path: root/arch/arm/mach-tegra/xusb-padctl-common.c
2020-05-18common: Drop log.h from common headerSimon Glass
Move this header out of the common header. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-11dm: core: Add ofnode_for_each_subnode()Simon Glass
Add a convenience macro to iterate over subnodes of a node. Make use of this where appropriate in the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-07-28dm: tegra: Convert USB setup to livetreeSimon Glass
Adjust this code to support a live device tree. This should be implemented as a PHY driver but that is left as an exercise for the maintainer. Signed-off-by: Simon Glass <sjg@chromium.org> Tested-by: Stephen Warren <swarren@nvidia.com>
2016-10-24Fix codying style broken by recent libfdt syncMasahiro Yamada
Commit b02e4044ff8e ("libfdt: Bring in upstream stringlist functions") broke codying style in some places especially by inserting an extra whitespace before fdt_stringlist_count(). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-13libfdt: Sync fdt_for_each_subnode() with upstreamSimon Glass
The signature for this macro has changed. Bring in the upstream version and adjust U-Boot's usages to suit. Signed-off-by: Simon Glass <sjg@chromium.org> Update to drivers/power/pmic/palmas.c: Signed-off-by: Keerthy <j-keerthy@ti.com> Change-Id: I6cc9021339bfe686f9df21d61a1095ca2b3776e8
2016-10-13libfdt: Bring in upstream stringlist functionsSimon Glass
These have now landed upstream. The naming is different and in one case the function signature has changed. Update the code to match. This applies the following upstream commits by Thierry Reding <treding@nvidia.com> : 604e61e fdt: Add functions to retrieve strings 8702bd1 fdt: Add a function to get the index of a string 2218387 fdt: Add a function to count strings Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-12ARM: tegra: create common XUSB padctl driver fileStephen Warren
A fair amount of the XUSB padctl driver will be common between Tegra124 and Tegra210. To avoid cut/paste between the two chips, create a new file that will contain the common code, and convert the Tegra124 code to use it. This change doesn't move every last piece of code that can/will be shared, but rather concentrates on moving code that can be moved with zero changes, so there are no other diffs mixed in. Signed-off-by: Stephen Warren <swarren@nvidia.com> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
