Move this option to Kconfig and tidy up existing uses.
There are a few options which use lower case. We should use upper case for
all CONFIG options.
[trini: Add usbtty/nand hunk to include/configs/spear3xx_evb.h]
A few boards define this in a header file which is incorrect. It means that
Kconfig options that rely on this cannot be used. Move it.
Note that quite a few boards defined this options but do not appear to
actually use SPL:
BSC9132QDS_NOR_DDRCLK100_SECURE
BSC9132QDS_NOR_DDRCLK133_SECURE
BSC9132QDS_SDCARD_DDRCLK100_SECURE
BSC9132QDS_SDCARD_DDRCLK133_SECURE
BSC9132QDS_SPIFLASH_DDRCLK100_SECURE
BSC9132QDS_SPIFLASH_DDRCLK133_SECURE
C29XPCIE_NOR_SECBOOT
P1010RDB-PA_36BIT_NAND_SECBOOT
P1010RDB-PA_36BIT_SPIFLASH_SECBOOT
P1010RDB-PA_NAND_SECBOOT
P1010RDB-PA_NOR_SECBOOT
P1010RDB-PB_36BIT_NOR_SECBOOT
P1010RDB-PB_36BIT_SPIFLASH_SECBOOT
P1010RDB-PB_NAND_SECBOOT
P1010RDB-PB_NOR_SECBOOT
P3041DS_SECURE_BOOT
P4080DS_SECURE_BOOT
P5020DS_NAND_SECURE_BOOT
P5040DS_SECURE_BOOT
T1023RDB_SECURE_BOOT
T1024QDS_DDR4_SECURE_BOOT
T1024QDS_SECURE_BOOT
T1024RDB_SECURE_BOOT
T1040RDB_SECURE_BOOT
T1042D4RDB_SECURE_BOOT
T1042RDB_SECURE_BOOT
T2080QDS_SECURE_BOOT
T2080RDB_SECURE_BOOT
T4160QDS_SECURE_BOOT
T4240QDS_SECURE_BOOT
ls1021aqds_nor_SECURE_BOOT
ls1021atwr_nor_SECURE_BOOT
ls1043ardb_SECURE_BOOT
For these boards CONFIG_SPL_DM will no-longer be defined in SPL. But since
they apparently don't have an SPL, this should not matter.
The secure boot header files incorrectly define SPL options only if
CONFIG_SPL_BUILD is defined. This means that the options are only enabled
in an SPL build, and not with a normal 'make xxx_defconfig'. This means
that moveconfig.py cannot work, since it sees the options as disabled even
when they may be manually enabled in an SPL build.
Fix this by changing the order.
We are supposed to not add config entries with only "default y"
in board/SoC Kconfig files.
Acked-by: Enric Balletbo i Serra <enric.balletbo@collabora.com>
Move this option to Kconfig and set its default value to 4; this
increases the number of supported CPUs for some boards.
It consumes 1KB memory per CPU for PSCI stack, but it should not
be a big deal, given the amount of memory used for the modern OSes.
Reviewed-by: Alexander Graf <agraf@suse.de>
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms
can select. Then, move CONFIG_ARMV7_PSCI, which is automatically
enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled.
If CONFIG_ARMV7_NONSEC is enabled, the linker script requires
CONFIG_ARMV7_PSCI_NR_CPUS regardless of CONFIG_ARMV7_PSCI.
SPL_BUILD is not a CONFIG in Kconfig, so !SPL_BUILD is always true.
On all TI platforms the ROM defines a "downloaded image" area at or near
the start of SRAM which is followed by a reserved area. As it is at
best bad form and at worst possibly harmful in corner cases to write in
this reserved area, we stop doing that by adding in the define
NON_SECURE_SRAM_IMG_END to say where the end of the downloaded image
area is and make SRAM_SCRATCH_SPACE_ADDR be one kilobyte before this.
At current we define the end of scratch space at 0x228 bytes past the
start of scratch space this this gives us a lot of room to grow. As
these scratch uses are non-optional today, all targets are modified to
respect this boundary.
