This board still doesn't select CONFIG_DM and seems to be umaintained.
As it makes progress on modernizing several DaVinci drivers more
difficult and the maintainer has not expressed interest in updating
it, this patch proposes to remove it.
Signed-off-by: Bartosz Golaszewski <bgolaszewski@baylibre.com>
- Gen3 PCIe driver + enablement on Salvator-X platforms.
- Gen3 recovery SPL used to reload ATF/OpTee/U-Boot instead of minimon.
- SDHI HS400 fixes ported from latest BSP and datasheet.
- SoCFPGA PL310 cleanup + A10 fix, A10 DT cleanup, DW GPIO fix.
Finding bitstream from cff-file is no longer valid after bitstream is built
into FIT image and loaded by generic firmware loader. Remove cff-file
as this is legacy implementation from A10 downstream.
Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com>
On SoCFPGA A10 systems, it can rarely happen that a reboot from Linux
will result in stale data in PL310 L2 cache controller. Even if the L2
cache controller is disabled via the CTRL register CTRL_EN bit, those
data can interfere with operation of devices using DMA, like e.g. the
DWMMC controller. This can in turn cause e.g. SPL to fail reading data
from SD/MMC.
The obvious solution here would be to fully reset the L2 cache controller
via the reset manager MPUMODRST L2 bit, however this causes bus hang even
if executed entirely from L1 I-cache to avoid generating any bus traffic
through the L2 cache controller.
This patch thus configures and enables the L2 cache controller very early
in the SPL boot process, clears the L2 cache and disables the L2 cache
controller again.
The reason for doing it in SPL is because we need to avoid accessing any
of the potentially stale data in the L2 cache, and we are certain any of
the stale data will be below the OCRAM address range. To further reduce
bus traffic during the L2 cache invalidation, we enable L1 I-cache and
run the invalidation code entirely out of the L1 I-cache.
Cc: Chin Liang See <chin.liang.see@intel.com>
Cc: Dalon Westergreen <dwesterg@gmail.com>
Cc: Dinh Nguyen <dinguyen@kernel.org>
Cc: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
Cc: Tien Fong Chee <tien.fong.chee@intel.com>
Pull the PL310 clearing code into common code, so it can be reused
by Arria10.
Manage power supply configuration for board using stpmic1
with LPDDR2 or with LPDDR3:
+ VDD_DDR1 = 1.8V with BUCK3 (bypass if possible)
+ VDD_DDR2 = 1.2V with BUCK2
Update DDR configuration with the latest update:
- PUBL_regs: DXnGCR[0]= according to ddr_width to disable Byte
lane 2/3 in 16bit
- fix LPDDR2/3 timing_calc to step RL/WL in relaxed
timings mode
- remove LPDDR3 RL3 (optional) support vs MR0[7]
because MR0[7] can't be read instead always apply
worse RL/WL for LPDDR3 when freq < 166MHz)
- change MR3 to 48ohm drive for LPDDR2/3
- change default ZPROG[7:4] = 0x1 for LPDDR2/3 ,
'0' is not allowed even when ODT not used
- use DQSTRN for LPDDR2/3 (it was not set in PIR)
- LPDDR3: set dqsge/dwsgx gate extension to 2,2
like LPDDR2
-DDRCTRL.dfitmg0:
+ for LPDDR3 tphy_wrlat = WL (as LPDDR2)
+ improvement for relaxed mode vs RL/Wl at corner case.
For example @533MHz RL/WL (relaxed) = 9/5 for LPDDR2/3
and correction to MR2 accordingly
- DDR_PCFGQOS1_1: port1 timeout relaxed from 0x00 to 0x40,
for LTDC.
- DDR_PCFGWQOS0_0: change vpr level from
11 to 12 in order to include the CPU on
the variable priority queue.
- DDR_SCHED: fix to consider 13 levels (13 levels - 1 = 0xC)
Allow fractional support in DDR tools.
Add the needed configurations for bootstage and
activate bootstage command.
BOOTSTAGE_REPORT is not activated by default.
In initf_bootstage() we call bootstage_mark_name() which ends up calling
timer_get_us() before timer_init(); that cause crash for stm32mp1.
This patch solve the issue without changing the initialization sequence.
See also commit 97d20f69f53e ("Enable CONFIG_TIMER_EARLY with bootstage")
for other solution when DM is activated for TIMER.
Activate bootcount and use TAMP register to store the count value.
