path: root/arch/avr32/lib
2010-06-29Fix (null) problem for AVR32 boardsReinhard Meyer (-VC)
Currently the U-Boot address ranges for AVR32 boards are printed like this: "U-Boot code: (null) -> 0001183c data: 000188e8 -> 0004e9b0" This patch fixes this to print: "U-Boot code: 00000000 -> 0001183c data: 000188f8 -> 0004e9c0" Signed-off-by: Reinhard Meyer <info@emk-elektronik.de>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