Tested on OMAP4 Pandaboard, OMAP3 Beagle xM
Cc: Albert Aribaud <albert.u.boot@aribaud.net>
Cc: Nagendra T S <nagendra@mistralsolutions.com>
Cc: Vaibhav Hiremath <hvaibhav@ti.com>
Cc: Lokesh Vutla <lokeshvutla@ti.com>
Cc: Felipe Balbi <balbi@ti.com>
Cc: Igor Grinberg <grinberg@compulab.co.il>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Paul Kocialkowski <contact@paulk.fr>
Cc: Enric Balletbo i Serra <eballetbo@gmail.com>
Cc: Adam Ford <aford173@gmail.com>
Cc: Steve Sakoman <sakoman@gmail.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Thomas Weber <weber@corscience.de>
Cc: Hannes Schmelzer <oe5hpm@oevsv.at>
Cc: Thomas Chou <thomas@wytron.com.tw>
Cc: Sam Protsenko <semen.protsenko@linaro.org>
Cc: Samuel Egli <samuel.egli@siemens.com>
Cc: Michal Simek <michal.simek@xilinx.com>
Cc: Mateusz Kulikowski <mateusz.kulikowski@gmail.com>
Cc: Ben Whitten <ben.whitten@gmail.com>
Cc: Bin Meng <bmeng.cn@gmail.com>
Cc: Sekhar Nori <nsekhar@ti.com>
Cc: Mugunthan V N <mugunthanvnm@ti.com>
Cc: "B, Ravi" <ravibabu@ti.com>
Cc: "Matwey V. Kornilov" <matwey.kornilov@gmail.com>
Cc: Ladislav Michl <ladis@linux-mips.org>
Cc: Ash Charles <ashcharles@gmail.com>
Cc: "Kipisz, Steven" <s-kipisz2@ti.com>
Cc: Daniel Allred <d-allred@ti.com>
Tested-by: Lokesh Vutla <lokeshvutla@ti.com>
Acked-by: Lokesh Vutla <lokeshvutla@ti.com>
Tested-by: Ladislav Michl <ladis@linux-mips.org>
Remove the device definition from board file, update the driver with
the new compatible property and update config with necessary options.
Signed-off-by: Beniamino Galvani <b.galvani@gmail.com>
Import DTS files and dt-bindings includes from Linux 4.8-rc1.
So far we could only tell the gpio framework that a GPIO was mapped as input or
output, not as alternative function.
This patch adds support for determining whether a function is mapped as
alternative.
Acked-by: Stephen Warren <swarren@wwwdotorg.org>
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and
REFR fields of the MDREF register as 1 and 7, respectively for
DDR3 and 0 and 3 for LPDDR2.
Looking at the MDREF initialization done via DCD we see that
boards do need to initialize these fields differently:
$ git grep 0x021b0020 board/
board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800
board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */
board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800
board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800
board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800
board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800
board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800
So introduce a mechanism for users to be able to configure
REFSEL and REFR fields as needed.
Keep all the mx6 SPL users in their current REF_SEL and REFR values,
so no functional changes for the existing users.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Eric Nelson <eric@nelint.com>
Add support for Advantech DMS-BA16 board. The board is based on Advantech
BA16 module which has a i.MX6D processor. The board supports:
- FEC Ethernet
- USB Ports
- SDHC and MMC boot
- SPI NOR
- LVDS and HDMI display
Basic information about the module:
- Module manufacturer: Advantech
- CPU: Freescale ARM Cortex-A9 i.MX6D
- SPECS:
Up to 2GB Onboard DDR3 Memory;
Up to 16GB Onboard eMMC NAND Flash
Supports OpenGL ES 2.0 and OpenVG 1.1
HDMI, 24-bit LVDS
1x UART, 2x I2C, 8x GPIO,
4x Host USB 2.0 port, 1x USB OTG port,
1x micro SD (SDHC),1x SDIO, 1x SATA II,
1x 10/100/1000 Mbps Ethernet, 1x PCIe X1 Gen2
Signed-off-by: Akshay Bhat <akshay.bhat@timesys.com>
Cc: u-boot@lists.denx.de
Cc: sbabic@denx.de
With commit ceec08f50b6, phy is connected to slave 0, but
changing the phy node was missed, fix it by populating the
phy node to proper cpsw slave node.
Fixes: ceec08f50b6 ("ARM: dts: dra72-evm: Add mode-gpios entry for mac node")
Signed-off-by: Mugunthan V N <mugunthanvnm@ti.com>
Cc: Vignesh R <vigneshr@ti.com>
Tested-by: Tom Rini <trini@konsulko.com>
The Orange Pi Plus2E is an extended version of the Orange Pi Pc Plus,
with 2G RAM and an external gbit ethernet phy.
The dts file is identical to the one submitted to the upstream kernel,
except that it has the pending patch to enable the ethernet controller
squashed in, as u-boot already has sun8i-emac support.
This adds an emac node to the orangepi-2 dts (not yet merged upstream,
but in u-boot we already have emac support); fixes the alphetically
sorting of nodes in sun8i-h3-orangepi-plus.dts and disables some
usb controllers in sun8i-h3-orangepi-plus.dts which are only used
on the plus2e, as upstream has decided to do a separate dts files
for the plus2e.
The sun8i-emac driver follows an old version of the proposed DT
bindings, where the EMAC clock and EPHY control register range is
listed directly, rather than through a syscon phandle.
Add back the syscon register range to avoid an invalid data access.
We should fix the driver once the Linux kernel bindings have been
finalized.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
Reviewed-by: Hans de Goede <hdegoede@redhat.com>
A33-OLinuXino is A33 development board designed by Olimex LTD.
