colibri-imx6ull ethernet device is fec2, while the optional secondary
ethernet is fec1, update the ethernet aliases in the .dts file so that
ethaddr is set to fec2 and eth1addr to fec1.
Without this change the ethernet interfaces have a different
mac address between Linux and U-Boot.
Signed-off-by: Francesco Dolcini <francesco.dolcini@toradex.com>
Add code to build the eMMC variant of the Colibri iMX6ULL, i.e. the
'Colibri iMX6ULL 1GB' which has a eMMC instead of the raw NAND used
on other SKUs.
Related-to: ELB-4056, ELB-4057
Since NXPs 5.4. release zeros are needed at the end of the bootloader.
Assume that never more than 10k of padding is needed and skip the
shell magic to get a correct size.
The recovery image needs to support both Colibri-iMX7 NAND and
Colibri-iMX7 eMMC modules. Forward port the solution for this
from u-boot 2016.11, originally developed by
Stefan Agner <stefan.agner@toradex.com>.
Related-to: TEI-775
Signed-off-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
OF graph endpoint connections must be bidirectional and dtc warn if they
are not. i.MX7 based DTs have an error and generate
warnings:
arch/arm/dts/imx7d-sdb.dtb: Warning (graph_endpoint):
/replicator/ports/port@0/endpoint: graph connection to node
'/soc/tpiu@30087000/port/endpoint' is not bidirectional
/soc/tpiu@30087000/port/endpoint: graph connection to node
'/replicator/ports/port@1/endpoint' is not bidirectional
Signed-off-by: Ilko Iliev <iliev@ronetix.at>
NAND modules (Colibri Vybrid, iMX7, iMX6ULL) require the images with
1024 prepending bytes.
Add the u-boot-nand.imx target which enables with CONFIG_IMX_NAND
option.
Related-to: TEI-775
imx-bootaux loads an elf file linked for an auxilary core. Thus the
loader function requires address translation from the auxilary core's
address space to where those are mapped into U-Boot's address space.
So the elf loader is specific and must not be replaced with a generic
loader which doesn't provide the address translation functionality.
Fixes commit 805b3cac1e0 ("lib: elf: Move the generic elf
loading/validating functions to lib")
Related-to: ELB-3520
Rename EEPROM nodes.
Create aliases for EEPROM to unify their order:
eeprom0 - on-module EEPROM
eeprom1 - carrier-board EEPROM
eeprom2 - MIPI-DSI to HDMI adapter EEPROM
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
According to i.MX 7Solo Applications Processor Reference Manual,
2.1.3 Cortex-M4 Memory Map, M4 can address only 1536MB of DDRC
(Start Address: 0x8000_0000; End Address: 0xDFFF_FFFF).
Correct DDRC size to 0x60000000.
Fixes: c0f037f6("mach-imx: bootaux: elf firmware support")
1. Move u-boot specific nodes to u-boot dts include: legacy lcdif
node and aliases.
2. Add iomux configuration for LCD.
3. Drop un-needed u-boot,dm-pre-reloc for alias node.
4. Fix display-timings, use the one from Toradex downstream kernel [1]
[1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx7-colibri-eval-v3.dtsi?h=toradex_4.9-2.3.x-imx#n206
1. Move aliases and legacy lcdif node to the u-boot specific dts include.
2. Provide proper display timings, as in the downstream Toradex kernel
[1].
[1]: https://git.toradex.com/cgit/linux-toradex.git/tree/arch/arm/boot/dts/imx6ull-colibri-eval-v3.dtsi?h=toradex_4.9-2.3.x-imx#n183
https://gitlab.denx.de/u-boot/custodians/u-boot-rockchip
- rk3188 cpu init and APLL fix;
- rk3399: Add BOOTENV_SF command;
- rk3288 correct vop0 vop1 setting;
Move the setting for noc remap out of SPL code. Changing
noc remap inside SPL results in breaking back to BROM
boot.
Fixes commit c14fe2a8e192 ("rockchip: rk3188: Move SoC
one time setting into arch_cpu_init()").
Signed-off-by: Alexander Kochetkov <al.kochet@gmail.com>
Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
Fix EMAC register address calculation, address need to multiply
with sizeof(u32) or 4.
