path: root/arch/avr32
2014-03-04kbuild: fix CROSS_COMPILE settings in config.mkMasahiro Yamada
The syntax CROSS_COMIPLE ?= <cross_compiler_prefix> does not work because config.mk is parsed after exporting CROSS_COMPILE. Like Linux Kernel's arch/$(ARCH)/Makefile, we must write as follows: ifeq ($(CROSS_COMPILE),) CROSS_COMPILE := <cross_compiler_prefix> endif Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-01-24avr32: delete unused header filesMasahiro Yamada
2014-01-24avr32: move CONFIG_AVR32 definition to arch/avr32/config.mkMasahiro Yamada
Like other architectures, CONFIG_AVR32 can be defined in arch/avr32/config.mk rather than board header files. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-10-31avr32: convert makefiles to Kbuild styleMasahiro Yamada
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-13avr32: fix relocation address calculationAndreas Bießmann
Commit 1865286466a5d0c7f2e3c37632da56556c838e9e (Introduce generic link section.h symbol files) changed the __bss_end symbol type from char[] to ulong. This led to wrong relocation parameters which ended up in a not working u-boot. Unfortunately this is not clear to see cause due to RAM aliasing we may get a 'half-working' u-boot then. Fix this by dereferencing the __bss_end symbol where needed. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15avr32: Fix cast warning in board.cSimon Glass
The frame buffer pointer in global_data is not a pointer, so we should remove these casts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Refactor linker-generated arraysAlbert ARIBAUD
Refactor linker-generated array code so that symbols which were previously linker-generated are now compiler- generated. This causes relocation records of type R_ARM_ABS32 to become R_ARM_RELATIVE, which makes code which uses LGA able to run before relocation as well as after. Note: this affects more than ARM targets, as linker- lists span possibly all target architectures, notably PowerPC. Conflicts: arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds arch/arm/cpu/armv7/omap-common/u-boot-spl.lds board/ait/cam_enc_4xx/u-boot-spl.lds board/davinci/da8xxevm/u-boot-spl-da850evm.lds board/davinci/da8xxevm/u-boot-spl-hawk.lds board/vpac270/u-boot-spl.lds Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2013-02-19malloc: make malloc_bin_reloc staticGabor Juhos
On architectures where manual relocation is needed, the 'malloc_bin_reloc' function must be called after 'mem_malloc_init'. Make the 'malloc_bin_reloc' function static and call it directly from 'mem_malloc_init' instead of calling that from board_init_{r,f} functions of the affected architectures. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-02-04avr32: Use generic global_dataSimon Glass
Move avr32 over to use generic global_data. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04avr32: Move cpu_hz to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04avr32: Move stack_end to arch_global_dataSimon Glass
2013-02-01Add architecture-specific global dataSimon Glass
We plan to move architecture-specific data into a separate structure so that we can make the rest of it common. As a first step, create struct arch_global_data to hold these fields. Initially it is empty. This patch applies to all archs at once. I can split it if this is really a pain. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-10-22common: Discard the __u_boot_cmd sectionMarek Vasut
The command declaration now uses the new LG-array method to generate list of commands. Thus the __u_boot_cmd section is now superseded and redundant and therefore can be removed. Also, remove externed symbols associated with this section from include/command.h . Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-19avr32: Change bi_baudrate and global data baudrate to intSimon Glass
These don't need to be longs, so change them. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Tom Rini <trini@ti.com>
2012-09-26malloc: remove extern declarations of malloc_bin_reloc() in board.c filesDaniel Schwierzeck
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations in various board.c files to get rid of one checkpatch.pl warning. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
2012-09-03avr32:portmux: fix setup for macb1Andreas Bießmann
Use portd_mask instead of portc_mask to setup the pins for port D. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-09-02avr32: Remove redundant LDSCRIPT definitionBenoît Thébaudeau
AVR32's LD script uses a standard location that is now automatically detected by the main Makefile, so its definition in AVR32's config.mk is now obsolete and redundant. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-08-09global_data: unify global flag definesMike Frysinger
All the global flag defines are the same across all arches. So unify them in one place, and add a simple way for arches to extend for their needs. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2012-06-04avr32:board.c: fix compile warningAndreas Bießmann
This patch fixes following warning: ---8<--- board.c: In function 'board_init_r': board.c:257: warning: unused variable 's' --->8--- Patch de30122bb58fee7b0f94bcfabab595b6ad757336 missed to remove this variable too. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-13ATMEL: remove old atmel_mci driverSven Schnelle
All boards are using the gen_atmel_mci driver now, so no need to carry the old driver around. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-03-13ATMEL: use generic mmc frameworkSven Schnelle
gen_atmel_mci works on AVR32 as well, so no need to use the legacy mmc driver. This also has the nice side effect of being able to use SDHC cards an those boards. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-12-23Merge branch 'next' of ../nextWolfgang Denk
