path: root/arch/arm/mach-tegra/psci.S
2018-05-07tegra: psci: save context id in cpu_on commandPatrick Delaunay
Replace the psci_save_target_pc call by the new function psci_save(cpu, pc,context_id) Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2016-07-15ARM: PSCI: Switch to per-CPU target PC storage in secure data sectionChen-Yu Tsai
Now that we have a secure data section and space to store per-CPU target PC address, switch to it instead of storing the target PC on the stack. Also save clobbered r4-r7 registers on the stack and restore them on return in psci_cpu_on for Tegra, i.MX7, and LS102xA platforms. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-07-15ARM: PSCI: Remove unused psci_text_end symbolChen-Yu Tsai
psci_text_end was used to calculate the PSCI stack address following the secure monitor text. Now that we have an explicit secure stack section, this is no longer used. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2016-07-15ARM: PSCI: Split out common stack setup code from psci_arch_initChen-Yu Tsai
Every platform has the same stack setup code in assembly as part of psci_arch_init. Move this out into a common separate function, psci_stack_setup, for all platforms. This will allow us to move the remaining parts of psci_arch_init into C code, or drop it entirely. Also provide a stub no-op psci_arch_init for platforms that don't need their own specific setup code. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Hans de Goede <hdegoede@redhat.com>
2015-05-13tegra: Set CNTFRQ for secondary CPUsJan Kiszka
We only set CNTFRQ in arch_timer_init for the boot CPU. But this has to happen for all cores. Fixing this resolves problems of KVM with emulating the generic timer/counter. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Reviewed-by: Tom Rini <trini@konsulko.com> Reviewed-by: Thierry Reding <treding@nvidia.com> Tested-by: Thierry Reding <treding@nvidia.com> Tested-by: Ian Campbell <ijc@hellion.org.uk> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-05-13tegra124: Add PSCI support for Tegra124Jan Kiszka
This is based on Thierry Reding's work and uses Ian Campell's preparatory patches. It comes with full support for CPU_ON/OFF PSCI services. The algorithm used in this version for turning CPUs on and off was proposed by Peter De Schrijver and Thierry Reding in http://thread.gmane.org/gmane.comp.boot-loaders.u-boot/210881. It consists of first enabling CPU1..3 via the PMC, just to powergate them again with the help of the Flow Controller. Once the Flow Controller is in place, we can leave the PMC alone while processing CPU_ON and CPU_OFF PSCI requests. Signed-off-by: Jan Kiszka <jan.kiszka@siemens.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