It has AXP223 PMU, 1GB DRAM, a micro SD card, one USB-OTG connector,
headphone and mic jacks, connector for LiPo battery and optional
4GB NAND Flash.
It has two 40-pin headers. One for LCD panel, and one for
additional modules. Also there is CSI/DSI connector.
The dts files are identical to the ones submitted to the upstream kernel.
Signed-off-by: Stefan Mavrodiev <stefan.mavrodiev@gmail.com>
Add a proper dts for the iNet D978 rev2 based A33 tablets.
Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz>
Acked-by: Hans de Goede <hdegoede@redhat.com>
The Colorado TK1 SOM is a small form factor board similar to the
Jetson TK1. The main differences lie in the pinmux, and in that the
PCIe controller is set to use in 4lanes+1lane, rather than 2+2.
The pinmux header here was generated from a spreadsheet provided by
Colorado Engineering using the tegra-pinmux scripts. The spreadsheet
was converted from v09 to v11 by me.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
Signed-off-by: Tom Warren <twarren@nvidia.com>
The board ID EEPROM and board ID stickers on p2771-0000 will use a numeric
versioning scheme, with version numbers such as 000/100/200/300/400/500.
Within NVIDIA, these versions are also known as A00/A01/A02/A03/A04/B00.
However, that numbering scheme is not easily visible outside of NVIDIA,
and so does not make much sense to use. Convert U-Boot to use the readily
visible numeric scheme.
Also, it turns out that the current A02 DT actually applies to board
versions 000/100/200 (A00..A02). Consequently rename this to 000 not 200
so that all U-Boot builds are named after the first version of the HW they
support.
The eMMC on sLD3 is assigned with dedicated pins (only multiplexed
with GPIO), so it shouldn't hurt to enable eMMC on SPL all the time.
The revision of the original support card (rev 3.5, rev 3.6) fits in
the 8 bit width revision register. When it was extended in a weird
way, it was versioned in the format of "3.6.x" (where it should have
been "3.7", of course). What is worse, only the sub-level version
"6.x" was recorded in the 8 bit width register, completely ignoring
the compatibility of the revision register format.
This patch saves madly-versioned support cards by assuming the major
version "3" when the MSB 4 bit of the register is read as "6". With
this, the support card revision that were displayed as "6.10" is now
corrected to "3.6.10".
This supports the system reset via PSCI for ARMv7 SoCs.
Because the system reset is not supported on PSCI 0.1, let's define
CONFIG_ARMV7_PSCI_1_0. (it is supported since PSCI 0.2, but there
is no CONFIG to enable it in U-Boot for now.)
Most of them are my mistakes.
The page table is maintained by the CPU, hence it is safe to always
align cache flush to a whole cache line size. This allows to use
mmu_page_table_flush for a single page table, e.g. when configure
only small regions through mmu_set_region_dcache_behaviour.
Tested-by: Fabio Estevam <fabio.estevam@nxp.com>
Add LPAE support for mmu_set_region_dcache_behaviour. The function
is in use in some LPAE capable board such TI DRA7xx or NXP i.MX 7.
Use a tab not 8 spaces.
This series moves the CONFIG_SYS_CACHELINE_SIZE. First, in nearly all
cases we are mirroring the values used by the Linux Kernel here. Also,
so long as (and in this case, it is true) we implement flushes in hunks
that are no larger than the smallest implementation (and given that we
mirror the Linux Kernel, again we are fine) it is OK to align higher.
