path: root/arch/arm/mach-uniphier/board_late_init.c
2020-02-28ARM: uniphier: remove workaround for the NAND write protectMasahiro Yamada
This workaround was previously needed for LD4, Pro4, sLD8, Pro5 SoCs. The boot ROM does not touch this register for PXs2/LD6b or later. Now that the reset signal of the Denali NAND controller is always asserted in board_init() then deasserted in the driver, the WRITE_PROTECT register gets back to the default value, which means the write protect is deasserted. This workaround can go away entirely. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-12-02common: Move some board functions out of common.hSimon Glass
A number of board function belong in init.h with the others. Move them. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2019-08-11env: Move env_set_hex() to env.hSimon Glass
Move env_set_hex() over to the new header file along with env_set_addr() which uses it. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Joe Hershberger <joe.hershberger@ni.com>
2019-07-10ARM: uniphier: set {kernel, ramdisk, fdt}_addr_r at boot-timeMasahiro Yamada
The base of DRAM will be changed for the next generation SoC. The addresses needed for booting the kernel should be shifted according to the DRAM base. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: set dram_base environment variableMasahiro Yamada
The base of DRAM will be changed for the next generation SoC. Set the base address to the 'dram_base' environment variable, which will be useful for scripting. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: set loadaddr at boot-timeMasahiro Yamada
The base of DRAM will be changed for the next generation SoC. To support it along with existing SoCs in the single defconfig, set 'loadaddr' at boot-time by adding the offset to the DRAM base. CONFIG_SYS_LOAD_ADDR is still hard-coded for compilation, but the value from environment variable 'loadaddr' should be used. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: turn uniphier_set_fdt_file() into void functionMasahiro Yamada
For consistency with a function that will be added. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2019-07-10ARM: uniphier: detect SD boot modeMasahiro Yamada
The planned new SoC supports the SD boot mode. Detect and display it. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-12-29ARM: uniphier: do not modify bootcmd environment variable at run-timeMasahiro Yamada
Some users might want to modify 'bootcmd' at compile-time by editing include/configs/uniphier.h, but overwriting it at run-time makes it impossible. Instead, set 'bootdev' at run-time, which contains the boot device the system is booting from, then indirectly reference it from 'bootcmd'. It is up to users whether to override 'bootcmd'. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-09-20mtd: move NAND files into a raw/ subdirectoryMiquel Raynal
NAND flavors, like serial and parallel, have a lot in common and would benefit to share code. Let's move raw (parallel) NAND specific code in a raw/ subdirectory, to ease the addition of a core file in nand/ and the introduction of a spi/ subdirectory specific to SPI NANDs. Signed-off-by: Miquel Raynal <miquel.raynal@bootlin.com>
2018-07-25ARM: uniphier: enable distro bootMasahiro Yamada
Switch to the distro boot for UniPhier platform. - Remove the environment vairalbes used to load images from raw block devices. - Keep the command to download images via tftp. This will be useful to boot the kernel when no valid kernel image is ready yet in the file system. - Use root.cpio.gz instead of root.cpio.uboot because we always know the file size of the init ramdisk; it is loaded via either a file system or network. - Rename fit_addr_r to kernel_addr_r, which the distro command checks to get the load address of FIT image. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-05-23ARM: uniphier: rename environment variable fdt_file to fdtfileMasahiro Yamada
For booting Linux in the generic distro mechanism, cmd/pxe.c retrieves the FDT file name from "fdtfile" environment variable. Rename "fdt_file" to "fdtfile" for easier migration to distro boot. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-10-15ARM: uniphier: use pr_() instead of printf() where appropriateMasahiro Yamada
Replace printf() with pr_() to specify proper loglevel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-08-16env: Rename getenv/_f() to env_get()Simon Glass
We are now using an env_ prefix for environment functions. Rename these two functions for consistency. Also add function comments in common.h. Quite a few places use getenv() in a condition context, provoking a warning from checkpatch. These are fixed up in this patch also. Suggested-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-20ARM: uniphier: show STM (SCP) status on boot and pinmon commandMasahiro Yamada
