path: root/arch/avr32/lib
2017-07-06avr32: Retire AVR32 for goodAndy Shevchenko
AVR32 is gone. It's already more than two years for no support in Buildroot, even longer there is no support in GCC (last version is heavily patched 4.2.4). Linux kernel v4.12 got rid of it (and v4.11 didn't build successfully). There is no good point to keep this support in U-Boot either. Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Andy Shevchenko <andriy.shevchenko@linux.intel.com>
2016-05-02Change my mailaddressAndreas Bießmann
I'll switch my mails to my own server, so drop all gmail references. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-06-10avr32: delete ancient board.cAndreas Bießmann
2015-04-18net: Remove the bd* parameter from net stack functionsJoe Hershberger
This value is not used by the network stack and is available in the global data, so stop passing it around. For the one legacy function that still expects it (init op on old Ethernet drivers) pass in the global pointer version directly to avoid changing that interface. Signed-off-by: Joe Hershberger <joe.hershberger@ni.com> Reported-by: Simon Glass <sjg@chromium.org> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Simon Glass <sjg@chromium.org> (Trival fix to remove an unneeded variable declaration in 4xx_enet.c)
2015-02-17avr32: add generic board supportAndreas Bießmann
2015-02-17avr32: use generic gd->start_addr_spAndreas Bießmann
Before avr32 had an extra storage for stack end to have a nice stack printout on exception. Remove this extra storage and use generic gd->start_addr_sp instead. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-17avr32: convert to dram_init()Andreas Bießmann
Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2015-02-17avr32: factor out cpu_mmc_init()Andreas Bießmann
cpu_mmc_init() is required by the init sequence to have a working MMC interface on avr32. This will not be included in the binary if we omit the avr32 board.c when building the generic board. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2015-02-17avr32: rename cpu_init() -> arch_cpu_init()Andreas Bießmann
2015-02-17avr32: use dlmalloc for DMA buffersAndreas Bießmann
2014-06-14avr32: migrate cache functionsAndreas Bießmann
Unfortunately the avr32 cache implementation has another API than the one described in common.h. Migrate the flush/invalidate dcache functions to the common API to be usable in device drivers. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Josh Wu <josh.wu@atmel.com>
2014-05-12bd_info: remove bi_barudrate member from struct bd_infoMasahiro Yamada
gd->bd->bi_baudrate is a copy of gd->baudrate. Since baudrate is a common feature for all architectures, keep gd->baudrate only. It is true that bi_baudrate was passed to the kernel in that structure but it was a long time ago. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Tom Rini <trini@ti.com> Cc: Simon Glass <sjg@chromium.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de> Acked-by: Michal Simek <monstr@monstr.eu> (For microblaze)
2013-10-31avr32: convert makefiles to Kbuild styleMasahiro Yamada
Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Andreas Bießmann <andreas.devel@googlemail.com>
2013-07-16Build arch/$ARCH/lib/bootm.o depending on CONFIG_CMD_BOOTMDirk Eibach
MAKEALL is fine for ppc4xx and mpc85xx. Run checks were done on our controlcenterd hardware. Signed-off-by: Dirk Eibach <dirk.eibach@gdsys.cc> Signed-off-by: Andy Fleming <afleming@freescale.com>
2013-07-02avr32/m68k/microblaze/nds32/nios2/openrisc/sh/sparc: fix do_bootm_linuxAndreas Bießmann
Commit 35fc84fa1ff51e15ecd3e464dac87eb105ffed30 broke bootm on avr32. It requires to call do_bootm_linux() with flag set to BOOTM_STATE_OS_PREP before calling it again with flag set to BOOTM_STATE_OS_GO. Fix this by allowing flag set to BOOTM_STATE_OS_PREP, this however will require a complete refactoring later on. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> [trini: Apply to m68k, microblaze, nds32, nios2, openrisc, sh and sparc] Signed-off-by: Tom Rini <trini@ti.com>
2013-05-13avr32: fix relocation address calculationAndreas Bießmann
Commit 1865286466a5d0c7f2e3c37632da56556c838e9e (Introduce generic link section.h symbol files) changed the __bss_end symbol type from char[] to ulong. This led to wrong relocation parameters which ended up in a not working u-boot. Unfortunately this is not clear to see cause due to RAM aliasing we may get a 'half-working' u-boot then. Fix this by dereferencing the __bss_end symbol where needed. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-05-01lib: consolidate hang()Andreas Bießmann