This fixes write to invalid address.
Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
Since commit:
commit 6333cbb3817ed551cd7d4e92f7359c73ccc567fc
Author: Michael Walle <michael@walle.cc>
Date: Thu May 7 00:11:58 2020 +0200
phy: atheros: ar8035: remove static clock config
We can configure the clock output in the device tree. Disable the
hardcoded one in here. This is highly board-specific and should have
never been enabled in the PHY driver.
If bisecting shows that this commit breaks your board it probably
depends on the clock output of your Atheros AR8035 PHY. Please have a
look at doc/device-tree-bindings/net/phy/atheros.txt. You need to set
"clk-out-frequency = <125000000>" because that value was the hardcoded
value until this commit.
Signed-off-by: Michael Walle <michael@walle.cc>
, the clock output setting for the AR803x driver is removed from being
hardcoded in the PHY driver and should be passed via device tree instead.
Update the device tree with the "qca,clk-out-frequency" property so that
Ethernet can work again.
Reported-by: Soeren Moch <smoch@web.de>
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Tested-by: Soeren Moch <smoch@web.de>
Signed-off-by: Walter Lozano <walter.lozano@collabora.com>
Current aliases missed gpio0 node, and this node shoud be
aliased to gpio index 0 to align with i.MX8QXP. Otherwise, we
will get below message when running "gpio status" command, and
see the reason by "dm uclass".
=> gpio status
Device 'gpio@5d090000': seq 0 is in use by 'gpio@5d080000'
Device 'gpio@5d0a0000': seq 1 is in use by 'gpio@5d090000'
Device 'gpio@5d0b0000': seq 2 is in use by 'gpio@5d0a0000'
=> dm uclass
uclass 36: gpio
0 * gpio@5d080000 @ fbaefb90, seq 0, (req -1)
1 * gpio@5d090000 @ fbaefc70, seq 1, (req 0)
2 * gpio@5d0a0000 @ fbaefd50, seq 2, (req 1)
3 * gpio@5d0b0000 @ fbaefe30, seq 5, (req 2)
4 * gpio@5d0c0000 @ fbaeff10, seq 3, (req 3)
5 * gpio@5d0d0000 @ fbaefff0, seq 4, (req 4)
6 * gpio@5d0e0000 @ fbaf00d0, seq 6, (req 5)
7 * gpio@5d0f0000 @ fbaf01b0, seq 7, (req 6)
Signed-off-by: Ye Li <ye.li@nxp.com>
Select default U-Boot and SPL text base for the MX7 SoC. The U-Boot
text base is picked as the one used by various MX7 boards. The SPL
text base however is different.
The SPL text base is set to 0x912000 instead of the usual 0x911000,
that is because the 0x911000 value cannot work. Using 0x911000 as a
SPL text base will result in the DCD header being placed below the
0x911000 address, which is a reserved SRAM area which must not be
used. This will actually trigger eMMC boot failure on MX7D at least.
Hence the increment.
Update all boards affected by this SPL problem to the new SPL_TEXT_BASE.
Cc: Fabio Estevam <festevam@gmail.com>
Cc: NXP i.MX U-Boot Team <uboot-imx@nxp.com>
Cc: Peng Fan <peng.fan@nxp.com>
There are systems where board_early_init_f() is plain empty. Switch
the config option from "select" to "imply", to permit user to unset
the BOARD_EARLY_INIT_F if it were to be empty.
The iMX7 defines further DDRC ZQCTLx registers, however those were
thus far missing from the list of registers and not programmed. On
systems with LPDDR2 or DDR3, those registers must be programmed with
correct values, otherwise the DRAM may not work. However, existing
systems which worked without programming these registers before are
now setting those registers to 0, which is the default value, so no
functional change there.
As per kernel commit 0672d22a1924 ("ARM: dts: imx: Fix the AR803X phy-mode)
the correct phy-mode should be "rgmii-id", so fix it accordingly
to fix the Ethernet regression.
This problem has been exposed by commit:
commit 13114f38e2ccea9386726d8b9831dfc310589548
Author: Vladimir Oltean <vladimir.oltean@nxp.com>
Date: Thu May 7 00:11:51 2020 +0200
phy: atheros: Explicitly disable RGMII delays
To eliminate any doubts about the out-of-reset value of the PHY, that
the driver previously relied on.
