path: root/arch/arm/mach-uniphier/boot-device/boot-device.c
2017-10-15ARM: uniphier: use pr_() instead of printf() where appropriateMasahiro Yamada
Replace printf() with pr_() to specify proper loglevel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-20ARM: uniphier: remove sLD3 SoC supportMasahiro Yamada
This SoC is too old. It is difficult to maintain any longer. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-05-17ARM: uniphier: add more init code for PXs3Masahiro Yamada
Add the boot device table and reset deassertion for eMMC. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-04-20ARM: uniphier: show STM (SCP) status on boot and pinmon commandMasahiro Yamada
The SCP (System Control Processor) or what we call STM (Stand-by MPU) is integrated in LD4, Pro4, sLD8, LD6b, LD11, and LD20. For these SoCs, show the information if STM is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: rework spl_boot_device() and related codeMasahiro Yamada
The current implementation has ugly switch statements here and there, and duplicates similar code. Rework it using table lookups for SoC data and reduce code duplication. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