Use SGI0 interruption and TAMP_BACKUP_MAGIC_NUMBER
to synchronize the core1 boot sequence requested by
core0 in psci_cpu_on():
- a initial interruption is needed in ROM code after
RCC_MP_GRSTCSETR_MPUP1RST (psci_cpu_off)
- the ROM code set to 0 the 2 registers
+ TAMP_BACKUP_BRANCH_ADDRESS
+ TAMP_BACKUP_MAGIC_NUMBER
when magic is not egual to
BOOT_API_A7_CORE0_MAGIC_NUMBER
This patch solve issue for cpu1 restart in kernel.
echo 0 > /sys/devices/system/cpu/cpu1/online
echo 1 > /sys/devices/system/cpu/cpu1/online
Reorder the include files in alphabetic order.
Use Kconfig to activate CONFIG_PREBOOT (empty by default).
Add arch stm32mp for ENV migration step and drop more
items from include/configs/xxx.h.
This patch moves the the config SYS_MALLOC_LEN to
Kconfig as it is already done for zynq arch in
commit 01aa5b8f0503 ("Kconfig: Move config
SYS_MALLOC_LEN to Kconfig for zynq")
Signed-off-by: Zhao Qiang <qiang.zhao@nxp.com>
Reviewed-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
ENVL_NOWHERE is dependent on CONFIG_ENV_IS_NOWHERE and not on
CONFIG_CHAIN_OF_TRUST so return ENVL_NOWHERE when CONFIG_ENV_IS_NOWHERE
is enabled
Signed-off-by: Udit Agarwal <udit.agarwal@nxp.com>
Move the ecc addr from driver to dts.
Signed-off-by: Peng Ma <peng.ma@nxp.com>
LS1028AQDS Development System is a high-performance
computing, evaluation, and development platform that supports
LS1028A QorIQ Architecture processor.
Signed-off-by: Sudhanshu Gupta <sudhanshu.gupta@nxp.com>
Signed-off-by: Rai Harninder <harninder.rai@nxp.com>
Signed-off-by: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Signed-off-by: Bhaskar Upadhaya <Bhaskar.Upadhaya@nxp.com>
Signed-off-by: Tang yuantian <andy.tang@nxp.com>
Signed-off-by: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
LS1028A is an ARMv8 implementation. LS1028ARDB is an evaluation
platform that supports the LS1028A family SoCs. This patch add basic
support of the platform.
Signed-off-by: Tang Yuantian <andy.tang@nxp.com>
Ls1028a SoC is based on Layerscape Chassis Generation 3.2
architecture with features:
2 ARM v8 Cortex-A72 cores, CCI400, SEC, DDR3L/4, LCD, GPU, TSN
ENETC, 2 USB 3.0, 2 eSDHC, 2 FlexCAN, 2 SPI, SATA, 8 I2C controllers,
6 LPUARTs, GPIO, SAI, qDMA, eDMA, GIC, TMU etc.
The LX2160A integrated 6 PCIe Gen4 controllers.
Signed-off-by: Hou Zhiqiang <Zhiqiang.Hou@nxp.com>
The LX2160A PCIe is using driver PCIE_LAYERSCAPE_GEN4 instead
of PCIE_LAYERSCAPE.
The lx2160a have up to 6 PCIe controllers and have different
address and size of PCIe region.
The LS2080A has 8GB region for each PCIe controller, while the
other platforms have 32GB.
Change to use PCIe address macro to determine if precompile the PCIe
MMU table entry.
Build an SPL which can be started via SCIF download mode on R-Car Gen3
and allows loading and executing U-Boot uImage with the next stage code.
This is also useful for starting e.g. ATF BL2, which inits the hardware
and returns to the U-Boot SPL, which can then load e.g. U-Boot proper.
The H3, M3-W, M3-N SoCs have plenty of SRAM for storing the U-Boot SPL
while the payload, e.g. ATF BL2, executes, so there is no problem here.
However, E3 and D3 have much less SRAM, hence the loader uses a trick
where it copies itself beyond the area used by BL2 and executes from
there. That area is 32kiB large and not enough to hold U-Boot SPL, BSS,
stack and malloc area, so the later two are placed at +0x4000 offset
from start of SRAM, another area not used by ATF BL2. To make things
even more complicated, the SCIF loader cannot load to the upper 32kiB
of the SRAM directly, hence the copying approach.
Signed-off-by: Marek Vasut <marek.vasut+renesas@gmail.com>
Cc: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
- update for using splashfile instead of location->name
when loading the splash image from a FIT
- updates for loading internal and external splash data from FIT
- DM_GPIO/DM_VIDEO migration for mx53 cx9020 board
- fix boot issue on mx6sabresd board after DM_VIDEO migration
- increase the max preallocated framebuffer BPP to 32 in ipuv3
driver to prepare for configurations with higher color depth
- allow to use vidconsole_put_string() in board code for text
output on LCD displays
- H6 WDT reset fix (Clément)
- H6 SPL_TEXT_BASE fixes (Clément, Jonas)
- NPI-M1+ emac enablment (Emmanuel)
Some H6 boards have a watchdog which didn't make the SoC
reboot properly.
