Make sure TPS62362 set 0 defaults to 1.200V as the Linux kernel may
switch to set 0 using TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to
TPS62362 VSEL1 prior to actually setting it to a sane value dependent on
the current CPU frequency.
Fix the following boot hang observed when booting our downstream L4T
R16.5 based BSP:
[ 0.900129] kernel BUG at /build/linuxdev/oe-core_V2.7/build/tmp-
glibc/work-shared/colibri-t20/kernel-source/drivers/spi/spi-tegra.c:258!
[ 0.912478] Internal error: Oops - undefined instruction: 0 [#1]
PREEMPT SMP
[ 0.919525] Modules linked in:
[ 0.922586] CPU: 0 Not tainted (3.1.10-v2.7b1+g7e628fd #1)
[ 0.928428] PC is at spi_tegra_isr.part.0+0x14/0x18
[ 0.933310] LR is at spi_tegra_isr+0x38/0x7c
[ 0.937580] pc : [<c05c25e8>] lr : [<c0334d4c>] psr: 60000193
[ 0.937585] sp : c8075c40 ip : c8075c50 fp : c8075c4c
[ 0.949062] r10: c08a2f20 r9 : c08a2f74 r8 : 00000000
[ 0.954285] r7 : c8074000 r6 : c81545c0 r5 : c08a2f74 r4 : c81545b0
[ 0.960810] r3 : 00000000 r2 : 00000001 r1 : 60000193 r0 : 60000193
[ 0.967336] Flags: nZCv IRQs off FIQs on Mode SVC_32 ISA ARM
Segment kernel
[ 0.974734] Control: 10c5387d Table: 0000404a DAC: 00000015
While at it also fix the following clock initialisation related errors:
[ 0.000000] tegra_dvfs: rate 216000000 too high for dvfs on sdmmc1
[ 0.000000] Unable to set clock sdmmc1 to rate 48000000: -22
[ 0.000000] tegra_dvfs: rate 216000000 too high for dvfs on sdmmc3
[ 0.000000] Unable to set clock sdmmc3 to rate 48000000: -22
Just release TPS65911 GPIO1 (EN_CORE_DVFS_N) connected to TPS62362
VSEL1 to switch VDD_CORE back to boot set 1 defaulting to 1.200V.
(cherry picked from commit 622d408fea7af6d2ed778b546de346e90ea1a21f)
Implement early TPS6586X PMIC rail configuration setting SM0 being
VDD_CORE_1.2V to 1.2 volts and SM1 being VDD_CPU_1.0V to 1.0 volts.
While those are PMIC power-up defaults the SoC might have been reset
separately with certain rails being left at lower DVFS states which
is e.g. the case upon watchdog reset while otherwise nearly idling.
(cherry picked from commit f7c3186985ebb244d075b04ed7c055f39f485670)
R16.5 based BSP:
[ 4.174349] tegra_dvfs: rate 408000000 too high for dvfs on sbc1
Migrating our BSPs towards mainline U-Boot I noticed it suddenly booting
slower. With mainline Linux I noticed about a 1 to 2 second increase
while booting downstream L4T takes 10 to 15 seconds longer!
This reverts commit 858530a8c0a7ce7e573e513934804a00d6676813.
drivers/serial/Makefile
(cherry picked from commit 752aae30a791326581efafbb761c0cebaba8d3ea)
drivers/serial/serial_tegra.c
include/configs/tegra-common.h
(cherry picked from commit 4b97c4173ef96cfa4eb3ba4ea9121320efa90091)
This patch adds board support for the Toradex Apalis TK1 a computer on
module which can be used on different carrier boards.
The module consists of a Tegra TK1 SoC, a PMIC solution, 2 GB of DDR3L
RAM, a bunch of level shifters, an eMMC, a TMP451 temperature sensor
chip, an I210 gigabit Ethernet controller and a SGTL5000 audio codec.
Furthermore, there is a Kinetis MK20DN512 companion micro controller for
analogue, CAN and resistive touch functionality.
For the sake of ease of use we do not distinguish between different
carrier boards for now as the base module features are deemed
sufficient enough for regular booting.
The following functionality is working so far:
- eMMC boot, environment storage and Toradex factory config block
- Gigabit Ethernet
- MMC/SD cards (both MMC1 as well as SD1 slot)
- USB client/host (dual role OTG port as client e.g. for DFU/UMS or host,
other two ports as host)
An SMC call is required for all cache-wide operations on Tegra186. This
patch implements the two missing hooks now that U-Boot supports them, and
fixes the mapping of "hook name" to SMC call code.
