path: root/arch/arm
2016-08-26sun6i: Add defconfig and dts file for tablets using the inet-q972 PCBHans de Goede
Add a defconfig and dts file for tablets using the generic inet-q972 PCB. Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host, micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot, (mini) power-barrel and an usb wifi module. This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet. The dts files are identical to the ones submitted to the upstream kernel. Signed-off-by: Hans de Goede <hdegoede@redhat.com> Acked-by: Ian Campbell <ijc@hellion.org.uk>
2016-08-26Merge branch 'master' of git://www.denx.de/git/u-boot-marvellTom Rini
2016-08-26arm: mvebu: a38x: typo fix cpabilities -> capbilitiesChris Packham
Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-08-26arm: mvebu: a38x: update serdes error handlingChris Packham
Ensure appropriate error messages are generated. Previously all errors indicated that the serdes was already in use. Now appropriate error messages are given. Signed-off-by: Chris Packham <judge.packham@gmail.com> Signed-off-by: Stefan Roese <sr@denx.de>
2016-08-26arm: mvebu: Add support for NAND interface on A-38xChris Packham
The NAND interface on the Armada-38x series is similar to that on the Armada-XP. The key difference is that the NAND ECC clock ratio is provided via the DFX Server registers instead of the Core Clock. Signed-off-by: Chris Packham <chris.packham@alliedtelesis.co.nz> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <eibach@gdsys.de> Signed-off-by: Stefan Roese <sr@denx.de>
2016-08-25ARM: tegra: remove stale nvidia, bpmp I2C DT propertyStephen Warren
The nvidia,bpmp property is left over from an old BPMP I2C binding, and shouldn't be present. Remove it from the SoC DT file, and update the I2C driver not to parse it; the value wasn't used for anything any more anyway. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-25ARM: tegra: fix Tegra186 SDHCI clock/reset namesStephen Warren
The Tegra SDHCI binding dictates that the reseet name for the Tegra SDHCI clock be "sdhci" not "sdmmc", and that the clock is accessed by index rather than by name. Fix the Tegra186 DT and MMC driver to honor this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-25ARM: tegra: fix Tegra186 I2C clock nameStephen Warren
The Tegra I2C binding dictates that the clock name for the Tegra I2C clock be "div-clk" not "i2c". Fix the Tegra186 DT and I2C driver to honor this. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-20Merge branch 'rmobile' of git://git.denx.de/u-boot-shTom Rini
[trini: Drop CMD_BOOTI as it's now on by default on ARM64] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-20ARM: OMAP4+: vcores: Remove duplicated codeLokesh Vutla
There is no reason to duplicate code for DRA7xx platforms as there can be Rail grouping. The maximum voltage detection algorithm can still be run on other platforms with no Rail grouping and does not harm as it gives the same result. Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-20ARM: OMAP5+: vcores: Drop unnecessary #ifndefsLokesh Vutla
gpio_en field is introduced to detect if pmic is controlled by GPIO. Make this field 0 on all TPS659* pmics available on DRA7/OMAP5 based platforms and remove the #ifndefs. Reviewed-by: Keerthy <j-keerthy@ti.com> Signed-off-by: Lokesh Vutla <lokeshvutla@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-20cmd: Split 'bootz' and 'booti' out from 'bootm'Tom Rini
The bootz and booti commands rely on common functionality that is found in common/bootm.c and common/bootm_os.c. They do not however rely on the rest of cmd/bootm.c to be implemented so split them into their own files. Have various Makefiles include the required infrastructure for CONFIG_CMD_BOOT[IZ] as well as CONFIG_CMD_BOOTM. Move the declaration of 'images' over to common/bootm.c. Cc: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2016-08-17ARM: rmobile: r8a7795: Add MMU layoutNobuhiro Iwamatsu
This add MMU layout for R8A7795 of Renesas ARM64 SoC. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Add BLANCHE board supportmasakazu.mochizuki.wd@hitachi.com
BLANCHE is development board based on R-Car V2H SoC (R8A7792) This commit supports the following periherals: - SCIF, Ethernet, QSPI, MMC Signed-off-by: Masakazu Mochizuki <masakazu.mochizuki.wd@hitachi.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support salvator-x boardNobuhiro Iwamatsu
Salvator-x is an entry level development board based on R-Car H3 SoC (R8A7795). This commit supports SCIF only. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support R8A7795Nobuhiro Iwamatsu
