Move common chip revision id's to main cpu header file
mx25 generic include cpu header for chip revision
Signed-off-by: Adrian Alonso <aalonso@freescale.com>
add some missing gpr register defines.
We can reuse common functions in lib/time.c, but not reimplement
functions in imx-common/time.c.
Only keep timer_init ,get_tbclk and implement timer_read_counter in
imx-common/time.c.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Enabled zynq qspi controller node for zed board.
Signed-off-by: Jagan Teki <jteki@openedev.com>
Cc: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Acked-by: Michal Simek <michal.simek@xilinx.com>
Enabled zynq qspi controller node for zc770-xm010 board.
=> sf probe 0 -- bus1 for selecting qspi controller
=> sf probe 1 -- bus0 for selecting spi controller
Enabled zynq qspi controller node for zc706 board.
Enabled zynq qspi controller node for zc702 board.
Enabled zynq qspi controller node for microzed board,
verified the same on spansion spi-nor flash.
Tested-by: Jagan Teki <jteki@openedev.com>
This patch adds zynq qspi controller nodes in zynq-7000.dtsi.
We have finished Generic Board conversion for ARM and PowerPC, i.e.
all the boards have been converted except OpenRISC, SuperH, SPARC,
which have not supported Generic Board framework yet.
Select SYS_GENERIC_BOARD in arch/Kconfig and delete all the macro
defines in include/configs/*.h.
We should not init the console this early since it precludes using driver
model for the UART, since it is not set up at the start of board_init_f().
See the README for more information. The debug UART does not have this
restriction. If we want to do early init with the console on it can be done
in spl_board_init().
Move the preloader_console_init() call from board_init_f() to board_init_r().
Tested-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Tested-by: Michal Simek <michal.simek@xilinx.com>
There is quite a bit of assembler code that can be removed if we use the
generic global_data setup. Less arch-specific code makes it easier to add
new features and maintain the start-up code.
Drop the unneeded code and adjust the hooks in board_f.c to cope.
Tested on LS2085ARDB and LS2085AQDS (armv8 SoC).
Tested-by: York Sun <yorksun@freescale.com>
Import various DT files for am57xx-beagle-x15 from
Linux Kernel v4.2
Add config file for this board, enable DM, DM_GPIO,
DM_SERIAL and DM_MMC.
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Import various DT files for am437x-sk-evm from Linux Kernel v4.2
Add config file for this board, enable DM, DM_GPIO, DM_SERIAL
and DM_MMC.
Reviewed-by: Lokesh Vutla <lokeshvutla@ti.com>
Import various DT files for am4372, an43xx pinctrl and
am437x-gp-evm from Linux Kernel v4.2
and DM_MMC.
Existing driver gets the actual omap hammc base address + 0x100
bytes as the first 0x100 bytes is not used by the driver. But
with DM conversion the base address from DT is different, to
accommodate the offset adding res0[0x100] to struct hsmmc.
Import various DT files for dra7-evm from Linux Kernel v4.2
Add config file for this board, enable DM and DM_GPIO
Add basic DT support for k2g evm.
Add MMC support for k2g
Signed-off-by: Roger Quadros <rogerq@ti.com>
Tested-by: Mugunthan V N <mugunthanvnm@ti.com>
In K2G, Ethernet doesn't support SGMII instead it support RGMII,
adding support to the driver to connect to RGMII phy.
Signed-off-by: Vitaly Andrianov <vitalya@ti.com>
Phy mode is a board property and it can be different between
multiple board and ports, so it should not be hardcoded in
driver to one specific mode. So adding a field in eth_priv_t
structure to pass phy mode to driver.
update K2G nav rx queue number
Coreect base addresses for SPI, Queue Manager, Ethernet, GPIO,
and MSMC segments.
Add api for configuring pin mux.
Add ddr3 related info
Add psc information for k2g
Add clock information for Galileo
Add pll data for k2g
Add Kconfig support
Adding CPU detection support for Keystone2 Galileo.
Now that OF_CONTROL is enabled on all keystone2 platforms,
build the default images with DT.
Import k2e specific DT files from Linux Kernel and enable
OF_CONTROL, DM, DM_SERIAL.
Import k2l specific DT files from Linux Kernel and enable
Import k2hk specific DT files from Linux Kernel and enable
Keystone dts files assumes that LPAE is enabled and top level root
node uses 64bit addresses. This breaks the keystone boot with
CONFIG_OF_CONTROL enabled. So do not use 64 bit addresse in U-Boot DT.
Import various generic dts files from Linux kernel so that
all keystone2 platforms can be DT in U-boot.
With CONFIG_DM_SERIAL is enabled NS16550_init() cannot be
called directly. Driver probe should be taking care of this.
So call this function only when DM_SERIAL is not enabled.
Since there is a common function to grab the serial number from the die id bits,
it makes sense have one to parse that serial number and feed it to the serial
ATAG.
Signed-off-by: Paul Kocialkowski <contact@paulk.fr>
This introduces omap_die_id_display to display the full die id.
There is no need to store it in an environment variable, that no boot script
is using anyway.
Now that we have a common prototype to grab the omap die id, functions to figure
out a serial number and usb ethernet address can use it directly.
Those also get an omap_die_id prefix for better consistency.
This introduces omap5 support for omap_die_id, which matches the common
omap_die_id definition. It replaces board-specific code to grab the die id bits.
This introduces omap4 support for omap_die_id, which matches the common
This replaces the previous get_dieid definition with omap_die_id, that matches
the common omap_die_id definition.
This introduces a common definition for omap_die_id, that aims at providing a
common interface for accessing omap platform's die id bits.
This patch enables DM_SERIAL for all ARCH_MVEBU boards (AXP & A38x).
Cc: Luka Perkov <luka.perkov@sartura.hr>
This patch adds driver model support for some Marvell MVEBU SoC's. Including
Armada XP and 38x. All 3 currently mainlined boards are converted. DM is now
selected automatically for MVEBU platforms.
With this DM support now available for MVEBU, hardcoding the base addresses
and other information is not necessary any more. Probing should be done
by using the values provided via the device tree now instead. For this
the driver also need to be converted to DM. Patches for some of the drivers
will follow.
These will be needed by the upcoming DM (driver model) support for
the Armada XP / 38x SoC's. This will provide DT based probing.
The dts files are copied 1:1 from the Linux kernel release v4.2.
Instead of calling board_init_r() directly from board_init_f(), just
return from board_init_f(). This will make the code continue executing
in crt0.S _main(), from which the board_init_r() is called. This patch
aligns the MVEBU SPL with the correct SPL design as well as reduces
the stack utilisation slightly.