If bisecting shows that this commit breaks your board you probably have
a wrong PHY interface mode. You probably want the
PHY_INTERFACE_MODE_RGMII_RXID or PHY_INTERFACE_MODE_RGMII_ID mode.
Signed-off-by: Vladimir Oltean <vladimir.oltean@nxp.com>
Fix the phy-mode accordingly to fix the regression.
Sync the device tree with 5.8-rc1.
It basically contains the following extra kernel commit:
commit 86b08bd5b99480b79a25343f24c1b8c4ddcb5c09
Author: Russell King <rmk+kernel@armlinux.org.uk>
Date: Wed Apr 15 16:44:17 2020 +0100
ARM: dts: imx6-sr-som: add ethernet PHY configuration
Add ethernet PHY configuration ahead of removing the quirk that
configures the clocking mode for the PHY. The RGMII delay is
already set correctly.
Signed-off-by: Russell King <rmk+kernel@armlinux.org.uk>
Reviewed-by: Fabio Estevam <festevam@gmail.com>
, which passes the 'qca,clk-out-frequency' property and it is important
to specify the correct frequency generated by the AR8035.
Tested-by: Tom Rini <trini@konsulko.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-stm
- fix SD card cart detect on DHCOM and ST boards
The cd-gpios with (GPIO_ACTIVE_LOW | GPIO_PULL_UP) gpio is thus far
unsupported, reinstate the old cd-gpios behavior until this handling
is fully implemented. This avoid potential issue for SDCard boot:
the card detect fails with floating gpio.
Reviewed-by: Patrice Chotard <patrice.chotard@st.com>
is fully implemented. This permits the DHSOM to boot from SD again,
without this patch the card detect fails.
Cc: Patrice Chotard <patrice.chotard@st.com>
Reviewed-by: Patrick Delaunay <patrick.delaunay@st.com>
The PSCI nodes are currently not populated for the Tegra210 and Tegra186
devices. This prevents the PSCI driver from being able to identify the
PSCI method used by these devices and causes the probe of the PSCI
driver to fail.
Since commit 81ea00838c68 ("efi_loader: PSCI reset and shutdown") was
added, which moves the PSCI EFI system reset handler into the PSCI
driver, this has prevented the EFI system reset from working for
Tegra210 and Tegra186. Therefore, populating these nodes is necessary
to fix the EFI system reset for Tegra210 and Tegra186.
Signed-off-by: Jon Hunter <jonathanh@nvidia.com>
Tested-by: Peter Robinson <pbrobinson@gmail.com>
Add OP-TEE firmware node in stm32mp15 U-Boot DTSI. This node is
needed since commit [1] that changed U-Boot/stm32mp15 to detect
OP-TEE availability by probing the resource instead of relying on
U-Boot configuration. The software sequence implemented by [1] is
fine but U-Boot DTS/DTSI files were not updated accordingly since,
hence OP-TEE presence is never detected by U-Boot, preventing Linux
kernel from using OP-TEE resources.
For consistency and to synchronize stm32mp15 DTSI files (excluding
U-Boot specific DTSI files) with the Linux kernel ones, this change
also moves the OP-TEE reserved memory nodes from board generic DTSI
files to U-Boot specific board DTSI files.
Link: [1] commit 43df0a159df6 ("stm32mp1: dynamically detect op-tee presence")
Signed-off-by: Etienne Carriere <etienne.carriere@linaro.org>
Fix the sequence in stm32mp1 fdt.c that disables OP-TEE resources
defined in FDT when U-boot detects OP-TEE firmware is not present.
Before this change, helper function stm32_fdt_disable_optee()
set property status to "disabled" for the OP-TEE reserved memory
nodes but this has no impact since Linux kernel does not consider
the status property for reserved-memory subnodes. This change
make U-Boot to attempt to delete the node instead.
Fixes: 4a1b975dac02 ("board: stm32mp1: reserve memory for OP-TEE in device tree")
- fsl_esdhc sdr104 and hs200 fix and error path fix
- fsl_esdhc workaround 3.3v io issue
- ca_dw_mmc cleanup
- presidio-asic emmc DT update.