Delete all occurrences of hang() and provide a generic function. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> [trini: Modify check around puts() in hang.c slightly] Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15avr32: Fix cast warning in board.cSimon Glass
The frame buffer pointer in global_data is not a pointer, so we should remove these casts. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Andreas Bießmann <andreas.devel@googlemail.com>
2013-03-15Introduce generic link section.h symbol filesSimon Glass
We create a separate header file for link symbols defined by the link scripts. It is helpful to have these all in one place and try to make them common across architectures. Since Linux already has a similar file, we bring this in even though many of the symbols there are not relevant to us. Each architecture has its own asm/sections.h where symbols specifc to that architecture can be added. For now everything except AVR32 just includes the generic header. One change is needed in arch/avr32/lib/board.c to make this conversion work. Reviewed-by: Tom Rini <trini@ti.com> (version 5) Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-19malloc: make malloc_bin_reloc staticGabor Juhos
On architectures where manual relocation is needed, the 'malloc_bin_reloc' function must be called after 'mem_malloc_init'. Make the 'malloc_bin_reloc' function static and call it directly from 'mem_malloc_init' instead of calling that from board_init_{r,f} functions of the affected architectures. Signed-off-by: Gabor Juhos <juhosg@openwrt.org> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
2013-02-04avr32: Move cpu_hz to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-02-04avr32: Move stack_end to arch_global_dataSimon Glass
2012-10-22common: Convert the U-Boot commands to LG-arraysMarek Vasut
This patch converts the old method of creating a list of command onto the new LG-arrays code. The old u_boot_cmd section is converted to new u_boot_list_cmd subsection and LG-array macros used as needed. Minor adjustments had to be made to the common code to work with the LG-array macros, mostly the fixup_cmdtable() calls are now passed the ll_entry_start and ll_entry_count instead of linker-generated symbols. The command.c had to be adjusted as well so it would use the newly introduced LG-array API instead of directly using linker-generated symbols. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-09-26malloc: remove extern declarations of malloc_bin_reloc() in board.c filesDaniel Schwierzeck
Declare malloc_bin_reloc() in malloc.h and remove all extern declarations in various board.c files to get rid of one checkpatch.pl warning. Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com> Cc: Wolfgang Denk <wd@denx.de> Cc: Andreas Bießmann <andreas.devel@gmail.com> Cc: Jason Jin <Jason.jin@freescale.com> Cc: Macpaul Lin <macpaul@andestech.com> Cc: Daniel Hellstrom <daniel@gaisler.com> Acked-by: Andreas Bießmann <andreas.devel@gmail.com>
2012-06-04avr32:board.c: fix compile warningAndreas Bießmann
This patch fixes following warning: ---8<--- board.c: In function 'board_init_r': board.c:257: warning: unused variable 's' --->8--- Patch de30122bb58fee7b0f94bcfabab595b6ad757336 missed to remove this variable too. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-05-15net: move bootfile init into eth_initializeMike Frysinger
All arches init this the same way, so move the logic into the core net code to avoid duplicating it everywhere else. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-05-15net: punt bd->bi_ip_addrMike Frysinger
This field gets read in one place (by "bdinfo"), and we can replace that with getenv("ipaddr"). After all, the bi_ip_addr field is kept up-to-date implicitly with the value of the ipaddr env var. Signed-off-by: Mike Frysinger <vapier@gentoo.org> Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
2012-03-18bootstage: Replace show_boot_progress/error() with bootstage_...()Simon Glass
These calls should not be made directly any more, since bootstage will call the show_boot_...() functions as needed. Signed-off-by: Simon Glass <sjg@chromium.org>
2012-03-18bootstage: Make use of BOOTSTAGE_ID_RUN_OS in show_boot_progress()Simon Glass
This changes the number 15 as used in boot_stage_progress() to use the new name provided for it. This is a separate patch because it touches so many files. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Mike Frysinger <vapier@gentoo.org>
