path: root/arch/arm/mach-uniphier/clk/clk-dram-pro5.c
2019-07-10ARM: uniphier: de-couple SC macros into base address and offsetMasahiro Yamada
The SC_* macros represent the address of SysCtrl registers. For a planned new SoC, its base address will be changed. Turn the SC_* macros into the offset from the base address. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-01-17ARM: uniphier: split out UMC clock enableMasahiro Yamada
The clock enable bits for UMC are more SoC-specific than for the other hardware blocks. Separate the UMC clocks and the other clocks for better code reuse across SoCs. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
