Synchronize R-Car Gen3 device trees with Linux 5.6.2,
commit 9fbe5c87eaa9b72db08425c52c373eb5f6537a0a .
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
Synchronize R-Car Gen2 device trees with Linux 5.6.2,
The Cubieboard is a single board computer containing a
Actions S700 SoC(with 4 ARMv8 Cortex-A53 cores).
This patch adds respective defconfig alongwith .dts(copied
from Linux v5.5-rc6 with hash "b3a987b0264d").
Signed-off-by: Amit Singh Tomar <amittomer25@gmail.com>
This patch moves some of the config options from bubblegum_96_defconfig
to respective Kconfig files.
This patch adds basic support for Actions Semi based S700
SoC, which is driven by common owl framework.
Reviewed-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Reviewed-by: Andre Przywara <andre.przywara@arm.com>
Devices like uart and clk are needed to be enabled before relocation.
this patch adds u-boot.dtsi file that mark these device as dm-pre-reloc.
This patch adds .dtsi file(sync with Linux 5.5-rc6 with hash "b3a987b0264d")
and required binding for S700 SoC that is a 64-bit Quad-core ARM
Cortex-A53 cores.
It also provisions dts file to be built based on selected
platform(CONFIG_MACH_S900/S700).
This patch converts S900 clock driver to something common that can
be used for other SoCs, for instance S700(few of clk registers are same).
This patch adds u-boot.dtsi file that mark these device as dm-pre-reloc.
Synchronize device tree bindings with v5.5-rc6 tag with commit id
"b3a987b0264d".
Also, it removes older clock binding defined for S900 along with undocumented
compatible string "actions,s900-serial" from serial driver and adapts clock
driver to cater to new bindings.
Now that memory maps(for both S700 and S900 SoCs) can be managed using
a common file, rename sysmap-s900 to sysmap-owl to reflect the same.
This commit adds common arch support for Actions Semi Owl
series SoCs and removes the Bubblegum96 board files.
Introduce arch_reserve_mmu to allow for architecture-specific reserve_mmu
routines. Also, define a weak nop stub for it.
Signed-off-by: Ovidiu Panait <ovpanait@gmail.com>
As a preparation for turning reserve_mmu into an arch-specific variant,
introduce arm_reserve_mmu on ARM. It implements the default routine for
reserving memory for MMU TLB and needs to be weakly defined in order to allow
for machines to override it.
Without this decoupling, after introducing arch_reserve_mmu, there would be two
weak definitions for it, one in common/board_f.c and one in
arch/arm/lib/cache.c.
Move the ARM-specific reserve_mmu definition from common/board_f.c
to arch/arm/lib/cache.c.
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- Solve stm32mp15 pinctrl dts issue (patch conflict in branches master and next)
- Split device tree for DHCOR Som and AV 96 board
- Update PLL4 setting in AV96 board
- Enable bootd, iminfo, imxtract on DHCOM
TARGET_QEMU_ARM_64BIT and TARGET_QEMU_ARM_32BIT should be mutually
exclusive.
The AV96 is in fact an assembly of DH Electronics DHCOR SoM on top
of an AV96 reference board. Split the DTs to reflect that and make
sure to DHCOR SoM can be reused on other boards easily.
It is also highly recommended to configure the board for the DHCOM
make stm32mp15_dhcom_basic_defconfig
make DEVICE_TREE=stm32mp15xx-dhcor-avenger96
as that permits reusing the board code for the DH components, like
accessing and reading out the ethernet MAC from EEPROM.
