path: root/arch/arm
2017-05-08Merge branch 'master' of git://git.denx.de/u-boot-sunxiTom Rini
2017-05-08ARM: keystone2: Add support for getting external clock dynamicallyLokesh Vutla
One some keystone2 platforms like K2G ICE, there is an option to switch between 24MHz or 25MHz as sysclk. But the existing driver assumes it is always 24MHz. Add support for getting all reference clocks dynamically by reading boot pins. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08ARM: k2g: Add support for dynamic programming of PLL based on SYSCLKLokesh Vutla
K2G supports various sysclk frequencies which can be determined using sysboot pins. PLLs should be configured based on this sysclock frequency. Add PLL configurations for all supported sysclk frequencies. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08Add ARM errata workaround 852421 and 852423 for Cortex-A17Nisal Menuka
ARM errata 852421 and 852423 applies to r1p0, r1p1 and r1p2 revisions of Cortex-A17 processors. These workarounds exist in Linux kernel and I thought it would be better to add them in to U-Boot. Signed-off-by: Nisal Menuka <nisalmenuka23@gmail.com>
2017-05-08aspeed: Cleanup ast2500-u-boot.dtsi Device Treemaxims@google.com
Remove unnecessary apb and ahb nodes and just override necessary nodes/values. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor SCU to use consistent mask & shiftmaxims@google.com
Refactor SCU header to use consistent Mask & Shift values. Now, consistently, to read value from SCU register, mask needs to be applied before shift. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Add support for Clocks needed by MACsmaxims@google.com
Add support for clocks needed by MACs to ast2500 clock driver. The clocks are D2-PLL, which is used by both MACs and PCLK_MAC1 and PCLK_MAC2 for MAC1 and MAC2 respectively. The rate of D2-PLL is hardcoded to 250MHz -- the value used in Aspeed SDK. It is not entirely clear from the datasheet how this clock is used by MACs, so not clear if the rate would ever need to be different. So, for now, hardcoding it is probably safer. The rate of PCLK_MAC{1,2} is chosen based on MAC speed selected through hardware strapping. So, the network driver would only need to enable these clocks, no need to configure the rate. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Add P-Bus clock in ast2500 clock drivermaxims@google.com
Add P-Bus Clock support to ast2500 clock driver. This is the clock used by I2C devices. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: AST2500 Pinctrl Drivermaxims@google.com
This driver uses Generic Pinctrl framework and is compatible with the Linux driver for ast2500: it uses the same device tree configuration. Not all pins are supported by the driver at the moment, so it actually compatible with ast2400. In general, however, there are differences that in the future would be easier to maintain separately. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Refactor AST2500 RAM Driver and Sysreset Drivermaxims@google.com
This change switches all existing users of ast2500 Watchdog to Driver Model based Watchdog driver. To perform system reset Sysreset Driver uses first Watchdog device found via uclass_first_device call. Since the system is going to be reset anyway it does not make much difference which watchdog is used. Instead of using Watchdog to reset itself, SDRAM driver now uses Reset driver to do that. These were the only users of the old Watchdog API, so that API is removed. This all is done in one change to avoid having to maintain dual API for watchdog in between. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Device Tree configuration for Reset Drivermaxims@google.com
Add Reset Driver configuration to ast2500 SoC Device Tree and bindings for various reset signals Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Reset Drivermaxims@google.com
Add Reset Driver for ast2500 SoC. This driver uses Watchdog Timer to perform resets and thus depends on it. The actual Watchdog device used needs to be configured in Device Tree using "aspeed,wdt" property, which must be WDT phandle, for example: rst: reset-controller { compatible = "aspeed,ast2500-reset"; aspeed,wdt = <&wdt1>; } Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Make SCU lock/unlock functions part of SCU APImaxims@google.com
Make functions for locking and unlocking SCU part of SCU API. Many drivers need to modify settings in SCU and thus need to unlock it first. This change makes it possible. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Watchdog Timer Drivermaxims@google.com
This driver supports ast2500 and ast2400 SoCs. Only ast2500 supports reset_mask and thus the option of resettting individual peripherals using WDT. Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08aspeed: Update ast2500 Device Treemaxims@google.com
Pull in the Device Tree for ast2500 from the mainline Linux kernel. The file is copied from https://raw.githubusercontent.com/torvalds/linux/34ea5c9d/arch/arm/boot/dts/aspeed-g5.dtsi Signed-off-by: Maxim Sloyko <maxims@google.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08ARM: DT: STM32F746: add u-boot, dm-pre-reloc property to sub nodesVikas Manocha