Change DT compatibility name to match change in driver's name.
Remove unused io_ds and fifo_mode fields from DT.
Signed-off-by: Alex Nemirovsky <alex.nemirovsky@cortina-access.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Tom Rini <trini@konsulko.com>
- cyclone5 bugfix
Commit e71b6f6622d6 ("i2c: designware_i2c: Rewrite timing calculation")
change the hcnt and lcnt timing calculation. New timing calculation is
based on calculation from Designware i2c databook.
After this new timing calculation, hcnt will have negative value
with i2c-scl-falling-time-ns 5000 that set in socfpga_cyclone5_socdk.dts.
This patch overwrite i2c-scl-falling-time-ns to 300ns (default SCL fall
time used in Designware i2c driver) for Uboot.
Before the fix:
=> i2c dev 0
Setting bus to 0
Failure changing bus number (-22)
After the fix:
=> i2c dev 0
Setting bus to 0
=> i2c probe
Valid chip addresses: 17 51 55 5B 5C 5E 66 68 70
OF_CONTROL, DM_SPI and other driver model migration deadlines
are expired for this board.
Remove it.
Acked-by: Lars Poeschel <poeschel@lemonage.de>
Signed-off-by: Jagan Teki <jagan@amarulasolutions.com>
Remove it.
Acked-by: Grazvydas Ignotas <notasas@gmail.com>
https://gitlab.denx.de/u-boot/custodians/u-boot-imx
Fixes for 2020.07
- mx53: mx53menlo Convert to DM_ETH, fix fail boot
- imx8mp_evk: fix boot issue
- MX6, display5: fix environment
- drop warnings (watchdog) for i.MX8mm i.mx8mp
- enable bootaux for i.MX8M
Travis: https://travis-ci.org/github/sbabic/u-boot-imx/builds/695929999
This reverts commit 1f63ee656698724bcdc4e711b4ccd267f6bf64ab.
As reported by Ye Li on ML:
1. Removing the image_offset will break secondary (redundant) boot support for sd and emmc.
2. When booting from emmc boot partition, the image_offset is 0. But the flash.bin
generated by mkimage with imximage-8mp-lpddr4.cfg is for sd. It expects to be burn at 32KB offset.
The fit offset 0x60000 has already included the 32KB offset. So when you burn this flash.bin
to emmc boot partition at offset 0, the fit offset should subtract the 32KB (0x60000 - 0x8000).
Convert the board to DM_ETH instead of legacy networking. This requires
a minor addition to the DT to satisfy the requirement for specifying a
PHY node. No functional change from board user perspective.
The iMX7D RM 9.2.4.9.3 Power removal flow Table 9-11. Re-enabling power
explicitly says both the DDR controller and the PHY must be reset in the
correct sequence. Currently the code only resets the controller. This
leads to a misbehavior where the system brings the DRAM up after reboot,
but the DRAM is unstable. Add the missing reset.
The easiest way to trigger this is by triggering WDT without having the
WDT assert WDOG_B signal, i.e. mw.w 0x30280000 0x25 .
When not booting from FlexSPI, the offset computation is:
offset = image_offset + CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_SECTOR * 512 - 0x8000;
When booting from SD card or eMMC user partition, image_offset is
0x8000. It is useless to add and remove 0x8000.
When booting from other device, image_offset is 0 so this computation is wrong.
Simplfy this computation to work on all booting devices.
Signed-off-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
With yModem the FIT Image is only supplied once, so we can only
seek forward in the yModem supplied image and never backwards.
With the recent changes to the SPL mechanism, including loading
U-Boot first, FDT after, then the loadables, we must also reorder
the FIT image script to make sure that the loadables are last in
the FIT image.
Signed-off-by: Patrick Wildt <patrick@blueri.se>
Tested-by: Sébastien Szymanski <sebastien.szymanski@armadeus.com>
i.MX8M could use imx bootaux to boot m4/m7 core, so let's add it
to the dependency list.
Signed-off-by: Peng Fan <peng.fan@nxp.com>
Accidentally submitted a patch with indentation not correct, let's fix it
by indenting wrong lines.