Signed-off-by: Tom Warren <twarren@nvidia.com>
SoC-specific logic may be required for all forms of cache-wide
operations; invalidate and flush of both dcache and icache (note that
only 3 of the 4 possible combinations make sense, since the icache never
contains dirty lines). This patch adds an optional hook for all
implemented cache-wide operations, and renames the one existing hook to
better represent exactly which operation it is implementing. A dummy
no-op implementation of each hook is provided.
When performing a cache disable function, code must not access DRAM.
That is because when the cache is disabled, it will be bypassed and all
loads and stores will be serviced by RAM. This prevents accessing any
dirty data in the cache. In turn, this means the stack cannot be
used, since that is in RAM. To guarantee that code doesn't use RAM (and
in particular the stack) __asm_flush_l3_cache() must be manually
implemented in assembly, rather than implemented in C since the compiler
won't know not to touch RAM.
nvtboot_boot_x0 is a 64-bit variable and hence must be 64-bit aligned.
So far this has happened by accident! Fix the code so this is guaranteed.
This fixes the following build error:
... relocation truncated to fit: R_AARCH64_LDST64_ABS_LO12_NC
against symbol `nvtboot_boot_x0' ...
On Tegra186, the bootloader which runs before U-Boot passes the Ethernet
MAC address to U-Boot using device tree. Extract this value and write it
to the environment, so that the Ethernet uclass picks it up and uses it
for the built-in Ethernet device.
Extend the Tegra186 implementation of board_late_init() to call a per-SoC
"hook" function. This will allow SoC-specific (rather than Tegra-wide)
functionality to be implemented without the core Tegra code needing to be
aware of the details. While board186.c is currently only used for
Tegra186, it should be applicable to any other future SoC, and perhaps its
simple design could be back-ported to older SoCs in the future too.
Add 'PCI' as a menu option and migrate all existing users.
Commit b02e4044ff8e ("libfdt: Bring in upstream stringlist
functions") broke codying style in some places especially
by inserting an extra whitespace before fdt_stringlist_count().
The signature for this macro has changed. Bring in the upstream version and
adjust U-Boot's usages to suit.
Update to drivers/power/pmic/palmas.c:
Signed-off-by: Keerthy <j-keerthy@ti.com>
Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
These have now landed upstream. The naming is different and in one case the
function signature has changed. Update the code to match.
This applies the following upstream commits by
Thierry Reding <treding@nvidia.com> :
604e61e fdt: Add functions to retrieve strings
8702bd1 fdt: Add a function to get the index of a string
2218387 fdt: Add a function to count strings
ARM CPUs can architecturally (speculatively) prefetch completely arbitrary
normal memory locations, as defined by the current translation tables. The
current MMU configuration for 64-bit Tegras maps an extremely large range
of addresses as DRAM, well beyond the actual physical maximum DRAM window,
even though U-Boot only needs access to the first 2GB of DRAM; the Tegra
port of U-Boot deliberately limits itself to 2GB of RAM since some HW
modules on at least some 64-bit Tegra SoCs can only access a 32-bit
physical address space. This change reduces the amount of RAM mapped via
the MMU to disallow the CPU from ever speculatively accessing RAM that
U-Boot will definitely not access. This avoids the possibility of the HW
raising SError due to accesses to always-invalid physical addresses.
On Tegra186, it is necessary to perform an SMC to fully flush all caches;
flushing/cleaning by set/way is not enough. Implement the required hook
to make this happen.
Implementations of the standard clock and reset APIs are available on all
Tegra SoCs now, so enable compilation of those uclasses.
Enable the Tegra CAR drivers for all SoCs prior to the BPMP being
available. This provides an implementation of those APIs everywhere.
Make clock_get_periph_rate() return the correct value for UART clocks.
This change needs to be applied before the patches that enable CONFIG_CLK
for Tegra SoCs before Tegra186, since enabling that option causes
ns16550_serial_ofdata_to_platdata() to rely on clk_get_rate() for UART
clocks, and clk_get_rate() eventually calls clock_get_periph_rate().
This change is a rather horrible hack, as explained in the comment added
to the clock driver. I've tried fixing this correctly for all clocks as
described in that comment, but there's too much fallout elsewhere. I
believe the clock driver has a number of bugs which all cancel each-other
out, and unravelling that chain is too complex at present. This change is
the smallest change that fixes clock_get_periph_rate() for UART clocks
while guaranteeing no change in behaviour for any other clock, which
avoids other regressions.
A future patch will implement a clock uclass driver for Tegra. That driver
will call into Tegra's existing clock code to simplify the transition;
this avoids tieing the clock uclass patches into significant refactoring
of the existing custom clock API implementation.
Some of the Tegra clock APIs that manipulate peripheral clocks require
both the peripheral clock ID and parent clock ID to be passed in together.
