path: root/arch/arm/mach-zynq/ddrc.c
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-30arm: zynq: Update years in copyright to reflect latest changesMichal Simek
Updating year in zynq files. Also add missing Copyright to board.c. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2017-06-20arm: zynq: Add Kconfig option for any DDR specific initializationSiva Durga Prasad Paladugu
Add Kconfig option for ddr init as this might be required in cases like ddr less systems where we want to skip ddrc init and this option is useful for it. Signed-off-by: Siva Durga Prasad Paladugu <sivadur@xilinx.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2016-01-27ARM: zynq: Remove memory division by 2 for ECC caseMichal Simek
For ECC case u-boot divided memory by 2 because one u-boot could be used for both cases when ECC is off or on. Remove this division and make sure that dts file contain the correct memory size when ECC is enabled. Signed-off-by: Michal Simek <michal.simek@xilinx.com>
2015-04-29ARM: zynq: move SoC sources to mach-zynqMasahiro Yamada
Move arch/arm/cpu/armv7/zynq/* -> arch/arm/mach-zynq/* Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Michal Simek <michal.simek@xilinx.com>
