't find any such variable names being used; it is highly recommended to follow standard conventions and start variable names with an alphanumeric character - "printenv" will now print a backslash at the end of all but the last lines of a multi-line variable value. Multi-line variables have never been formally defined, allthough there is no reason not to use them. Now we define rules how to deal with them, allowing for import and export. - Function forceenv() and the related code in saveenv() was removed. At the moment this is causing build problems for the only user of this code (schmoogie - which has no entry in MAINTAINERS); may be fixed later by implementing the "env set -f" feature. Inconsistencies: - "printenv" will '\\'-escape the '\n' in multi-line variables, while "printenv var" will not do that. ====================================================================== Advantages: - "printenv" output much better readable (sorted) - faster! - extendable (additional variable properties can be added) - new, powerful features like "factory reset" or easy switching between several different environment settings ("profiles") Disadvantages: - Image size grows by typically 5...7 KiB (might shrink a bit again on systems with redundant environment with a following patch series) ====================================================================== Implemented: - env command with subcommands: - env print [arg ...] same as "printenv": print environment - env set [-f] name [arg ...] same as "setenv": set (and delete) environment variables ["-f" - force setting even for read-only variables - not implemented yet.] - end delete [-f] name not implemented yet ["-f" - force delete even for read-only variables] - env save same as "saveenv": save environment - env export [-t | -b | -c] addr [size] export internal representation (hash table) in formats usable for persistent storage or processing: -t: export as text format; if size is given, data will be padded with '\0' bytes; if not, one terminating '\0' will be added (which is included in the "filesize" setting so you can for exmple copy this to flash and keep the termination). -b: export as binary format (name=value pairs separated by '\0', list end marked by double "\0\0") -c: export as checksum protected environment format as used for example by "saveenv" command addr: memory address where environment gets stored size: size of output buffer With "-c" and size is NOT given, then the export command will format the data as currently used for the persistent storage, i. e. it will use CONFIG_ENV_SECT_SIZE as output block size and prepend a valid CRC32 checksum and, in case of resundant environment, a "current" redundancy flag. If size is given, this value will be used instead of CONFIG_ENV_SECT_SIZE; again, CRC32 checksum and redundancy flag will be inserted. With "-b" and "-t", always only the real data (including a terminating '\0' byte) will be written; here the optional size argument will be used to make sure not to overflow the user provided buffer; the command will abort if the size is not sufficient. Any remainign space will be '\0' padded. On successful return, the variable "filesize" will be set. Note that filesize includes the trailing/terminating '\0' byte(s). Usage szenario: create a text snapshot/backup of the current settings: => env export -t 100000 => era ${backup_addr} +${filesize} => cp.b 100000 ${backup_addr} ${filesize} Re-import this snapshot, deleting all other settings: => env import -d -t ${backup_addr} - env import [-d] [-t | -b | -c] addr [size] import external format (text or binary) into hash table, optionally deleting existing values: -d: delete existing environment before importing; otherwise overwrite / append to existion definitions -t: assume text format; either "size" must be given or the text data must be '\0' terminated -b: assume binary format ('\0' separated, "\0\0" terminated) -c: assume checksum protected environment format addr: memory address to read from size: length of input data; if missing, proper '\0' termination is mandatory - env default -f reset default environment: drop all environment settings and load default environment - env ask name [message] [size] same as "askenv": ask for environment variable - env edit name same as "editenv": edit environment variable - env run same as "run": run commands in an environment variable ====================================================================== TODO: - drop default env as implemented now; provide a text file based initialization instead (eventually using several text files to incrementally build it from common blocks) and a tool to convert it into a binary blob / object file. - It would be nice if we could add wildcard support for environment variables; this is needed for variable name auto-completion, but it would also be nice to be able to say "printenv ip*" or "printenv *addr*" - Some boards don't link any more due to the grown code size: DU405, canyonlands, sequoia, socrates. => cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Stefan Roese <sr@denx.de>, Heiko Schocher <hs@denx.de> - Dropping forceenv() causes build problems on schmoogie => cc: Sergey Kubushyn <ksi@koi8.net> - Build tested on PPC and ARM only; runtime tested with NOR and NAND flash only => needs testing!! Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>, Cc: Stefan Roese <sr@denx.de>, Cc: Heiko Schocher <hs@denx.de> Cc: Sergey Kubushyn <ksi@koi8.net>
2010-09-19Make getenv() work before relocation.Wolfgang Denk
So far, getenv() would work before relocation is most cases, even though it was not intended to be used that way. When switching to a hash table based implementation, this would break a number of boards. For convenience, we make getenv() check if it's running before relocation and, if so, use getenv_f() internally. Note that this is limited to simple cases, as we use a small static buffer (32 bytes) in the global data for this purpose. For this reason, it is also not a good idea to convert all current uses of getenv_f() into getenv() - some of the existing use cases need to be able to deal with longer variable values, so getenv_f() is still needed and recommended for use before relocation. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-09-03avr32: Print unrelocated PC on exceptionHaavard Skinnemoen
In addition to the real PC value, also print the value of PC after subtracting the relocation offset. This value will match the address in the ELF file so it's much easier to figure out where things went wrong. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-06-29avr32: add unaligned.hAndreas Bießmann
This patch fixes following error: zlib.c:31:27: error: asm/unaligned.h: No such file or directory Suggested-by: Mike Frysinger <vapier@gentoo.org> Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-06-29avr32: disable branch foldingAndreas Bießmann
Due to a hardware bug mentioned in latest AP7000 datasheet errata (revision M from 09.09) branch folding is unreliable. This patch disables CPUCR.FE bitfield as stated in datasheet. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-06-29Fix (null) problem for AVR32 boardsReinhard Meyer (-VC)
Currently the U-Boot address ranges for AVR32 boards are printed like this: "U-Boot code: (null) -> 0001183c data: 000188e8 -> 0004e9b0" This patch fixes this to print: "U-Boot code: 00000000 -> 0001183c data: 000188f8 -> 0004e9c0" Signed-off-by: Reinhard Meyer <info@emk-elektronik.de>
2010-04-13avr32: Move cpu/at32ap/* to arch/avr32/cpu/*Peter Tyser
2010-04-13Move architecture-specific includes to arch/$ARCH/include/asmPeter Tyser
This helps to clean up the include/ directory so that it only contains non-architecture-specific headers and also matches Linux's directory layout which many U-Boot developers are already familiar with. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