Reason is still unknown but several people have test it.
Chen-Yu Tsai :
Pine H64 = H6 V200-AWIN H6448BA 7782 => OK
OrangePi Lite 2 = H6 V200-AWIN H8068BA 61C2 => KO
Martin Ayotte :
Pine H64 = H8069BA 6892 => OK
OrangePi 3 = HA047BA 69W2 => KO
OrangePi One Plus = H7310BA 6842 => KO
OrangePi Lite2 = H6448BA 6662 => KO
Clément Péron:
Beelink GS1 = H6 V200-AWIN H7309BA 6842 => KO
After the series of result, Icenowy try to reach Allwinner about this
issue but they seems not interested to investigate it.
As we don't have the ARIS coproc to do power management and watchdogis
the only solution to reset the board.
So, Change from watchdog to R_watchdog to allow a reboot on all H6
boards.
Signed-off-by: Clément Péron <peron.clem@gmail.com>
Reviewed-by: Jagan Teki <jagan@amarulasolutions.com>
Meet the following boot hang.
U-Boot SPL 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800)
Trying to boot from MMC1
U-Boot 2019.04-00661-gdc80a012e4 (Apr 25 2019 - 10:31:57 +0800)
CPU: Freescale i.MX6Q rev1.5 996 MHz (running at 792 MHz)
CPU: Automotive temperature grade (-40C to 125C)Reset cause: POR
Model: Freescale i.MX6 Quad SABRE Smart Device Board
Board: MX6-SabreSD
I2C: ready
DRAM: 1 GiB
Video device 'ipu@2400000' cannot allocate frame buffer memory -ensure the device is set up before relocation
Error binding driver 'ipuv3_video': -28
Video device 'ipu@2800000' cannot allocate frame buffer memory -ensure the device is set up before relocation
Some drivers failed to bind
Error binding driver 'generic_simple_bus': -28
initcall sequence 4ffe4500 failed at call 1780dfb7 (err=-28)
1. fdtdec_get_alias_seq will use "video" as base, however in alias node,
we use ipux, so add new alias for U-Boot dts.
2. DM_VIDEO is enabled, however reserve_video is called before
relocation, so to make DM_VIDEO work before relocation, need to
set SYS_MALLOC_F_LEN
3. defconfig is updated with savedefconfig
Note: I do not have a video panel to test, but with this patch, U-Boot
boots up again, below log.
U-Boot SPL 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800)
U-Boot 2019.04-00662-g0b62453bff (Apr 25 2019 - 10:36:31 +0800)
CPU: Automotive temperature grade (-40C to 125C) at 34C
Reset cause: POR
Board: MX6-SabreSD
I2C: ready
DRAM: 1 GiB
PMIC: PFUZE100 ID=0x10
MMC: FSL_SDHC: 0, FSL_SDHC: 1, FSL_SDHC: 3
Loading Environment from MMC... *** Warning - bad CRC, using default environment
PCI: pcie phy link never came up
In: serial
Out: serial
Err: serial
Net: FEC [PRIME]
Hit any key to stop autoboot: 0
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Anatolij Gustschin <agust@denx.de>
The ipu node in imx53 is needed for DM_VIDEO. We also need to set
u-boot,dm-pre-reloc to initialize before relocation.
Signed-off-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Without this U-Boot specific property, booting on Armada XP theadorable
fails in SPL. All nodes in the "internal-regs" (simple-bus) DT node are
not scanned, so the UART node is missing (and others).
I'm not adding this property in an *u-boot.dtsi file, since there is
none matching the generic rules for all files including this dtsi
file. So to not miss any of the boards using this dtsi file, I'm
adding it to this file directly, which makes the Linux merge a less
easy unforunately.
Cc: Chris Packham <judge.packham@gmail.com>
Cc: Marek Behún <marek.behun@nic.cz>
Reviewed-by: Chris Packham <judge.packham@gmail.com>
Instead of using the watchdog, let's use PSCI to perform the reset
of the SoC.
Signed-off-by: Fabien Parent <fparent@baylibre.com>
The watchdog should use a clock at 50 Mhz, so
instead of using the clock osc (200 Mhz), we
define a reference clock at 50Mhz and use it
for both watchdog.
Signed-off-by: Philippe Reynes <philippe.reynes@softathome.com>
for both watchdog.
