The echo -ne "\xNN" does not work in certain bourne-compatible shells, like
dash. The recommended way of hex->char conversion is using printf(1), but
there is a pitfall here. The GNU printf does support "\xNN" format, but
according to the opengroup documentation, this is not part of POSIX. The
POSIX printf only defines "\NNN" where N is octal. Thus, for the sake of
compatibility, we use that.
Move all the gpio definitions to driver file as
there is no use of them in other files.
Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com>
Remove non driver model support as it moved
to driver model. Dont need non driver model
anymore.
Enable DM GPIO and ZYNQ GPIO using kconfig instead of the board
config file.
Support ZynqMP zc1751 with DC cards.
Add new board support.
There are mini configurations which need to be fit to OCM that's why
these options shouldn't be enabled by default.
Add missing nand node for ep108.
Signed-off-by: Punnaiah Choudary Kalluri <punnaia@xilinx.com>
This patch adds the sata port phy OOB timing values in the sata
device-tree node.
Signed-off-by: Anurag Kumar Vulisha <anuragku@xilinx.com>
Enable option to support more then 4GB memories in single size block.
Use the same binding as is used in mainline Linux kernel.
For run time serdes adjustment.
Separate register space and put it on more lines.
Add some default properties to zynqmp.dtsi.
Signed-off-by: Hyun Kwon <hyun.kwon@xilinx.com>
Reflect actual silicon addresses in DT node names.
Use right addresses for channel names
Mainline kernel has no r1p12 compatible string that's why console stops
to work with the latest DTS files. Append generic compatible string.
Keep in your mind that using this generic compatible string not all uart
features will be available.
Modifying device tree node to support legacy interrupts.
Signed-off-by: Bharat Kumar Gogada <bharatku@xilinx.com>
Signed-off-by: Ravi Kiran Gummaluri <rgummal@xilinx.com>
GPIO driver supports an input interrupt that's why gpio node itself can
be labeled as interrupt controller.
Reported-by: John Linn <linnj@xilinx.com>
This patch adds ddrc memory controller node in dts.
size mentioned in dts is 0x30000, because we need to access DDR_QOS
INTR registers located at fd090208 from this driver.
Signed-off-by: Naga Sureshkumar Relli <nagasure@xilinx.com>
ZynqMP DMA's main clock and apb clock are added
in zynqmp DT.
Signed-off-by: VNSL Durga <vnsldurg@xilinx.com>
Acked-by: Punnaiah Choudary Kalluri <punnaia@xilinx.com>
Add CCI-400 node to DTSI.
ZynqMP is not using global interrupt-parent setting that's why
it has to be listed in every node separately. PMU node missed it and
this patch is adding it.
Reported-by: John Linn <John.Linn@xilinx.com>
Add power-domains to the DT and attach devices to them.
The power-domains are all logical domains as understood by firmware.
Each PD is identified by a unique identifier that the platform firmware
understands.
Signed-off-by: Soren Brinkmann <soren.brinkmann@xilinx.com>
This patch adds broken-tuning property to SD and
eMMC nodes.
Signed-off-by: P L Sai Krishna <lakshmis@xilinx.com>
Remove jumbo properties which are handled in the driver directly
and use mainline compatible string which is already handled by the
driver.
Signed-off-by: Edgar E. Iglesias <edgar.iglesias@xilinx.com>
This patch add 8-bit bus width property to eMMC node.
This patch makes compatible string as "m25p80" for qspi node in
ep108 device tree file
Signed-off-by: Ranjit Waghmode <ranjit.waghmode@xilinx.com>
Add missing mmc aliases.
Change the dtsi include code to use the C pre-processor #include instead
of the device tree /include/. This brings all ZynqMP device trees inline
with each other.
Signed-off-by: Alistair Francis <alistair.francis@xilinx.com>
Reviewed-by: Sören Brinkmann <soren.brinkmann@xilinx.com>
Compatible property should be the first.
Add missing DT nodes and enable USB.
Reviewed-by: Nathan Rossi <nathan@nathanrossi.com>
Add missing qspi node and make qspi as spi0.
Sync with others zynq DTS files.
Keep nodes alphabelitally sorted.
Add missing adv7511 and configure to match Base TRD.
Signed-off-by: Christian Kohn <christian.kohn@xilinx.com>
Add bindings for adv7511.
Added phy reset gpio information for gem0.
- Sync with Linux kernel
- Remove rootfs
- Remove earlyprintk
- Have compatible string as the first property
- Sync with Linux kernel dtsi
- Add missing interrupt properties
Added addtional bindings required for FPGA Manager operation
of the Xilinx Zynq Devc configuration interface.
Signed-off-by: Moritz Fischer <moritz.fischer@ettus.com>
Add MVEBU_TWSI1_BASE define so that the 2nd I2C controller on e.g. AXP
can be used.
