path: root/arch/arm/mach-tegra/pmc.c
2019-06-05ARM: tegra: Support TZ-only access to PMCThierry Reding
Some devices may restrict access to the PMC to TrustZone software only. Non-TZ software can detect this and use SMC calls to the firmware that runs in the TrustZone to perform accesses to PMC registers. Note that this also fixes reset_cpu() and the enterrcm command on Tegra186 where they were previously trying to access the PMC at a wrong physical address. Based on work by Kalyani Chidambaram <kalyanic@nvidia.com> and Tom Warren <twarren@nvidia.com>. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