While converting CONFIG_SYS_[DI]CACHE_OFF to Kconfig, there are instances
where these configuration items are conditional on SPL. This commit adds SPL
variants of these configuration items, uses CONFIG_IS_ENABLED(), and updates
the configurations as required.
Acked-by: Alexey Brodkin <abrodkin@synopsys.com>
Signed-off-by: Trevor Woerner <trevor@toganlabs.com>
[trini: Make the default depend on the setting for full U-Boot, update
more zynq hardware]
CONFIG_SYS_[DI]CACHE_OFF had been partially converted to Kconfig
parameters; only for the ARC architecture. This patch turns these two
parameters into Kconfig items everywhere else they are found.
All of the include/configs/* and defconfig changes in this patch are
for arm machines only. The Kconfig changes for arc, nds32, riscv,
and xtensa have been included since these symbols are found in code
under arch/{arc,nds32,riscv,xtensa}, however, no currently-defined
include/configs/* or defconfigs for these architectures exist which
include these symbols.
These results have been confirmed with tools/moveconfig.py.
Acked-by: Alexey Brodkin <abrodkin@snopsys.com>
[trini: Re-migrate for a few more boards]
According to De Morgan's Law[1]:
!(A && B) = !A || !B
!(A || B) = !A && !B
There are 5 places in the code where we find:
#if !(defined(CONFIG_SYS_ICACHE_OFF) && defined(CONFIG_SYS_DCACHE_OFF))
and 4 places in the code where we find:
#if (!defined(CONFIG_SYS_ICACHE_OFF) || !defined(CONFIG_SYS_DCACHE_OFF))
In words, the construct:
!defined(CONFIG_SYS_[DI]CACHE_OFF)
means:
"is the [DI]CACHE on?"
and the construct:
means:
"is the [DI]CACHE off?"
Therefore
means:
"the opposite of 'are they both off?'"
in other words:
"are either or both on?"
and:
means:
As a result, I've converted the 4 instances of '(!A || !B)' to '!(A && B)' for
consistency.
[1] https://en.wikipedia.org/wiki/De_Morgan%27s_laws
- SoCFPGA DT and reset cleanup, AE MCVEVK board support.
STM32 MCUs update:
_ Add MPU region for SPI NOR memory mapped region
_ Add missing QSPI flash compatible for STM32 F7 boards
_ Update spi-tx-bus-width and spi-rx-bus-width properties
_ Add QSPI support for STM32F469 Discovery board
Keep the FPGA bridge entries in SPL DT to let do_bridge_reset() toggle
the bridges on/off as needed according to the handoff file.
Pull out the u-boot,dm-pre-reloc from socfpga_arria10_socdk_sdmmc_handoff.dtsi
into separate dtsi header file to make it easier to patch in custom handoff
dtsi files, without having to manually add the U-Boot bits. Shuffle the include
clauses in the A10 DT files to make it obvious what gets included where without
having to follow confusing long chain of includes, i.e. board DT file includes
everything it needs.
Re-add support for Aries Embedded MCV SoM, which is CycloneV based
and the associated MCVEVK and MCVEVP baseboard. The board can boot
from eMMC. Ethernet and USB is supported.
The Aries Embedded boards have been removed with commit 03b54997d568
("board/aries: Remove"). I will now take care of them.
The device-tree files are from mainline Linux commit e93c9c99a629
("Linux v5.1)".
Signed-off-by: Wolfgang Grandegger <wg@aries-embedded.de>
CC: Marek Vasut <marex@denx.de>
CC: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
The stratix 10 reset manager ad-hoc code in arch/arm contains an unused
function 'reset_deassert_peripherals_handoff' that has been added from
the beginning. As this is probably a result of copying the gen5 reset
manager and this function has never been used, remove it.
Signed-off-by: Simon Goldschmidt <simon.k.r.goldschmidt@gmail.com>
commit c5de2b7eae68 ("arm: socfpga: implement proper peripheral reset")
has removed the call to 'reset_deassert_peripherals_handoff()' from
socfpga gen5 SPL since the reset driver now handles resets. However,
commit c1d4b464c8b8 ("ARM: socfpga: Disable bridges in SPL unless booting from FPGA")
has re-added this ad-hoc reset code, so that all peripherals were now
again enabled instead of letting the drivers enable them by request.
While at it, remove this function for gen5 as it should not be used.
Fixes: commit c1d4b464c8b8 ("ARM: socfpga: Disable bridges in SPL unless booting from FPGA")
Add support for loading FPGA bitstream to get DDR up running before
U-Boot is loaded into DDR. Boot device initialization, generic firmware
loader and SPL FAT support are required for this whole mechanism to work.
