path: root/arch/arm/mach-zynq/u-boot-spl.lds
2016-03-16spl: arm: Make sure to include all of the u_boot_list entriesTom Rini
Starting with 96e5b03 we use a linker list for partition table information. However since we use this in SPL we need to make sure that the SPL linker scripts include these as well. While doing this, it's best to simply include all linker lists to future proof ourselves. Cc: Andreas Bießmann <andreas.devel@googlemail.com> Acked-by: Michal Simek <michal.simek@xilinx.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reported-by: Nishanth Menon <nm@ti.com> Tested-by: Nishanth Menon <nm@ti.com> Signed-off-by: Tom Rini <trini@konsulko.com>
2015-11-04dm: arm: zynq: Enable device tree control in SPLSimon Glass
Move to using device tree control in SPL so that we can use the same driver code in both SPL and U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-29ARM: zynq: move SoC sources to mach-zynqMasahiro Yamada
Move arch/arm/cpu/armv7/zynq/* -> arch/arm/mach-zynq/* Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