Cc: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org>
Cc: Patrice Chotard <patrice.chotard@st.com>
Change-Id: I7db47280d4eb0d668eb4e006355240271154f97f
The PLL4 is supplying SDMMC12, SDMMC3 and SPDIF with 120 MHz and
FDCAN with 96 MHz. This isn't good for the SDMMC interfaces, which
can not easily divide the clock down to e.g. 50 MHz for high speed
SD and eMMC devices, so those devices end up running at 30 MHz as
that is 120 MHz / 4. Adjust the PLL4 settings such that both PLL4P
and PLL4R run at 100 MHz instead, which is easy to divide to 50MHz
for optimal operation of both SD and eMMC, SPDIF clock are not that
much slower and FDCAN is also unaffected.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
Remove the unnecessary file stm32mp157-pinctrl.dtsi and
solve all issues introduced by the commit 891483186052b2598 ("Merge branch
'next'") after a conflict on the patch applied in the next branch in
commit 1a4f57c895cc ("ARM: dts: stm32mp1: DT alignment with Linux 5.6-rc1")
Need to reapplied on stm32mp15-pinctrl.dtsi the the 3 patches
applied previously on file "stm32mp157-pinctrl.dtsi" in v2020.04
- commit 4fdbe6487daa ("ARM: dts: stm32: Add alternate pinmux for SDMMC1
direction pins")'
- commit 5fdcba64027f ("ARM: dts: stm32: Add alternate pinmux for SDMMC2
pins 4-7")'
- commit 955de5111112 ("ARM: dts: stm32: Add alternate pinmux for ethernet
RGMII")'
- mvebu bubt cmd: Add A38x support (Joel)
- Clearfog: Fix SCSI boot duplication (Joel)
- Armada-37xx: Fix DDR PHY clock divider values (Marek)
- iproc_sdhci memory leak fix and enable R1B resp quirk
- more mmc cmds and several mmc updates from Heinirich
- Use bounce buffer for tmio sdhci
- Alignment check for tmio sdhci
This function is only relevant to the MMC driver so calling it
spl_boot_partition() might be confusing. Rename it to
spl_mmc_boot_partition() to make its purpose more clear (and bring
it in line with spl_mmc_boot_mode()).
Signed-off-by: Harald Seiler <hws@denx.de>
The function's name is misleading as one might think it is used
generally to select the boot-mode when in reality it is only used by the
MMC driver to find out in what way it should try reading U-Boot Proper
from a device (either using a filesystem, a raw sector/partition, or an
eMMC boot partition).
Rename it to spl_mmc_boot_mode() to make it more obvious what this
function is about.
Link: https://lists.denx.de/pipermail/u-boot/2020-April/405979.html
Update mvebu SPL boot selection mechanism for the move to driver model
usage by ensuring that the required driver support for SPI and MMC
booting is available in SPL when the respective boot method is
selected.
Previously, all mvebu boards selected a boot method (implicitly
MVEBU_SPL_BOOT_DEVICE_SPI for many) even if SPL booting wasn't used.
This changes mvebu boot method selection to depend on SPL usage which
resolves the issue with aarch64 boards which don't use SPL getting an
implicit boot device selection resulting in unmet dependencies. The
32-bit arm boards do use SPL, but I'm led to conclude that most aren't
intentionally using the MVEBU_SPL_BOOT_DEVICE selection since none have
SPL_DM_SPI enabled in their defconfig even though they still implicitly
select the SPI boot method.
This also results in the new addition of SPL_GPIO_SUPPORT to helios4.
The mainline dts for helios4 includes the cd-gpios entry for sdhci with
identical addresses as the clearfog dts. I don't have a helios4 board
to confirm, but based on the current source conclude that the board
itself is either wired to pull the signal low for eMMC, or the default
MMC boot isn't fully functional in mainline. In either case, as far as
I can tell, including the GPIO support will at least cause no
regression.
Tested on SolidRun ClearFog devices.
Signed-off-by: Joel Johnson <mrjoel@lixil.net>
- Backplane support and bug fixes
- Further cleanups for 'make refcheckdocs'
- Another BTRFS fix.
- Support for automatic decompression of images with booti as well as
unlz4 command for manual decompression.
https://gitlab.denx.de/u-boot/custodians/u-boot-amlogic
- enable DM_RNG on meson boards
- fix SMBIOS info on Odroid-C2
- Fix video output on GXBB/GXL/GXM boards
- add USB gadget support for GXL/GXM boards
https://gitlab.denx.de/u-boot/custodians/u-boot-ti
- Fix boot on am335x guardian board
- Increase OPSI speed on AM65x and J721E devices
- Use JTAD register for identifying K3 devices.
- Update TI entry in MAINTAINERS file.
Add the USB DWC2 node to u-boot specific dtsi files since Gadget
support is not (yet) available in upstream Linux yet.
Signed-off-by: Neil Armstrong <narmstrong@baylibre.com>
Add arch code to initialize USB Gadget mode using the DWC2 controller,
and using the previously added set_mode() phy functions.
[narmstrong: fixup board_usb_cleanup call to phy_meson_gxl_usb2_set_mode]
Add set_mode function in the Amlogic GXL PHYs that will be called by
the arch code to switch PHYs from/to gadget mode.
Add generic support for backplane kr modes currently available:
10gbase-kr, 40gbase-kr4. Remove platform generic fixups
(armv8/layerscape and powerpc) for ethernet interfaces specified
in device tree as supported backplane modes.
