path: root/arch/arm
2016-01-20arm: dts: am437x-sk-evm: add tick-timer to chosen nodeMugunthan V N
Specify which timer to be used as tick-timer in chosen node. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-20arm: omap-common: do not build timer when CONFIG_TIMER definedMugunthan V N
To prepare timer driver to DM/DT conversion do not build the exiting timer driver when CONFIG_TIMER is defined. But since omap's SPL doesn't support DM yet so built timer driver only for SPL build when CONFIG_TIMER is defined. Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-20stm32: move stm32 specific code to mach-stm32Vikas Manocha
This patch moves stm32 sources at one place, with this armv7m now contains only generic stuff. Signed-off-by: Vikas Manocha <vikas.manocha@st.com>
2016-01-20armv7: Add missing newline after OMAP die IDLadislav Michl
Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Acked-by: Enric Balletbo Serra <enric.balletbo@collabora.com>
2016-01-20arm, ubifs: fix gcc5.x compiler warningHeiko Schocher
compiling U-Boot for openrd_base_defconfig with gcc 5.x shows the following warning: CC fs/ubifs/super.o In file included from fs/ubifs/ubifs.h:35:0, from fs/ubifs/super.c:37: fs/ubifs/super.c: In function 'atomic_inc': ./arch/arm/include/asm/atomic.h:55:2: warning: 'flags' is used uninitialized in this function [-Wuninitialized] local_irq_save(flags); ^ fs/ubifs/super.c: In function 'atomic_dec': ./arch/arm/include/asm/atomic.h:64:2: warning: 'flags' is used uninitialized in this function [-Wuninitialized] local_irq_save(flags); ^ CC fs/ubifs/sb.o [...] CC fs/ubifs/lpt.o In file included from include/linux/bitops.h:123:0, from include/common.h:20, from include/ubi_uboot.h:17, from fs/ubifs/ubifs.h:37, from fs/ubifs/lpt.c:35: fs/ubifs/lpt.c: In function 'test_and_set_bit': ./arch/arm/include/asm/bitops.h:57:2: warning: 'flags' is used uninitialized in this function [-Wuninitialized] local_irq_save(flags); ^ CC fs/ubifs/lpt_commit.o In file included from include/linux/bitops.h:123:0, from include/common.h:20, from include/ubi_uboot.h:17, from fs/ubifs/ubifs.h:37, from fs/ubifs/lpt_commit.c:26: fs/ubifs/lpt_commit.c: In function 'test_and_set_bit': ./arch/arm/include/asm/bitops.h:57:2: warning: 'flags' is used uninitialized in this function [-Wuninitialized] local_irq_save(flags); ^ CC fs/ubifs/scan.o CC fs/ubifs/lprops.o CC fs/ubifs/tnc.o In file included from include/linux/bitops.h:123:0, from include/common.h:20, from include/ubi_uboot.h:17, from fs/ubifs/ubifs.h:37, from fs/ubifs/tnc.c:30: fs/ubifs/tnc.c: In function 'test_and_set_bit': ./arch/arm/include/asm/bitops.h:57:2: warning: 'flags' is used uninitialized in this function [-Wuninitialized] local_irq_save(flags); ^ CC fs/ubifs/tnc_misc.o Fix it. Signed-off-by: Heiko Schocher <hs@denx.de>
2016-01-20ARM: uniphier: remove unneeded if conditionalsMasahiro Yamada
The if block does the same as the else block does. The conditional is not necessary at all. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-20ARM: uniphier: move UMC register macros to umc-regs.hMasahiro Yamada
The umc-proxstream2.c defiens the same macros as in umc-regs.h. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-20ARM: uniphier: set active ways to really enable outer cacheMasahiro Yamada
Each way must be unlocked to make it effective. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-20ARM: uniphier: fix range invalidate for outer cacheMasahiro Yamada
If invalidate operation is invoked against a cache-unaliged region, the both ends of the region should be flushed, not invalidated. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-20ARM: uniphier: factor out outer cache sync as a helper functionMasahiro Yamada
Avoid repeating the same code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-20ARM: uniphier: refactor outer cache operation slightlyMasahiro Yamada
Improve readability without changing the behavior. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-19armv8: cavium: Add ThunderX 88xx board definitionSergey Temerkhanov
This commit adds basic Cavium ThunderX 88xx board definitions and support. Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> [trini: Drop CONFIG_SYS_GENERIC_BOARD define] Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-19armv8: cavium: Add the device tree for ThunderXSergey Temerkhanov
This commit adds the FDT for the ThunderX family of SoCs Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-19armv8: Add Secure Monitor/Hypervisor Call (SMC/HVC) infrastructureSergey Temerkhanov