The SCP (System Control Processor) or what we call STM (Stand-by MPU) is integrated in LD4, Pro4, sLD8, LD6b, LD11, and LD20. For these SoCs, show the information if STM is enabled. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-02-23ARM: uniphier: rework spl_boot_device() and related codeMasahiro Yamada
The current implementation has ugly switch statements here and there, and duplicates similar code. Rework it using table lookups for SoC data and reduce code duplication. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-29ARM: uniphier: adjust fdt_file environment handling to latest LinuxMasahiro Yamada
The environment fdt_file is useful to remember the appropriate DTB file name. Adjust it to the recent renaming in the upstream kernel. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-09ARM: uniphier: do not overwrite fdt_file environmentMasahiro Yamada
This code auto-detects the best-match FDT file name, but it should respect the user's choice if "fdt_file" environment is found in a saved set of environments. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-06-09ARM: uniphier: check return code of setenv()Masahiro Yamada
Because setenv() may fail, it is better to check its return code. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24ARM: uniphier: rework uniphier_set_fdt_file()Masahiro Yamada
The current table look-up for the DTB file name turned out bothersome in terms of maintainability; I ended up adding a new entry every time a new board is supported. There is a common pattern between the DT compatible string and the corresponding file name; drop the vendor prefix "socionext," and prefix it with "uniphier-" and suffix it with ".dtb". Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-04-24ARM: uniphier: carry on booting for Unknown boot modeMasahiro Yamada
No need to stop booting U-Boot even if boot mode is unknown. Setting the "bootmode" environment is only useful for booting Linux Kernel. Anyway, U-Boot has already booted by this point. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: uniphier: add support for PH1-Pro4 Ace and Sanji boardsMasahiro Yamada
Initial commit for PH1-Pro4 Ace and Sanji boards. Note: There are two variants for the Ace board in terms of the amount of DDR memory; 1GB or 2GB. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2016-02-14ARM: uniphier: support USB boot mode for ProXstream2 / PH1-LD6b SoCMasahiro Yamada
The USB boot code is too fat and complicated to be included in SPL (at least for now). So, it was implemented as a separate project (what we call USB-loader). The expected boot sequence is as follows: Boot ROM -> USB-loader -> SPL -> U-Boot proper The USB-loader loads the SPL and U-Boot proper from a USB memory onto the locked L2 cache. Then, SPL needs to copy the U-Boot proper to DRAM, so this mode looks like a NOR boot from the view of SPL. However, we want to distinguish between (genuine) NOR boot and USB boot in some places. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-12-23ARM: uniphier: set DTB file name to fdt_file environmentMasahiro Yamada
When we want to boot Linux with a DTB file downloaded from a TFTP server or somewhere, we need to know the file name to be downloaded. Assume the U-Boot configuration is shared among some similar boards. If they are similar enough, the difference only appears in device trees. The build procedure would be like this: - Board A: make foo_common_defconfig && make DEVICE_TREE=foo_board_a - Board B: make foo_common_defconfig && make DEVICE_TREE=foo_board_b - Board C: make foo_common_defconfig && make DEVICE_TREE=foo_board_c In this case, the U-Boot image contains nothing about the DTB file name it is running with. (CONFIG_DEFAULT_DEVICE_TREE is not helpful for this purpose because it is painful to change it from "make menuconfig" for each board.) This commit allows to lookup the DTB file name based on the compatible string and set it to "fdt_file" environment. Then "tftpboot $fdt_file" will download the file we want. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-05-31ARM: UniPhier: replace <asm/io.h> with <linux/io.h>Masahiro Yamada
In the Linux coding style, it is recommended to include <linux/io.h> rather than <asm/io.h>. Follow this trend. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-03-01ARM: UniPhier: move SoC sources to mach-uniphierMasahiro Yamada
Move arch/arm/cpu/armv7/uniphier/* -> arch/arm/mach-uniphier/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