Renesas R8A7795 is CPU with Cortex-a57. This supports the basic register definition and GPIO and framework of PFC. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support R-Car Generation 3Nobuhiro Iwamatsu
This adds supporting R-Car Generation 3 (Gen3) as Renesas ARM64 SoC. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Create R-Car 32bit (Gen1 and Gen2) for KconfigNobuhiro Iwamatsu
This creates Kconfig of R-Car 32bit for Kconfig of R-Car 64bit (Gen3). Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2016-08-17ARM: rmobile: Move SoC headers to mach-rmobile/include/machNobuhiro Iwamatsu
Move form arch/arm/include/asm/arch-rmobile/ to arch/arm/mach-rmobile/include/mach/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Move SoC sources to mach-rmobileNobuhiro Iwamatsu
Move from arch/arm/cpu/armv7/rmobile/ to arch/arm/mach-rmobile/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-16ARM: dts: k2g-evm: enable mmc/sd suppportSekhar Nori
The K2G EVM from TI has an SD card slot as well as onboard eMMC for data storage. Enable support for these. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-16ARM: dts: K2G: Add support for MMC controllerSekhar Nori
K2G SoC from TI has two MMC/SD controllers. Add device tree data for these. Signed-off-by: Sekhar Nori <nsekhar@ti.com> Acked-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-15vexpress: Check TC2 firmware support before defaulting to nonsec bootingJon Medhurst \(Tixy\)
The firmware on TC2 needs to be configured appropriately before booting in nonsec mode will work as expected, so test for this and fall back to sec mode if required. Signed-off-by: Jon Medhurst <tixy@linaro.org> Reviewed-by: Ryan Harkin <ryan.harkin@linaro.org> Tested-by: Ryan Harkin <ryan.harkin@linaro.org>
2016-08-15Merge branch 'master' of git://git.denx.de/u-boot-atmelTom Rini
2016-08-15ARM: at91/dt: Add device tree for SAMA5D2 XplainedWenyou Yang
Add device tree for SAMA5D2 Xplained board. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com>
2016-08-15atmel: Bring in at91 pio4 device tree file and bindingsWenyou Yang
Bring in required device tree file and bindings from Linux. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15gpio: atmel_pio4: Move PIO4 definitions to head fileWenyou Yang
In order to make these PIO4 definitions shared with AT91 PIO4 pinctrl driver, move them from the existing gpio driver to the head file, and rephrase them. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15clk: at91: Add clock driverWenyou Yang
The patch is referred to at91 clock driver of Linux, to make the clock node descriptions in DT aligned with the Linux's. Signed-off-by: Wenyou Yang <wenyou.yang@atmel.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-08-15ARM: tegra: reduce CSITE clock from 204M to 136MBryan Wu
The L4T kernel complains about a CSITE clock rate above 144MHz, presumably because the HW is only characterized for a clock less than that. Adjust the rate to 136MHz to avoid the warning and stay in spec. Signed-off-by: Bryan Wu <pengw@nvidia.com> (swarren, re-wrote commit description) Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15ARM: tegra: move ft_system_setup()Stephen Warren
Currently, ft_system_setup() is implemented by board*.c, which are a bit of a dumping ground for a bunch of unrelated functionality, and separate versions exist for pre-Tegra186 and Tegra186. Move the implementation into a separate file to separate functionality, and allow sharing. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15ARM: tegra: enable PCIe controller on p2771-0000Stephen Warren
p2771-0000 has a couple of PCIe ports; one physically x4 desktop PCI connector (which may run at x2 electrically, depending on the board version and configuration) and a x1 connection to the M.2 slot (which may not be active, depending on the board version and configuration). This change enables those. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15ARM: tegra: enable SD card on p2771-0000Stephen Warren
Now that clock and reset drivers exist for Tegra186, we can enable the SD card controller. Now that a BPMP I2C driver exists for Tegra186, we can communicate with the PMIC to enable power to the SD card. Hook up the DT content and board code required to make the SD card work. Signed-off-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15ARM: tegra: enable I2C buses for P2771-0000Bryan Wu
Enable I2C devices in DT and enable building tegra_i2c.c driver. Signed-off-by: Bryan Wu <pengw@nvidia.com> (swarren, commit msg rework, fixed DT node sort order) Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15mmc: tegra: port to standard clock/reset APIsStephen Warren