This commit adds functions issuing calls to secure monitor or hypervisore. This allows using services such as Power State Coordination Interface (PSCI) provided by firmware, e.g. ARM Trusted Firmware (ATF) The SMC call can destroy all registers declared temporary by the calling conventions. The clobber list is "x0..x17" because of this Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Corey Minyard <cminyard@mvista.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
2016-01-19armv8: New MMU setup code allowing to use 48+ bits PA/VASergey Temerkhanov
This patch adds code which sets up 2-level page tables on ARM64 thus extending available VA space. CPUs implementing 64k translation granule are able to use direct PA-VA mapping of the whole 48 bit address space. It also adds the ability to reset the SCTRL register at the very beginning of execution to avoid interference from stale mappings set up by early firmware/loaders/etc. Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com>
2016-01-19armv8: Add read_mpidr() functionSergey Temerkhanov
This patch adds the read_mpidr() function which returns the MPIDR_EL1 register value Signed-off-by: Sergey Temerkhanov <s.temerkhanov@gmail.com> Signed-off-by: Radha Mohan Chintakuntla <rchintakuntla@cavium.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-16socfpga: Modify qts-filter args to allow input for bsp generated files and ↵Dalon Westergreen
quartus project directories The hps_isw_handoff and bsp/generated folders are typically not in the same path.This patch adds support for specifying the different input directories for the bsp and quartus projects. Signed-off-by: Dalon Westergreen <dwesterg@gmail.com> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Chin Liang See <clsee@altera.com>
2016-01-14arm: initialize gd for AArch64Stephen Warren
Commit adc421e4cee8 "arm: move gd handling outside of C code" removed the call to arch_setup_gd() on ARM and replaced it with assembly code in crt0.S. However, AArch64 uses a different startup file, and the same change was not made to it. This leaves gd uninitialized on AArch64, which typically leads to hangs or crashes. This change fixes that. Fixes: adc421e4cee8 ("arm: move gd handling outside of C code") Signed-off-by: Stephen Warren <swarren@nvidia.com>
2016-01-14Merge git://www.denx.de/git/u-boot-marvellTom Rini
Conflicts: arch/arm/Kconfig Signed-off-by: Tom Rini <trini@konsulko.com>
2016-01-14mvebu: Support Synology DS414Phil Sutter
This adds support for the MV78230 based DS414 NAS by Synology. The relevant bits have been extracted from the 'synogpl-5004-armadaxp' package Synology kindly published, garnished with a fair amount of trial-and-error. Sadly, support is far from perfect. The major parts I have failed in are SATA and XHCI support. Details about these and some other things follow: Device Tree ----------- The device tree file armada-xp-synology-ds414.dts has been copied from Linux and enhanced by recent U-Boot specific changes to armada-xp-gp.dts. SATA Support ------------ There is a Marvell 88SX7042 controller attached to PCIe which is supported by Linux's sata_mv driver but sadly not U-Boot's sata_mv. I'm not sure if extending the latter to support PCI devices is worth the effort at all. Porting sata_mv from Linux exceeded my brain's capacities. :( XHCI Support ------------ There is an EtronTech EJ168A XHCI controller attached to PCIe which drives the two rear USB3 ports. After a bit of playing around I managed to get it recognized by xhci-pci, but never was able to access any devices attached to it. Enabling it in ds414 board config shows that it does not respond to commands for whatever reason. The (somewhat) bright side to it is that it is not even supported in Synology's customized U-Boot, but that also means nowhere to steal the relevant bits from. EHCI Support ------------ This seems functional after issuing 'usb start'. At least it detects USB storage devices, and IIRC reading from them was OK. OTOH Linux fails to register the controller if 'usb start' wasn't given before in U-Boot. According to Synology sources, this board seems to support USB device (gadget?) mode. Though I didn't play around with it. PCIe Support ------------ This is fine, but trying to gate the clocks of unused lanes will hang PCI enum. In addition to that, pci_mvebu seems not to support