path: root/arch/arm/mach-sunxi
2018-02-07spl: eMMC/SD: Provide one __weak spl_boot_mode() functionLukasz Majewski
The goal of this patch is to clean up the code related to choosing SPL MMC boot mode. The spl_boot_mode() now is called only in spl_mmc_load_image() function, which is only compiled in if CONFIG_SPL_MMC_SUPPORT is enabled. To achieve the goal, all per mach/arch implementations eligible for unification has been replaced with one __weak implementation. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> (For ZynqMP) Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2017-12-02sunxi: set the default CPUx frequency of H5 to 816MHzIcenowy Zheng
Some H5 boards are designed to start at 1.1V CPUx voltage (e.g. Nano Pi NEO2), which may not work properly at 1008MHz if the chip's quality is not so good. Lower the default CPUx frequency of H5 to 816MHz. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-10-27sunxi: video: add LCD support to DE2 driverVasily Khoruzhick
Extend DE2 driver with LCD support. Tested on Pinebook which is based on A64 and has ANX6345 eDP bridge with eDP panel connected to it. Signed-off-by: Vasily Khoruzhick <anarsoul@gmail.com> [agust: rebased v5 on u-boot-video/master] Signed-off-by: Anatolij Gustschin <agust@denx.de>
2017-10-26sunxi: setup simplefb for Allwinner DE2Icenowy Zheng
As the support of EFI boot on Allwinner H3 is broken, we still need to use simplefb to pass the framebuffer to Linux. Add code to setup simplefb for Allwinner DE2 driver. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-26video: add an option for video simplefb via DTIcenowy Zheng
Add an option to indicate that the video driver should setup a SimpleFB node that passes the video framebuffer initialized by U-Boot to the operating system kernel. Currently only the Allwinner DE driver uses this option, and the definition of this option in the sunxi-common.h config header is converted to an imply of this option from CONFIG_VIDEO_SUNXI. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-10-26sunxi: change the DE1 video option to CONFIG_VIDEO_SUNXIIcenowy Zheng
The sunxi DE1 video option used to be CONFIG_VIDEO, which has the same name as the "Enable legacy video support" option in drivers/video/Kconfig. Change the option name to CONFIG_VIDEO_SUNXI, which is really used by Makefile under drivers/video/sunxi/, and defined in sunxi-common.h when CONFIG_VIDEO is selected before this change. Now CONFIG_VIDEO_SUNXI selects CONFIG_VIDEO and the usages of CONFIG_VIDEO in sunxi Kconfig and config headers are all converted to use CONFIG_VIDEO_SUNXI. Signed-off-by: Icenowy Zheng <icenowy@aosc.io>
2017-10-03sunxi: usb_phy: invert the USB phy_ctl conditionMaxime Ripard
All the new SoCs from Allwinner since the A33 have had the phy_ctl offset at 0x410 instead of 0x404 that was used on the previous SoCs. Instead of adding more and more special cases as the number of SoCs grow, let's invert the test to have 0x410 by default, and the (hopefully) fixed number of old SoCs being the exception. Suggested-by: Siarhei Siamashka <siarhei.siamashka@gmail.com> Suggested-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-10-03arm: sunxi: Move spl_boot_device in a separate functionMaxime Ripard
U-Boot itself might need to identify the boot device, for example to be able to tell where to load the kernel from when several options are possible. Move the logic of spl_boot_device to a function that is compiled both for the SPL and the main binary. Tested-by: Chen-Yu Tsai <wens@csie.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-08-28sunxi: Enable MMC new mode for A83TMaxime Ripard
The eMMC controller for the A83T uses the new operating mode. Enable it. Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-08-16Merge git://git.denx.de/u-boot-sunxiTom Rini
Update A20-OLinuXino-Lime2-eMMC_defconfig to include CONFIG_SCSI Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-15env: Convert CONFIG_ENV_IS_IN... to a choiceSimon Glass
At present we support multiple environment drivers but there is not way to select between them at run time. Also settings related to the position and size of the environment area are global (i.e. apply to all locations). Until these limitations are removed we cannot really support more than one environment location. Adjust the location to be a choice so that only one can be selected. By default the environment is 'nowhere', meaning that the environment exists only in memory and cannot be saved. Also expand the help for the 'nowhere' option and move it to the top since it is the default. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Move all of the imply logic to default X if Y so it works again] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-08-13spl: add hierarchical defaults for SPL_LDSCRIPTPhilipp Tomsich
With SPL_LDSCRIPT moved to Kconfig (and this being a 'string' config node), all the lingering definitions in header files will cause warnings/errors due to the redefinition of the configuration item. As we don't want to pollute the defconfig files (and values should usually be identical for entire architectures), the defaults are moved into Kconfig. Kconfig will always pick the first default that matches, so please keep these values at the end of each file (to allow any board-specific Kconfig, which will be included earlier) to override with an unconditional default setting. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2017-08-11sunxi: switch PRCM to non-secure on H3/H5 SoCsIcenowy Zheng
The PRCM of H3/H5 SoCs have a secure/non-secure switch, which controls the access to some clock/power related registers in PRCM. Current Linux kernel will access the CPUS (AR100) clock in the PRCM block, so the PRCM should be switched to non-secure. Add code to switch the PRCM to non-secure. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Tested-by: Chen-Yu Tsai <wens@csie.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-06-08sunxi: add LPDDR3 timing from stock boot0Icenowy Zheng
As we added LPDDR3 support in the former patch, we need a set of timing info to really enable it. Add the timing info used by stock boot0. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Acked-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: add LPDDR3 DRAM type support for DesignWare-like DRAM controllerIcenowy Zheng