However, the clock uclass API does not require any such "parent"
parameter, so the clock driver must determine this information itself.
This patch implements new Tegra- specific clock API
clock_get_periph_parent() for this purpose.
The new API is implemented in the core Tegra clock code rather than SoC-
specific clock code. The implementation uses various SoC-/clock-specific
data. That data is only available in SoC-specific clock code.
Consequently, two new internal APIs are added that enable the core clock
code to retrieve this information from the SoC-specific clock code. Due to
the structure of the Tegra clock code, this leads to some unfortunate code
duplication. However, this situation predates this patch.
Ideally, future work will de-duplicate the Tegra clock code, and migrate
it into drivers/clk/tegra. However, such refactoring is kept separate from
this series.
Currently, Tegra peripheral drivers control two aspects of their HW module
clock(s):
1) The clock enable/rate for the peripheral clock itself.
2) The system-level clock tree setup, i.e. the clock parent.
Aspect 1 is reasonable, but aspect 2 is a system-level decision, not
something that an individual peripheral driver should in general know
about or influence. Such system-level knowledge ties the driver to a
specific SoC implementation, even when they use generic APIs for clock
manipulation, since they must have SoC-specific knowledge such as parent
clock IDs. Limited exceptions exist, such as where peripheral HW is
expected to dynamically switch between clock sources at run-time, such
as CPU clock scaling or display clock conflict management in a multi-head
scenario.
This patch enhances the Tegra core code to perform system-level clock
tree setup, in a similar fashion to the Linux kernel Tegra clock driver.
This will allow future patches to simplify peripheral drivers by removing
the clock parent setup logic.
This change is required prior to converting peripheral drivers to use the
standard clock APIs, since:
1) The clock uclass doesn't currently support a set_parent() operation.
Adding one is possible, but not necessary at the moment.
2) The clock APIs retrieve all clock IDs from device tree, and the DT
bindings for almost all peripherals only includes information about the
relevant peripheral clocks, and not any potential parent clocks.
Convert the Tegra MMC driver to DM_MMC. Support for non-DM is removed
to avoid ifdefs in the code. DM_MMC is now enabled for all Tegra builds.
Cc: Jaehoon Chung <jh80.chung@samsung.com>
(swarren, fixed some NULL pointer dereferences, removed extraneous
changes, rebased on various other changes, removed non-DM support etc.)
Most other pin mux is configured in this function. This removes the
need to do it in an MMC-specific initialization function, which is good
since that function is going away later in this series.
pad_init_mmc() is performing an SoC-specific operation, using registers
within the MMC controller. There's no reason to implement this code
outside the MMC driver, so move it inside the driver.
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Move this option to Kconfig and tidy up existing uses.
Add ARCH_SUPPORT_PSCI as a non-configurable option that platforms
can select. Then, move CONFIG_ARMV7_PSCI, which is automatically
enabled if both ARMV7_NONSEC and ARCH_SUPPORT_PSCI are enabled.
Reviewed-by: Alexander Graf <agraf@suse.de>
SPL_BUILD is not a CONFIG in Kconfig, so !SPL_BUILD is always true.
The Colorado TK1 SOM is a small form factor board similar to the
Jetson TK1. The main differences lie in the pinmux, and in that the
PCIe controller is set to use in 4lanes+1lane, rather than 2+2.
The pinmux header here was generated from a spreadsheet provided by
Colorado Engineering using the tegra-pinmux scripts. The spreadsheet
was converted from v09 to v11 by me.
Signed-off-by: Peter Chubb <peter.chubb@data61.csiro.au>
The L4T kernel complains about a CSITE clock rate above 144MHz, presumably
because the HW is only characterized for a clock less than that. Adjust the
rate to 136MHz to avoid the warning and stay in spec.
Signed-off-by: Bryan Wu <pengw@nvidia.com>
(swarren, re-wrote commit description)
Currently, ft_system_setup() is implemented by board*.c, which are a bit
of a dumping ground for a bunch of unrelated functionality, and separate
versions exist for pre-Tegra186 and Tegra186. Move the implementation into
a separate file to separate functionality, and allow sharing.
In Tegra186, on-SoC reset signals are manipulated using IPC requests to
the BPMP (Boot and Power Management Processor). This change implements a
driver that does that. It is unconditionally selected by CONFIG_TEGRA186
since virtually any Tegra186 build of U-Boot will need the feature.