DM_PCI. DDR3 Training ------------- Marvell/Synology uses eight PUPs instead of four. Does not look like this is meant to be customized in mainline U-Boot at all. OTOH I have no idea what a "PUP" actually is. PEX Init -------- Synology uses different values than mainline U-Boot with this patch: pex_max_unit_get returns 2, pex_max_if_get returns 7 and max_serdes_lines is set to 7. Not changing this seems to not have an impact, although I'm not entirely sure it does not cause issues I am not aware of. Static Environment ------------------ This allows to boot stock Synology firmware at least. In order to be a little more flexible when it comes to booting custom kernels, do not only load zImage partition, but also rd.gz into memory. This way it is possible to use about 7MB for kernel with piggyback initramfs. Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-14mvebu: Add rudimental MV78230 supportPhil Sutter
This adds basic support for Marvell's MV78230 SoC which belongs to the Armada XP series. Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-14mvebu: Introduce kconfig symbols for SoC variantsPhil Sutter
This patch adds intermediate kconfig symbols which select their SoC family. Boards then select them instead of the family symbol directly. Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-14mvebu: axp: refactor board_sat_r_get() and callerPhil Sutter
Instead of calling board_sat_r_get() only for those boards providing the satr11 value via I2C, call it for all boards and return static values for those not using I2C. In addition to that, make this a weak function to allow for board code to override it. Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-14drivers/pci/pci_mvebu: Fix for boards with X4 lanesPhil Sutter
Armada XP has support for X4 lanes, boards specify this in their serdes_cfg. During PEX init in high_speed_env_lib.c, the configuration is stored in GEN_PURP_RES_2_REG. When enumerating PEX, subsequent interfaces of an X4 lane must be skipped. Otherwise the enumeration hangs up the board. The way this is implemented here is not exactly beautiful, but it mimics how Marvell's BSP does it. Alternatively we could get the information using board_serdes_cfg_get(), but that won't lead to clean code, either. Signed-off-by: Phil Sutter <phil@nwl.cc> Acked-by: Stefan Roese <sr@denx.de> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-01-14arm: mvebu: Add runtime detection of UART (xmodem) boot-modeStefan Roese
This patch adds runtime detection of the Marvell UART boot-mode (xmodem protocol). If this boot-mode is detected, SPL will return to the BootROM to continue the UART booting. With this patch its now possible, to generate a U-Boot image that can be booted either from the strapped boot-device (e.g. SPI NOR, MMC, etc) or via the xmodem protocol from the UART. In the UART case, the kwboot tool will dynamically insert the UART boot-device type into the image. And also patch the load address in the header, so that the mkimage header will be skipped (as its not expected by the Marvell BootROM). This simplifies the development for Armada XP / 38x based boards. As no special images need to be generated by selecting the MVEBU_BOOTROM_UARTBOOT Kconfig option. Since the Kconfig option MVEBU_BOOTROM_UARTBOOT is not needed any more, its now completely removed. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-14arm: mvebu: Add runtime boot-device detectionStefan Roese
This patch adds runtime boot-device detection to SPL U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-14arm: mvebu: Make local structs static constStefan Roese
As these structs are local only and const, declare them accordingly. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-14arm: mvebu: Move SAR register defines into headerStefan Roese
This is preparation for the runtime bootmode detection in spl.c. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Phil Sutter <phil@nwl.cc> Cc: Kevin Smith <kevin.smith@elecsyscorp.com>
2016-01-14arm: mvebu: Remove leftover MakefileStefan Roese
This Makefile was not used since quite some time. I only missed to remove it in the move to mach-mvebu. So lets remove it now so that the mvebu-common directory is really removed completely. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Move SoC selection (A38X vs AXP) into KconfigStefan Roese