This patch is required for correct SPL device tree creation by fdtgrep as fdtgrep looks for u-boot,dm-pre-reloc property of the node to include it in the spl device tree. Not adding it in these subnodes ignores the pin muxing of peripherals which is almost always in the subnodes. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-08igep003x: Add support for IGEP SMARC AM335xPau Pajuelo
The IGEP SMARC AM335x is an industrial processor module with following highlights: o AM3352 TI processor (Up to AM3359) o Cortex-A8 ARM CPU o SMARC form factor module o Up to 512 MB DDR3 SDRAM / 512 MB FLASH o WiFi a/b/g/n and Bluetooth v4.0 on-board o Ethernet 10/100/1000 Mbps and 10/100 Mbps controller on-board o JTAG debug connector available o Designed for industrial range purposes Signed-off-by: Pau Pajuelo <ppajuelo@iseebcn.com> Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Pau Pajuelo <ppajuel@gmail.com>
2017-05-08igep0033: Rename to igep003xLadislav Michl
Rename igep0033 to igep003x as IGEP SMARC AM335x module (igep0034) can use the same source files. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Pau Pajuelo <ppajuel@gmail.com>
2017-05-08ARM: am33xx: define BOOT_DEVICE_ONENANDLadislav Michl
am33xx does not support OneNAND, but we need this define anyway to let UBI SPL code compile. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Tested-by: Pau Pajuelo <ppajuel@gmail.com>
2017-05-08ARM: am33xx: fix typo in spl.hLadislav Michl
2017-05-08stm32f7: add support for stm32f769 disco boardVikas Manocha
This board support stm32f7 family device stm32f769-I with 2MB internal Flash & 512KB RAM. STM32F769 lines offer the performance of the Cortex-M7 core (with double precision floating point unit) running up to 216 MHz. To compile for stm32f769 board, use same defconfig as stm32f746-disco, the only difference is to pass "DEVICE_TREE=stm32f769-disco". Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: move board specific pin muxing to dtsVikas Manocha
2017-05-08stm32f7: sdram: correct sdram configuration as per micron sdramVikas Manocha
Actually the sdram memory on stm32f746 discovery board is micron part MT48LC_4M32_B2B5_6A. This patch does the modification required in the device tree node & driver for the same. Also we are passing here all the timing parameters in terms of clock cycles, so no need to convert time(ns or ms) to cycles. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f746: to switch on user LED1 & read user buttonVikas Manocha
All discovery boards have one user button & one user LED. Here we are just reading the button status & switching ON the user LED. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: use stm32f7 gpio driver supporting driver modelVikas Manocha
With this gpio driver supporting DM, there is no need to enable clocks for different gpios (for pin muxing) in the board specific code. Need to increase the allocatable area required before relocation from 0x400 to 0xC00 becuase of 10 new gpio devices(& new gpio class) added in device tree. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-05-08ARM: DT: stm32f7: add gpio device tree nodesVikas Manocha
Also created alias for gpios for stm32f7 discovery board. Based on these aliases, it would be possible to get gpio devices by sequence. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08dm: gpio: Add driver for stm32f7 gpio controllerVikas Manocha
This patch adds gpio driver supporting driver model for stm32f7 gpio. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> Reviewed-by: Simon Glass <sjg@chromium.org> Cc: Christophe KERELLO <christophe.kerello@st.com> [trini: Add depends on STM32] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-08stm32f7: sdram: use sdram device tree node to configure sdram controllerVikas Manocha
2017-05-08stm32f7: use clock driver to enable sdram controller clockVikas Manocha
This patch also removes the sdram/fmc clock enable from board specific code. Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08ARM: DT: stm32f7: add sdram pin contol nodeVikas Manocha
Also added DT binding doc for stm32 fmc(flexible memory controller). Signed-off-by: Vikas Manocha <vikas.manocha@st.com> cc: Christophe KERELLO <christophe.kerello@st.com>
2017-05-08stm32f7: use clock driver to enable qspi controller clockVikas Manocha
2017-05-08spl: make image arg or fdt blob address reconfigurableVikas Manocha
At present fdt blob or argument address being passed to kernel is fixed at compile time using macro CONFIG_SYS_SPL_ARGS_ADDR. FDT blob from different media like nand, nor flash are copied to the address pointed by the macro. The problem is, it makes args/fdt blob compulsory to copy which is not required in cases like for NOR Flash. This patch removes this limitation. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2017-05-08arm: dra7xx: move CONFIG_DRA7XX to KconfigUri Mashiach
The symbol CONFIG_DRA7XX is needed for Kconfig conditions. Cc: Lokesh Vutla <lokeshvutla@ti.com> Signed-off-by: Uri Mashiach <uri.mashiach@compulab.co.il> Reviewed-by: Tom Rini <trini@konsulko.com>
2017-05-05arm64: mvebu: incorrect check of fdt address cellsxypron.glpk@gmx.de