In Tegra186, on-SoC clocks are manipulated using IPC requests to the BPMP
(Boot and Power Management Processor). This change implements a driver
that does that. A tegra/ sub-directory is created to follow the existing
pattern. It is unconditionally selected by CONFIG_TEGRA186 since virtually
The Tegra BPMP (Boot and Power Management Processor) is a separate
auxiliary CPU embedded into Tegra to perform power management work, and
controls related features such as clocks, resets, power domains, PMIC I2C
bus, etc. This driver provides the core low-level communication path by
which feature-specific drivers (such as clock) can make requests to the
BPMP. This driver is similar to an MFD driver in the Linux kernel. It is
unconditionally selected by CONFIG_TEGRA186 since virtually any Tegra186
As part of testing booting Linux kernels on Rockchip devices, it was
discovered by Ziyuan Xu and Sandy Patterson that we had multiple and for
some cases incomplete isb definitions. This was causing a failure to
boot of the Linux kernel.
In order to solve this problem as well as cover any corner cases that we
may also have had a number of changes are made in order to consolidate
things. First, <asm/barriers.h> now becomes the source of isb/dsb/dmb
definitions. This however introduces another complexity. Due to
needing to build SPL for 32bit tegra with -march=armv4 we need to borrow
the __LINUX_ARM_ARCH__ logic from the Linux Kernel in a more complete
form. Move this from arch/arm/lib/Makefile to arch/arm/Makefile and add
a comment about it. Now that we can always know what the target CPU is
capable off we can get always do the correct thing for the barrier. The
final part of this is that need to be consistent everywhere and call
isb()/dsb()/dmb() and NOT call ISB/DSB/DMB in some cases and the
function names in others.
Acked-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Acked-by: Sandy Patterson <apatterson@sightlogix.com>
Reported-by: Ziyuan Xu <xzy.xu@rock-chips.com>
Reported-by: Sandy Patterson <apatterson@sightlogix.com>
Introduce tegra_board_init() and call it from board_init(). Tegra wil use
tegra_board_init() for board-specific initialization, and board_init() for
SoC-specific initialization.
On Tegra186, U-Boot is booted by the binary firmware as if it were a
Linux kernel. Consequently, a DTB is passed to U-Boot. Cache the address
of that DTB, and parse the /memory/reg property to determine the actual
RAM regions that U-Boot and subsequent EL2/EL1 SW may actually use.
Given the binary FW passes a DTB to U-Boot, I anticipate the suggestion
that U-Boot use that DTB as its control DTB. I don't believe that would
work well, so I do not plan to put any effort into this. By default the
FW-supplied DTB is the L4T kernel's DTB, which uses non-upstreamed DT
bindings. U-Boot aims to use only upstreamed DT bindings, or as close as
it can get. Replacing this DTB with a DTB using upstream bindings is
physically quite easy; simply replace the content of one of the GPT
partitions on the eMMC. However, the binary FW at least partially relies
on the existence/content of some nodes in the DTB, and that requires the
DTB to be written according to downstream bindings. Equally, if U-Boot
continues to use appended DTBs built from its own source tree, as it does
for all other Tegra platforms, development and deployment is much easier.
IVC (Inter-VM Communication) protocol is a Tegra-specific IPC (Inter
Processor Communication) framework. Within the context of U-Boot, it is
typically used for communication between the main CPU and various
auxiliary processors. In particular, it will be used to communicate with
the BPMP (Boot and Power Management Processor) on Tegra186 in order to
manipulate clocks and reset signals.
Many files in arch/arm/mach-tegra are compiled conditionally based on
Kconfig variables, or applicable to all platforms. We can let the main
Tegra Makefile handle compiling (or not) those files to avoid each SoC-
specific Makefile needing to duplicate entries for those files. This
leaves the SoC-specific Makefiles to compile truly SoC-specific code.
In the future, we'll hopefully add Kconfig variables for all the other
files, and refactor those files, and so reduce the need for SoC-specific
Makefiles and/or ifdefs in the Makefiles.
arch/arm/cpu/armv8/Makefile
arch/arm/lib/bootm-fdt.c
Fix a number of typos, including:
* "compatble" -> "compatible"
* "eanbeld" -> "enabled"
* "envrionment" -> "environment"
* "FTD" -> "FDT" (for "flattened device tree")
* "ommitted" -> "omitted"
* "overriden" -> "overridden"
* "partiton" -> "partition"
* "propogate" -> "propagate"
* "resourse" -> "resource"
* "rest in piece" -> "rest in peace"
* "suport" -> "support"
* "varible" -> "variable"
Introduce virtual and physical addresses in the mapping table. This change
have no impact on existing boards because they all use idential mapping.
Signed-off-by: York Sun <york.sun@nxp.com>
Now that we have a secure data section and space to store per-CPU target
PC address, switch to it instead of storing the target PC on the stack.
Also save clobbered r4-r7 registers on the stack and restore them on
return in psci_cpu_on for Tegra, i.MX7, and LS102xA platforms.
Signed-off-by: Chen-Yu Tsai <wens@csie.org>
