path: root/arch/arm/mach-tegra/cache.c
2019-06-05ARM: tegra: Guard GP pad control code with a Kconfig symbolThierry Reding
The GP pad control code is not relevant on all Tegra SoC generations, so guard it with a Kconfig symbol that can be selected by the generations that need it. This is in preparation for unifying Tegra186 code with the code used on older generations. Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2016-01-19Add more SPDX-License-Identifier tagsTom Rini
In a number of places we had wordings of the GPL (or LGPL in a few cases) license text that were split in such a way that it wasn't caught previously. Convert all of these to the correct SPDX-License-Identifier tag. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-07-28ARM: Tegra210: Add support to common Tegra source/config filesTom Warren
Derived from Tegra124, modified as appropriate during T210 board bringup. Cleaned up debug statements to conserve string space, too. This also adds misc 64-bit changes from Thierry Reding/Stephen Warren. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <treding@nvidia.com> Signed-off-by: Stephen Warren <swarren@nvidia.com>
2015-02-21ARM: tegra: collect SoC sources into mach-tegraMasahiro Yamada
This commit moves files as follows: arch/arm/cpu/arm720t/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/arm720t/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/arm720t/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/arm720t/tegra124* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/arm720t/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/armv7/tegra20/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/armv7/tegra30/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/armv7/tegra114/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/armv7/tegra124/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/armv7/tegra-common/* -> arch/arm/mach-tegra/* arch/arm/cpu/tegra20-common/* -> arch/arm/mach-tegra/tegra20/* arch/arm/cpu/tegra30-common/* -> arch/arm/mach-tegra/tegra30/* arch/arm/cpu/tegra114-common/* -> arch/arm/mach-tegra/tegra114/* arch/arm/cpu/tegra124-common/* -> arch/arm/mach-tegra/tegra124/* arch/arm/cpu/tegra-common/* -> arch/arm/mach-tegra/* Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Tested-by: Simon Glass <sjg@chromium.org> [ on nyan-big ] Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