The biggest changes here are that we always use 64 bytes for CPU_V7 even
if for example the underlying core is only 32 bytes (this mirrors
Linux). Second, we say ARM64 uses 64 bytes not 128 (as found in the
Linux Kernel) as we do not need multi-platform support (to this degree)
and only the Cavium ThunderX 88xx series has a use for such large
alignment.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Luka Perkov <luka.perkov@sartura.hr>
Cc: Steve Rae <steve.rae@raedomain.com>
Cc: Stefan Agner <stefan.agner@toradex.com>
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Peter Griffin <peter.griffin@linaro.org>
Acked-by: Paul Kocialkowski <contact@paulk.fr>
Acked-by: "Pali Rohár" <pali.rohar@gmail.com>
Cc: Grazvydas Ignotas <notasas@gmail.com>
Cc: Nishanth Menon <nm@ti.com>
Cc: Stephen Warren <swarren@wwwdotorg.org>
Cc: Robert Baldyga <r.baldyga@samsung.com>
Cc: David Feng <fenghua@phytium.com.cn>
Cc: Alison Wang <b18965@freescale.com>
Cc: York Sun <york.sun@nxp.com>
Cc: Shengzhou Liu <Shengzhou.Liu@nxp.com>
Cc: Mingkai Hu <mingkai.hu@nxp.com>
Cc: Prabhakar Kushwaha <prabhakar.kushwaha@nxp.com>
Cc: Aneesh Bansal <aneesh.bansal@freescale.com>
Cc: Saksham Jain <saksham.jain@nxp.com>
Cc: Qianyu Gong <qianyu.gong@nxp.com>
Cc: Wang Dongsheng <dongsheng.wang@nxp.com>
Cc: Alex Porosanu <alexandru.porosanu@freescale.com>
Cc: Hongbo Zhang <hongbo.zhang@nxp.com>
Cc: tang yuantian <Yuantian.Tang@freescale.com>
Cc: Rajesh Bhagat <rajesh.bhagat@nxp.com>
Cc: Josh Wu <josh.wu@atmel.com>
Cc: Bo Shen <voice.shen@atmel.com>
Cc: Viresh Kumar <viresh.kumar@linaro.org>
Cc: Christophe Ricard <christophe-h.ricard@st.com>
Cc: Anand Moon <linux.amoon@gmail.com>
Cc: Beniamino Galvani <b.galvani@gmail.com>
Cc: Carlo Caione <carlo@endlessm.com>
Cc: huang lin <hl@rock-chips.com>
Cc: Sjoerd Simons <sjoerd.simons@collabora.co.uk>
Cc: Xu Ziyuan <xzy.xu@rock-chips.com>
Cc: "jk.kernel@gmail.com" <jk.kernel@gmail.com>
Cc: "Ariel D'Alessandro" <ariel@vanguardiasur.com.ar>
Cc: Kever Yang <kever.yang@rock-chips.com>
Cc: Chin Liang See <clsee@altera.com>
Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
Cc: Hans de Goede <hdegoede@redhat.com>
Cc: Ian Campbell <ijc@hellion.org.uk>
Cc: Siarhei Siamashka <siarhei.siamashka@gmail.com>
Cc: Boris Brezillon <boris.brezillon@free-electrons.com>
Cc: Andre Przywara <andre.przywara@arm.com>
Cc: Bernhard Nortmann <bernhard.nortmann@web.de>
Cc: Tom Warren <twarren@nvidia.com>
Cc: Alexander Graf <agraf@suse.de>
Cc: Vitaly Andrianov <vitalya@ti.com>
Cc: "Andrew F. Davis" <afd@ti.com>
Cc: Murali Karicheri <m-karicheri2@ti.com>
Cc: Carlos Hernandez <ceh@ti.com>
Cc: Gong Qianyu <Qianyu.Gong@freescale.com>
Acked-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Acked-by: Chin Liang See <clsee@altera.com>
The H3 PLL5 used for DRAM barely manages to lock to the required
frequency before DRAM controller starts, sometimes leading to wrong
delay-line calibration results.
This patch changes the PLL tuning parameters to the same values as
boot0 used, which speeds up the locking and fixes the problem.
Signed-off-by: Jens Kuske <jenskuske@gmail.com>
When the backlight's pwm input is connected to a pwm output of the SoC,
actually use pwm to drive the backlight.
The mean reason for doing this is to fix the backlight turning off
for aprox. 1 second while the kernel is booting. This is caused by
the kernel actually using pwm to drive the backlight, so that it
can dim the backlight. First the pwm driver loads and switches the
pinmux for the pin driving the backlight's pwm input to the pwm
controller. Then about 1s later the actual backlight driver loads
and tells the pwm driver to actually update the pwm settings, which
have a power-on-reset value of "off".
An additional advantage is that this allows us to initatiate the
backlight at 80%, which is the kernel default, avoiding a brightness
change while the kernel loads.
Reviewed by: Peter Korsgaard <peter@korsgaard.com>
Add a defconfig and dts file for the Empire Electronix M712 tablet, this
is a 7" A13 tablet, with micro-usb (otg), headphone and micro-sd slots on
the outside. It uses a Goodix gt811 touchscreen controller, a RTL8188CTV
wifi chip and a DMART06 (1238a4) accelerometer.
The dts file is identical to the one submitted to the upstream kernel.
Sync dts files with the current (Aug 18th 2016) state of Maxime's
linux/sunxi/for-next repo.
Note this commit also updates configs/MSI_Primo81_defconfig,
adding: "# CONFIG_REQUIRE_SERIAL_CONSOLE is not set", this is necessary
because the tablet does not have a reachable uart so the dts sync
drops its serial0 alias.
Acked-by: Ian Campbell <ijc@hellion.org.uk>
Add a defconfig and dts file for tablets using the generic inet-q972 PCB.
Tablets with this PCB feature a mini-hdmi output, micro-usb usb-host,
micro-usb usb-otg, 3.5mm headphone jack, a micro sd slot,
(mini) power-barrel and an usb wifi module.
This has been tested on a 9.7" 1024x768 qware qw tb9718-qhd tablet.
