path: root/arch/avr32/cpu/cpu.c
2013-02-04avr32: Move cpu_hz to arch_global_dataSimon Glass
Move this field into arch_global_data and tidy up. Signed-off-by: Simon Glass <sjg@chromium.org>
2011-05-18avr32: rename memory-map.h -> hardware.hAndreas Bießmann
Signed-off-by: Andreas Bießmann <biessmann@corscience.de>
2010-04-13avr32: Move cpu/at32ap/* to arch/avr32/cpu/*Peter Tyser