Tegra186 supports the new standard clock and reset APIs. Older Tegra SoCs still use custom APIs. Enhance the Tegra MMC driver so that it can operate with either set of APIs. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15reset: add Tegra186 reset driverStephen Warren
In Tegra186, on-SoC reset signals are manipulated using IPC requests to the BPMP (Boot and Power Management Processor). This change implements a driver that does that. It is unconditionally selected by CONFIG_TEGRA186 since virtually any Tegra186 build of U-Boot will need the feature. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15clock: add Tegra186 clock driverStephen Warren
In Tegra186, on-SoC clocks are manipulated using IPC requests to the BPMP (Boot and Power Management Processor). This change implements a driver that does that. A tegra/ sub-directory is created to follow the existing pattern. It is unconditionally selected by CONFIG_TEGRA186 since virtually any Tegra186 build of U-Boot will need the feature. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-15misc: add Tegra BPMP driverStephen Warren
The Tegra BPMP (Boot and Power Management Processor) is a separate auxiliary CPU embedded into Tegra to perform power management work, and controls related features such as clocks, resets, power domains, PMIC I2C bus, etc. This driver provides the core low-level communication path by which feature-specific drivers (such as clock) can make requests to the BPMP. This driver is similar to an MFD driver in the Linux kernel. It is unconditionally selected by CONFIG_TEGRA186 since virtually any Tegra186 build of U-Boot will need the feature. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-08-12kconfig: use bool instead of boolean for type definition attributesMasahiro Yamada
Linux stopped the use of keyword 'boolean' in Kconfig. Refer to commit 6341e62b212a2541efb0160c470e90bd226d5496 ("kconfig: use bool instead of boolean for type definition attributes") in Linux Kernel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-12ARM: dts: dra7xx-evm: add evm_3v3_sd regulatorVignesh R
Add a node for evm_3v3_sd using onboard PCF GPIO expander which feeds on to mmc vdd. Update mapping for vmmc-supply and vmmc_aux-supply. evm_3v3_sd supplies to SD card vdd, and ldo1 to sdcard i/o lines. Signed-off-by: Vignesh R <vigneshr@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-08-12drivers/sysreset: group sysreset driversMax Filippov
Create drivers/sysreset and move sysreset-uclass and all sysreset drivers there. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-12ARM: non-sec: flush code cacheline alignedStefan Agner
Flush operations need to be cacheline aligned to take effect, make sure to flush always complete cachelines. This avoids messages such as: CACHE: Misaligned operation at range [00900000, 009004d9] Signed-off-by: Stefan Agner <stefan.agner@toradex.com> Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-08-11Merge branch 'master' of git://git.denx.de/u-boot-uniphierTom Rini
2016-08-11Merge branch 'master' of git://git.denx.de/u-boot-usbTom Rini
2016-08-11ARM: uniphier: add PSCI support for UniPhier ARMv7 SoCsMasahiro Yamada
Currently, only the CPU_ON function is supported. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-11ARM: uniphier: add uniphier_cache_set_active_ways()Masahiro Yamada
This outer cache allows to control active ways independently for each CPU, so this function will be useful to set up active ways for a specific CPU. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-11ARM: uniphier: add uniphier_cache_inv_way() to support way invalidationMasahiro Yamada
This invalidates entries in specified ways of the outer cache. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-11ARM: uniphier: move (and rename) CONFIG_UNIPHIER_L2CACHE_ON to KconfigMasahiro Yamada
Move this option to Kconfig, renaming it into CONFIG_CACHE_UNIPHIER. The new option name makes sense enough, and the same as Linux has. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-11ARM: uniphier: move outer cache register macros to .c fileMasahiro Yamada
Now, all of these macros are only used in cache-uniphier.c, so there is no need to export them in a header file. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-08-11ARM: uniphier: reuse uniphier_cache_disable() for lowlevel_initMasahiro Yamada
The DRAM is available at this point, so setup the temporary stack and call the C function to reduce the code duplication a bit. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