Signed-off-by: Giulio Benetti <giulio.benetti@benettiengineering.com>
Acked-by: Peng Fan <peng.fan@nxp.com>
So far the puma dts files only just included the main puma dtsi without
handling the actual baseboard and rk3399-puma.dtsi was very much
detached from the variant in the mainline Linux kernel.
Recent changes resulted in a strange situation with nonworking puma boards.
Commit ab800e5a6f28 ("arm: dts: rockchip: puma: move U-Boot specific bits to u-boot.dtsi")
moved the sdram include from rk3399-puma-ddrX.dts to new files
rk3399-puma-ddrx-u-boot.dtsi which were never included anywhere though.
Commit 167efc2c7a46 ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux")
replaced the rk3399-puma.dtsi nearly completely, but in the kernel
it definitly depends on a baseboard dts to actually enable peripherals
like sd-slot, uarts, etc.
So to untagle this and bring the whole thing more in line with mainline
Linux, bring the rk3399-puma-haikou.dts over as well, drop the separate
DDR-option devicetrees and instead replace them with a puma Kconfig option
to select and include the needed DDR variant.
Signed-off-by: Heiko Stuebner <heiko.stuebner@theobroma-systems.com>
Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
Tabs not spaces, so transform it to the common styling.
The regulator enable-gpio uses opposite values for the declaration
vs. the enable_active_low property, breaking the regulator enablement.
Make the usbhost-supply work again by bringing them in sync again.
This mimics the upstream Linux change found on:
http://lore.kernel.org/r/20200604091239.424318-1-heiko@sntech.de
The gmac reset has opposite values for the gpio declaration
and the separate reset-active, bring this in line to make
u-boot also find the ethernet-phy.
This mimics the upstream Linux commit found on
https://lore.kernel.org/r/20200603132836.362519-1-heiko@sntech.de
U-Boot TPL 2020.07-rc3-00121-gab88251130 (Jun 03 2020 - 16:43:42)
Channel 0: LPDDR4, 50MHz
BW=32 Col=10 Bk=8 CS0 Row=16/15 CS=1 Die BW=16 Size=2048MB
Channel 1: LPDDR4, 50MHz
256B stride
256B stride
lpddr4_set_rate: change freq to 400000000 mhz 0, 1
lpddr4_set_rate: change freq to 800000000 mhz 1, 0
Trying to boot from BOOTROM
Returning to boot ROM...
U-Boot SPL 2020.07-rc3-00121-gab88251130 (Jun 03 2020 - 16:43:42 +0200)
Trying to boot from SPI
U-Boot 2020.07-rc3-00121-gab88251130 (Jun 03 2020 - 16:43:42 +0200)
SoC: Rockchip rk3399
Reset cause: RST
Model: Pine64 RockPro64 v2.1
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe310000: 2, mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected gd25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
*** Warning - bad CRC, using default environment
In: serial
Out: vidconsole
Err: vidconsole
Net: eth0: ethernet@fe300000
Hit any key to stop autoboot: 0
Signed-off-by: Marcin Juszkiewicz <marcin@juszkiewicz.com.pl>
U-Boot TPL 2020.07-rc3-00090-gd4e919f927-dirty (Jun 01 2020 - 23:45:53)
BW=32 Col=10 Bk=8 CS0 Row=15 CS1 Row=15 CS=2 Die BW=16 Size=2048MB
256B stride
256B stride
U-Boot SPL 2020.07-rc3-00087-ga21e9fd385 (Jun 02 2020 - 00:09:45 +0530)
Trying to boot from MMC1
NOTICE: BL31: v2.2(release):
NOTICE: BL31: Built : 15:05:37, May 12 2020
U-Boot 2020.07-rc3-00087-ga21e9fd385 (Jun 02 2020 - 00:09:45 +0530)
Reset cause: POR
Model: Firefly ROC-RK3399-PC Board
DRAM: 3.9 GiB
PMIC: RK808
MMC: mmc@fe320000: 1, sdhci@fe330000: 0
Loading Environment from SPI Flash... SF: Detected w25q128 with page size 256 Bytes, erase size 4 KiB, total 16 MiB
In: serial
Out: serial
Err: serial
The 'stdout-path' is missing after dts sync.
Fixes: 167efc2c7a ("arm64: dts: rk3399: Sync v5.7-rc1 from Linux")
Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