In dram_init_banksize there seems to be a typo concerning a plausibility check of the fdt. Testing sc > 2 twice does not make any sense. The problem was indicated by cppcheck. Signed-off-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
2017-05-02sunxi: add clock configuration of R40 sataIcenowy Zheng
R40 has a similar SATA controller with the ones on A10/A20, but with a reset line added (like other peripherals on sun6i+), and two extra VDD pins added (1.2v and 2.5v). Add clock configuration of R40 SATA. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-02ARM: sunxi: use imply instead of bare default y in KconfigMasahiro Yamada
Fix annoying config redefines in SoC/board level Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-02ARM: sunxi: move board/sunxi/Kconfig to arch/arm/mach-sunxi/KconfigMasahiro Yamada
For the consistent location of SoC-level Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-01fdt: Move fdt_fixup_ethernet to a common placeTom Rini
With 3f66149d9fb4 we no longer have a common call fdt_fixup_ethernet. This was fine to do on PowerPC as they largely had calls already in ft_cpu_fixup. On ARM however we largely relied on this call. Rather than introduce a large number of changes to ft_cpu_fixup / ft_board_fixup we recognize that this is a common enough call that we should be doing it in a central location. Do it early enough that we can do any further updates in ft_cpu_fixup / ft_board_fixup. Cc: Gerd Hoffmann <kraxel@redhat.com> Cc: Chen-Yu Tsai <wens@csie.org> Cc: Maxime Ripard <maxime.ripard@free-electrons.com> Cc: Thomas Chou <thomas@wytron.com.tw> (maintainer:NIOS) Cc: York Sun <york.sun@nxp.com> (maintainer:POWERPC MPC85XX) Cc: Stefan Roese <sr@denx.de> (maintainer:POWERPC PPC4XX) Cc: Simon Glass <sjg@chromium.org> Cc: Joakim Tjernlund <Joakim.Tjernlund@infinera.com> Fixes: 3f66149d9fb4 ("Remove extra fdt_fixup_ethernet() call") Signed-off-by: Tom Rini <trini@konsulko.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: York Sun <york.sun@nxp.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-04-30Convert CONFIG_CMD_DIAG to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DIAG Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_DIAG on some keymile configs] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_DEKBLOB to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_DEKBLOB Note: This option does not seem to actually be enabled by any board. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply under SECURE_BOOT for mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Kconfig: Add a separate option for FS_CRAMFSSimon Glass
Rather than using CMD_CRAMFS for both the filesystem and its command, we should have a separate option for each. This allows us to enable CRAMFS support without the command, if desired, which reduces U-Boot's size slightly. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply FS_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30fs: Convert CONFIG_CMD_CRAMFS to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CRAMFS Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CRAMFS for keymile] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_CLK to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_CLK Signed-off-by: Simon Glass <sjg@chromium.org> [trini: imply CMD_CLK on ARCH_ZYNQ] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_BMODE to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BMODE Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Make this default y and depend on mx5/6/7] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30Convert CONFIG_CMD_BLOB to KconfigSimon Glass
This converts the following to Kconfig: CONFIG_CMD_BLOB Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Add imply CMD_BLOB under CHAIN_OF_TRUST] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-30power: Rename CONFIG_AS3722_POWER to CONFIG_PMIC_AS3722Simon Glass
Before converting this to Kconfig, rename it to match the other PMICs. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-30arm: Re-sync ARCH_MX5 / MX51 / MX53 CONFIG optionsTom Rini
A few boards had not been fully re-synced with CONFIG_ARCH_MX5 / CONFIG_MX51 / CONFIG_MX53 being in Kconfig. Do so now. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-28sunxi: video: Add A64/H3/H5 HDMI driverJernej Skrabec
This commit adds support for HDMI output. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-28sunxi: i2c: Add support for DM I2CJernej Skrabec
This commit adds support for DM I2C on sunxi platform. It can coexist with old style sunxi I2C driver, because it is still used in SPL and by some SoCs. Because sunxi platform doesn't yet support DM clk, reset and pinctrl driver, workaround is needed to enable clocks and set resets and pinctrls. This is done by calling i2c_init_board() in board_init(). This means that CONFIG_I2Cx_ENABLE options needs to be correctly set in order to use needed I2C controller. Commit is based on the previous patch made by Philipp Tomsich Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-27Merge tag 'xilinx-fixes-for-v2017.05' of git://www.denx.de/git/u-boot-microblazeTom Rini
Xilinx fixes for v2017.05 - Fix usbotg on Miami board - Cleanup zc1751 defconfig