Signed-off-by: Florinel Iordache <florinel.iordache@nxp.com>
Reviewed-by: Priyanka Jain <priyanka.jain@nxp.com>
This patch is to define esdhc_status_fixup function for ls1028a to disable
SDHC1/SDHC2 status in device tree node if not selected.
Signed-off-by: Yinbo Zhu <yinbo.zhu@nxp.com>
Signed-off-by: Xiaowei Bao <xiaowei.bao@nxp.com>
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
JTAG ID register is defined by IEEE 1149.1 for device identification.
Use this JTAG ID register for identifying AM65x[0] and J721E[1] devices
instead of using SoC specific registers.
[0] http://www.ti.com/lit/ug/spruid7e/spruid7e.pdf
[1] http://www.ti.com/lit/ug/spruil1a/spruil1a.pdf
Reported-by: Grygorii Strashko <grygorii.strashko@ti.com>
Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Add dtsi file for i.MXRT1020.
Those two boards are supposed to be run with a single u-boot binary.
There are notable differences though - HSC uses DSA switch (which
phy_id == 0x0) and DCC (DP83848C).
After the commit 3bf135b6c367
("drivers: net: phy: Ignore PHY ID 0 during PHY probing") the PHY devices
with phy_id == 0 are not created in U-Boot anymore. This caused regression
on HSC.
To fix this problem - the fec's 'fixed-link' node has been introduced and
the phy_id is not assessed anymore. This approach works on both boards.
Signed-off-by: Lukasz Majewski <lukma@denx.de>
During the conversion of this board to DM_REGULATOR, usb-mass-storage
was broken and started failing with the following error:
=> ums 0 mmc 2
UMS: LUN 0, dev 2, hwpart 0, sector 0x0, count 0xe90000
Error enabling VBUS supply
g_dnl_register: failed!, error: -38
g_dnl_register failed
Fix this by adding the relevant GPIO to the regulator node.
Fixes: 4ca99fe81aea ("ARM: imx: dh-imx6: Enable DM regulator")
Use DM_ETH instead of legacy networking. Add VIO as a fixed regulator
to the relevant device-trees and augment the FEC node with properties
for the reset GPIO.
It should be noted that the relevant properties for the reset GPIO
already exist in the PHY node (reset-gpios, reset-delay-us,
reset-post-delay-us) but U-Boot currently ignores those and only
supports the bus-level reset properties in the FEC node
(phy-reset-gpios, phy-reset-duration, phy-reset-post-delay).
The detection of the revD1 version is based on the presence of the PMIC.
Currently revb1 device trees are used for mx6q/mx6dl variants, which
do not have the PMIC nodes.
This causes revD1 boards to be incorrectly be detected as revB1.
Fix this issue by using the revd1 device trees, so that the PMIC node can be
found and then the PMIC can be detected by reading its register ID.
Imported the revd1 device trees from mainline kernel version 5.7-rc1.
Reported-by: Heiko Schocher <hs@denx.de>
Reported-by: Derek Atkins <derek@ihtfp.com>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Derek Atkins <derek@ihtfp.com>
Tested-by: Heiko Schocher <hs@denx.de>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Add lcdif node and its pinctrl.
Reviewed-by: Anatolij Gustschin <agust@denx.de>
Linux doesn't provide skeleton.dtsi file so let's remove its include and
provide #address-cells/size-cells = <1> that were defined in
skeleton.dtsi before.
Add lcdif node to SoC.
Add support for i.MXRT by adding CONFIG_IMXRT in register structure and
adding .compatible = "fsl,imxrt-lcdif".
Signed-off-by: Michael Krummsdorf <michael.krummsdorf@ew.tq-group.com>
The device trees for TQMa6x SOM support variations in
- CPU type: imx6dl- or imx6q-
- MBa6 I2C bus access: -mba6a (i2c1) or -mba6b (i2c3)
(plus the respective common/module include trees)
- USBH1 is directly connected to a hub
- USBOTG is connected to a separate connector
and can act as host/device or full OTG port.
The i.MX6DP and i.MX6QP incorporate NoC interconnect logic
which needs to be configured in order to use external DDR memory.
This patch enables the SPL to configure the necessary registers
in accordance with the NXP engineering bulletin EB828.
Co-developed-by: Filip Brozović <fbrozovic@gmail.com>
Signed-off-by: Bernhard Messerklinger <bernhard.messerklinger@br-automation.com>
Signed-off-by: Filip Brozovic <fbrozovic@gmail.com>
