path: root/arch/arm/mach-uniphier/sc-regs.h
2016-03-24ARM: uniphier: drop PH1- prefix from CONFIG options and file namesMasahiro Yamada
The current CONFIG names like "CONFIG_ARCH_UNIPHIER_PH1_PRO4" is too long. It would not hurt to drop "PH1_" because "UNIPHIER_" already well specifies the SoC family. Also, rename files for consistency. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-01-13ARM: uniphier: move headers out of include/mach directoryMasahiro Yamada
These headers are only included locally in arch/arm/mach-uniphier/. There is no reason to export them by putting in the mach/ directory. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