2012-03-13ATMEL: remove old atmel_mci driverSven Schnelle
All boards are using the gen_atmel_mci driver now, so no need to carry the old driver around. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2012-03-13ATMEL: use generic mmc frameworkSven Schnelle
gen_atmel_mci works on AVR32 as well, so no need to use the legacy mmc driver. This also has the nice side effect of being able to use SDHC cards an those boards. Signed-off-by: Sven Schnelle <svens@stackframe.org> Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com>
2011-10-23avr32: Use getenv_ulong() in place of getenv(), strtoulSimon Glass
This changes the board code to use the new getenv_ulong() function. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-10-05net: drop !NET_MULTI codeMike Frysinger
This is long over due. All but two net drivers have been converted, but those have now been dropped. The only thing left to do is actually delete all references to NET_MULTI and code that is compiled when that is not defined. So here we scrub the core code. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-08-01Unify timer_init() and cpu_init() prototypesWolfgang Denk
Clean up some duplicated prototype declarations. Get rid of now useless AVR32 initcalls.h file. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Albert Aribaud <albert.aribaud@free.fr> Cc: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Cc: Graeme Russ <graeme.russ@gmail.com>
2011-07-28unify version_stringAndreas Bießmann
This patch removes the architecture specific implementation of version_string where possible. Some architectures use a special place and therefore we provide U_BOOT_VERSION_STRING definition and a common weak symbol version_string. Signed-off-by: Andreas Bießmann <andreas.devel@googlemail.com> CC: Mike Frysinger <vapier@gentoo.org> CC: Peter Pan <pppeterpppan@gmail.com> Acked-by: Mike Frysinger <vapier@gentoo.org>
2011-05-18avr32: add ATAG_BOARDINFOAndreas Bießmann
This patch adds a new ATAG_BORADINFO to U-Boot. This tag is intended to hand over the bd->bi_board_number to the linux kernel for early stage board information like a board revision or other kind of board specific decisions necessary before the linux peripherial drivers are up. Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2010-10-29Replace CONFIG_RELOC_FIXUP_WORKS by CONFIG_NEEDS_MANUAL_RELOCWolfgang Denk
By now, the majority of architectures have working relocation support, so the few remaining architectures have become exceptions. To make this more obvious, we make working relocation now the default case, and flag the remaining cases with CONFIG_NEEDS_MANUAL_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-19board_init_r: Removed unused cmdtp variableRichard Retanubun
Follow up to commit 620f1f6a64095ed558e68d37f1965d015cd49b02 removed compiler warning for (now) unused cmd_tbl_t* cmdtp
2010-09-19relocation: fixup cmdtableHeiko Schocher
fixup_cmdtable() did all work for fixing up the cmdtable, if CONFIG_RELOC_FIXUP_WORKS is not defined. CONFIG_RELOC_FIXUP_WORKS is missing for i386! I talked with Graeme Russ, and he will fix this soon. Portions of this work were supported by funding from the CE Linux Forum. Signed-off-by: Heiko Schocher <hs@denx.de>
2010-09-03avr32: Add simple paging supportHaavard Skinnemoen
Use the MMU hardware to set up 1:1 mappings between physical and virtual addresses. This allows us to bypass the cache when accessing the flash without having to do any physical-to-virtual address mapping in the CFI driver. The virtual memory mappings are defined at compile time through a sorted array of virtual memory range objects. When a TLB miss exception happens, the exception handler does a binary search through the array until it finds a matching entry and loads it into the TLB. The u-boot image itself is covered by a fixed TLB entry which is never replaced. This makes the 'saveenv' command work again on ATNGW100 and other boards using the CFI driver, hopefully without breaking any rules. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-06-29Fix (null) problem for AVR32 boardsReinhard Meyer (-VC)
Currently the U-Boot address ranges for AVR32 boards are printed like this: "U-Boot code: (null) -> 0001183c data: 000188e8 -> 0004e9b0" This patch fixes this to print: "U-Boot code: 00000000 -> 0001183c data: 000188f8 -> 0004e9c0" Signed-off-by: Reinhard Meyer <info@emk-elektronik.de>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