Until now, the SoC selection for the ARCH_MVEBU platforms has been done in the config header. Using CONFIG_ARMADA_XP in a non-clear way. As it needed to get selected for AXP and A38x based boards. This patch now changes this to move the SoC selection to Kconfig. And also uses CONFIG_ARCH_MVEBU as a common define for both AXP and A38x. This makes things a bit clearer - especially for new board additions. Additionally the defines CONFIG_SYS_MVEBU_DDR_AXP and CONFIG_SYS_MVEBU_DDR_A38X are replaced with the already available CONFIG_ARMADA_38X and CONFIG_ARMADA_XP. And CONFIG_DDR3 is removed, as its not referenced anywhere. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Consolidate board Kconfig options into one fileStefan Roese
Merging all the board specific Kconfig options into the main Kconfig file for mach-mvebu makes things easier to maintain. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Print CPU and SDRAM frequency upon startupStefan Roese
With this patch, the CPU and the DDR frequencies will get printed in the U-Boot startup messages. Resulting in such a log: U-Boot 2016.01-rc2-00188-gb8eeaec-dirty (Dec 21 2015 - 12:32:35 +0100) SoC: MV78460-B0 at 1600 MHz I2C: ready DRAM: 4 GiB (800 MHz, ECC not enabled) ... Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Make serdes setup on Armada XP less noisyStefan Roese
Change some of the PEX configuration output lines from always output to only ouput upon specific debug enabling. This changes the SPL output from: U-Boot SPL 2016.01-rc2-00037-g9353a7f (Dec 10 2015 - 10:27:42) High speed PHY - Version: 2.1.5 (COM-PHY-V20) Update Device ID PEX0782611ab Update Device ID PEX1782611ab Update Device ID PEX2782611ab Update Device ID PEX3782611ab Update Device ID PEX8782611ab Update PEX Device ID 0x78260 High speed PHY - Ended Successfully DDR3 Training Sequence - Ver 5.7.4 DDR3 Training Sequence - Ended Successfully to: U-Boot SPL 2016.01-rc2-00037-g9353a7f-dirty (Dec 10 2015 - 10:32:04) High speed PHY - Version: 2.1.5 (COM-PHY-V20) High speed PHY - Ended Successfully DDR3 Training Sequence - Ver 5.7.4 DDR3 Training Sequence - Ended Successfully Resulting in a little faster bootup time. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Don't include "netdev.h" in cpu.cStefan Roese
This is not needed any more since the switch to DM / DTS network initialization on MVEBU. Lets remove it, as it otherwise leads to compilation warning when CONFIG_NET is not enabled. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add support for MV78260Stefan Roese
This patch adds support for the dual core Armada XP variant, the MV78260. It has some minor differences to the 4-core MV78460, e.g. only 12 serdes lanes. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Phil Sutter <phil@nwl.cc>
2016-01-14arm: mvebu: Don't use 0 as board ID as its used for the custom boardsStefan Roese
Using board ID 0 is reserved for the non-Marvell "custom" boards. So move the board ID's to reflect this. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Phil Sutter <phil@nwl.cc>
2016-01-14arm: mvebu: Simplify code in setup_usb_phys() a bitStefan Roese
Use the clrbits() / setbits() functions instead of clrsetbits() when bit are only cleared or set. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Don't disable cache at startup on Armada XP at allStefan Roese
This patch leaces the cache configuration untouched for the AXP in the setup done by the BootROM. Resulting in the cache still being enabled at the startup of U-Boot. This leads to a slightly faster boot to the U-Boot prompt (or Linux of course). Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Don't call arch_cpu_init() from SPL at allStefan Roese
This patch removes the call to arch_cpu_init() in the SPL U-Boot version. As SPL does not need all the configuration done in this function. And also does not need the reconfiguration of the internal register address to 0xf1000000. This will be done by the main U-Boot later on. This also fixes a problem with the timer not beeing initialized on AXP, as needed for the mdelay in the setup_usb_phys(). This will now only be called once in main U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add v7_outer_cache_disable function for AXP & A38xStefan Roese
Add functionality to correctly disable the L2 cache on the Armada XP and 38x platforms. Without this, booting into Linux on ClearFog (A38x) results in a hangup without any output on the serial console at all. Even with earlyprintk enabled. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Enable L2 cache on Armada XPStefan Roese