* 'next' of ../next: mkenvimage: Add version info switch (-V) mkenvimage: Fix getopt() error handling mkenvimage: Fix some typos phy: add Micrel KS8721BL phy definition net: introduce per device index mvgbe: remove setting of ethaddr within the driver x86: Add support for specifying an initrd with the zboot command x86: Refactor the zboot innards so they can be reused with a vboot image x86: Add infrastructure to extract an e820 table from the coreboot tables x86: Add support for booting Linux using the 32 bit boot protocol x86: Clean up the x86 zimage code in preparation to extend it x86: Import code from coreboot's libpayload to parse the coreboot table x86: Initial commit for running as a coreboot payload CHECKPATCH: ./board/esd/hh405/logo_320_240_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_1024_768_8bpp.c CHECKPATCH: ./board/esd/hh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/hh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/apc405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/voh405/logo_320_240_4bpp.c CHECKPATCH: ./board/esd/voh405/logo_640_480_24bpp.c CHECKPATCH: ./board/esd/hh405/fpgadata.c CHECKPATCH: ./board/esd/pci405/fpgadata.c CHECKPATCH: ./board/esd/tasreg/fpgadata.c CHECKPATCH: ./board/esd/apc405/fpgadata.c CHECKPATCH: ./board/esd/voh405/fpgadata.c CHECKPATCH: ./board/esd/ash405/fpgadata.c CHECKPATCH: ./board/esd/dasa_sim/fpgadata.c CHECKPATCH: ./board/esd/ar405/fpgadata_xl30.c CHECKPATCH: ./board/esd/ar405/fpgadata.c CHECKPATCH: ./board/esd/plu405/fpgadata.c CHECKPATCH: ./board/esd/wuh405/fpgadata.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci405ab.c CHECKPATCH: ./board/esd/cpci405/fpgadata_cpci4052.c CHECKPATCH: ./board/esd/canbt/fpgadata.c CHECKPATCH: ./board/esd/du405/fpgadata.c CHECKPATCH: ./board/esd/cpciiser4/fpgadata.c CHECKPATCH: ./board/dave/PPChameleonEVB/fpgadata.c avr32:mmu.c: fix printf() length modifier fat.c: fix printf() length modifier cmd_sf.c: fix printf() length modifier Make printf and vprintf safe from buffer overruns vsprintf: Move function documentation into header file Add safe vsnprintf and snprintf library functions Move vsprintf functions into their own header Conflicts: tools/mkenvimage.c Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-12-20AVR32: fix timer_init() functionSven Schnelle
timer_init() now returns an int (the error code) instead of void. This makes compilation fail with: interrupts.c:111: error: conflicting types for 'timer_init' /home/svens/u-boot/u-boot/include/common.h:246: error: previous declaration of 'timer_init' was here make[1]: *** [interrupts.o] Error 1 Signed-off-by: Sven Schnelle <svens@stackframe.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-12-17avr32:mmu.c: fix printf() length modifierAndreas Bießmann
avr32 uses unsigned long addresses, fix the printf() length modifier for that fact. Before this patch following warning occours: ---8<--- mmu.c: In function 'mmu_init_r': mmu.c:25: warning: format '%08x' expects type 'unsigned int', but argument 2 has type 'uintptr_t' --->8--- Signed-off-by: Andreas Bießmann <biessmann@corscience.de> cc: Mike Frysinger <vapier@gentoo.org> cc: Thomas Chou <thomas@wytron.com.tw> cc: Reinhard Meyer <u-boot@emk-elektronik.de> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-10-23avr32: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-23avr32: cache: define ARCH_DMA_MINALIGN for DMA buffer alignmentAnton Staaf
Signed-off-by: Anton Staaf <robotboy@chromium.org> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Lukasz Majewski <l.majewski@samsung.com> Cc: Reinhard Meyer <u-boot@emk-elektronik.de>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05image: push default arch values to arch headersMike Frysinger
This pushes the ugly duplicated arch ifdef lists we maintain in various image related files out to the arch headers themselves. Acked-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> Tested-by: Thomas Chou <thomas@wytron.com.tw> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-10-05console: Implement pre-console bufferGraeme Russ
Allow redirection of console output prior to console initialisation to a temporary buffer. To enable this functionality, the board (or arch) must define: - CONFIG_PRE_CONSOLE_BUFFER - Enable pre-console buffer - CONFIG_PRE_CON_BUF_ADDR - Base address of pre-console buffer - CONFIG_PRE_CON_BUF_SZ - Size of pre-console buffer (in bytes) The pre-console buffer will buffer the last CONFIG_PRE_CON_BUF_SZ bytes Any earlier characters are silently dropped.
2011-08-01Unify timer_init() and cpu_init() prototypesWolfgang Denk
Clean up some duplicated prototype declarations. Get rid of now useless AVR32 initcalls.h file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Graeme Russ <graeme.russ@gmail.com>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-07-26Timer: Remove reset_timer() for non-Nios2 archesGraeme Russ
2011-07-26Timer: Remove set_timer completelyGraeme Russ
2011-05-18avr32: add ATAG_BOARDINFOAndreas Bießmann
This patch adds a new ATAG_BORADINFO to U-Boot. This tag is intended to hand over the bd->bi_board_number to the linux kernel for early stage board information like a board revision or other kind of board specific decisions necessary before the linux peripherial drivers are up. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: use single linker scriptAndreas Bießmann
This patch move the atstk100x linker script to $(CPUDIR) and delete other pure copies of this file in each board directory. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32/config.mk: simplify PLATFORM_RELFLAGSAndreas Bießmann
This patch removes PLATFORM_RELFLAGS from board specific config.mk files and define them in arch specific config.mk file. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-05-18avr32: fix linkingAndreas Bießmann
This patch fixes following error: ---8<--- avr32-linux-ld: --gc-sections and -r may not be used together --->8--- Since 8aba9dceebb14144e07d19593111ee3a999c37fc all avr32 boards are broken due to linking error as seen above. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