Until now, the L2 cache was never enabled again in U-Boot. To get even better performance (bootup time), lets enable the L2 cache in U-Boot. This code was taken from the Linux kernel. A performance gain was measured on the DB-MV784MP-GP board by testing with tftpboot and sata commands. This patch also cleans up the L2 cache related code. And makes sure that the L2 cache is only disabled once. Please note that A38x still runs with L2 cache disabled. And needs to be enabled for this SoC in a separate patch if needed or desired. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add SolidRun ClearFog Armada 38x initial supportStefan Roese
This patch adds basic support for the SolidRun ClearFog Armada 38x based board to mainline U-Boot. Supported interfaces / devices are: - DDR3 - UART - MMC - Ethernet port 0 (connected to dedicated PHY) - I2C The included DT source was taken from Russell King's ftp server: http://www.home.arm.linux.org.uk/~rmk/clearfog/ With only minor modifications, like the addition of some aliases and the "u-boot,dm-pre-reloc" property. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Rabeeh Khoury <rabeeh@solid-run.com> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Move some defines to common include fileStefan Roese
This patch moves some config options to the mvebu common include file. Making it easier to not forget these defines for new boards. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc>
2016-01-14net: mvneta: Convert to driver modelStefan Roese
Update this driver to support driver model. As all MVEBU boards using this driver are converted with this patch, the non-driver-model code can be removed completely. This is also the reason why this patch is quite big and includes a) the driver change and b) the platform change. As its not git-bisect save otherwise. With this conversion, some parameters are now extracted from the DT instread of using the config header defines. The supported properties right now are: PHY-mode ("phy-mode") and PHY-address ("reg"). The base addresses for the ethernet controllers can be removed from the header files as well. Please note that this patch also removes the E1000 network driver from some MVEBU config headers. This is necessary, as with DM_ETH configured and the e1000 driver enabled, the PCI driver also needs to support DM. But the MVEBU PCI(e) driver still needs to get ported to DM. When this is done, the E1000 driver can be enabled again. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Joe Hershberger <joe.hershberger@ni.com> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: armada-388-gp.dts: Add ethernet aliasesStefan Roese
Adding these aliases enables the update of the MAC addresses from within U-Boot. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add armada-xp-maxbcm.dts for maxbcm boardStefan Roese
This is needed for the upcoming ethernet DM conversion of the maxbcm board. The configuration of the PHY is then extracted from the DT instead of using the defines from the config header. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr>
2016-01-14arm: mvebu: Add SPI driver model supportStefan Roese
This patch enables the DM support for the SPI driver and the SPI NOR flash chips. Some MVEBU boards boot from SPI NOR, so adding the aliases and enabling CONFIG_DM_SEQ_ALIAS is needed here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu: Add DM and OF_CONTROL support to SPLStefan Roese
This patch adds full DM support to the SPL on MVEBU. Currently only serial is supported. Other drivers will follow. This patch also adds the necessary config values for the DEBUG UART to the MVEBU defconfig files. This came in handy while implementing this DM support. Additionally, the mvebu specific SPL linker script is removed and this common one is used instead: arch/arm/cpu/u-boot-spl.lds This common linker script already handles all special cases. No need to reinvent the wheel for MVEBU here. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Dirk Eibach <dirk.eibach@gdsys.cc> Cc: Simon Glass <sjg@chromium.org>
2016-01-14arm: mvebu/kirkwood: Use common timer functionsStefan Roese
By using the common timer functions for mvebu/kirkwood we can get rid of quite a lot of code. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Luka Perkov <luka.perkov@sartura.hr> Cc: Simon Guinot <simon.guinot@sequanux.org> Cc: Valentin Longchamp <valentin.longchamp@keymile.com>