Some A64 boards (SoPine and Pinebook production batch) use LPDDR3 DRAM chips. Add support for LPDDR3 DRAM in the DesignWare-like DRAM controller code. Real LPDDR3 chips' support is not added yet in this commit. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: enable DRAM initialization and SPL for V3s SoCIcenowy Zheng
As we have already support for the DesignWare DRAM controller and the integrated DDR2 chip of V3s, let's enable the SPL support for V3s. This patch also contains the default DRAM configuration for V3s. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: add support for V3s DRAM controllerIcenowy Zheng
Allwinner V3s features a DRAM controller like the on in H3, but with a DDR2 DRAM. Add support for it. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: add support for the DDR2 in V3s SoCIcenowy Zheng
Allwinner V3s SoC features a co-packaged DDR2 DRAM chip, which needs its timing param. Add support for it. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Acked-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: enable dual rank detection in DesignWare-like DRAM codeIcenowy Zheng
The DesignWare-like DRAM code used to set the controller defaultly to single rank mode, which makes it not able to detect the second rank. Set the default value to dual rank, thus the rank detection code can work and finally the rank setting will be the correct value. Currently we know little about the dual-rank on R40, and the usage of A15 address line seems to be breaking dual-rank support. The only R40 board currently available (Sinovoip Banana Pi M2 Ultra) uses A15 rather than dual-rank, thus we cannot do research for it. So dual rank detection is temporarily disabled on R40. This change is tested on a Orange Pi One (H3, single rank), a Pine64+ 2GiB version (A64, single rank) , a Pinebook early prototype with DDR3 (A64, dual rank) and a SoPine with some LPDDR3 patch (A64, dual CS pins on one chip). Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: Add selective DRAM type and timingIcenowy Zheng
DRAM chip varies, and one code cannot satisfy all DRAMs. Add options to select a timing set. Currently only DDR3-1333 (the original set) is added into it. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: add bank detection code to H3 DRAM initialization codeIcenowy Zheng
Some DDR2 DRAM have only four banks, not eight. Add code to detect this situation. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: add option for 16-bit DW DRAM controllerIcenowy Zheng
Some Allwinner SoCs features a DesignWare-like controller with only 16 bit bus width. Add support for them. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: Rename bus-width related macros in H3 DRAM codeIcenowy Zheng
The DesignWare DRAM controller used by H3 and newer SoCs use a bit to identify whether the DRAM is half-width. As H3 itself come with 32-bit DRAM, the two modes of the bit used to be named "MCTL_CR_32BIT" and "MCTL_CR_16BIT", but for SoCs with 16-bit DRAM they're really 8-bit and 16-bit. Rename the bit's macro, and also rename the variable name in dram_sun8i_h3.c. This commit do not add 16-bit DRAM controller support, but the support will be introduced in next commit. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-06-08sunxi: makes an invisible option for H3-like DRAM controllersIcenowy Zheng
Allwinner SoCs after H3 (e.g. A64, H5, R40, V3s) uses a H3-like DesignWare DRAM controller, which do not have official free DRAM initialization code, but can use modified dram_sun8i_h3.c. Add a invisible option for easier DRAM initialization code reuse. Signed-off-by: Icenowy Zheng <icenowy@aosc.xyz> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@amarulasolutions.com> Tested-by: Jagan Teki <jagan@amarulasolutions.com>
2017-05-17sunxi: enable automatic FIT build for 64-bit SoCsAndre Przywara
The Allwinner SoCs with 64-bit cores use an ARM Trusted Firmware binary, which needs to be loaded alongside U-Boot proper. Set the respective Kconfig options to let them select this feature and also automatically build the FIT image. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> [Rename Kconfig path to arch/arm/mach-sunxi/Kconfig] Signed-off-by: Jagan Teki <jagan@openedev.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-05-02sunxi: add clock configuration of R40 sataIcenowy Zheng
R40 has a similar SATA controller with the ones on A10/A20, but with a reset line added (like other peripherals on sun6i+), and two extra VDD pins added (1.2v and 2.5v). Add clock configuration of R40 SATA. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-02ARM: sunxi: use imply instead of bare default y in KconfigMasahiro Yamada
Fix annoying config redefines in SoC/board level Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-05-02ARM: sunxi: move board/sunxi/Kconfig to arch/arm/mach-sunxi/KconfigMasahiro Yamada
For the consistent location of SoC-level Kconfig. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-28sunxi: i2c: Add support for DM I2CJernej Skrabec
This commit adds support for DM I2C on sunxi platform. It can coexist with old style sunxi I2C driver, because it is still used in SPL and by some SoCs. Because sunxi platform doesn't yet support DM clk, reset and pinctrl driver, workaround is needed to enable clocks and set resets and pinctrls. This is done by calling i2c_init_board() in board_init(). This means that CONFIG_I2Cx_ENABLE options needs to be correctly set in order to use needed I2C controller. Commit is based on the previous patch made by Philipp Tomsich Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Heiko Schocher <hs@denx.de> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-21sunxi: add basic V3s supportIcenowy Zheng
Basic U-Boot support is now present for V3s. Some memory addresses are changed specially for V3s, as the original address map cannot fit into a so small DRAM. As the DRAM controller code needs a big refactor, the SPL support is disabled in this version. Signed-off-by: Icenowy Zheng <icenowy@aosc.io> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add clock support for DE2/HDMI/TCON on newer SoCsJernej Skrabec
This is needed for HDMI, which will be added later. Signed-off-by: Jernej Skrabec <jernej.skrabec@siol.net> Reviewed-by: Simon Glass <sjg@chromium.org> Signed-off-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Use H3/A64 DRAM initialization code for R40Chen-Yu Tsai
The R40 seems to have a variant of the memory controller found in the H3 and A64 SoCs. Adapt the code for use on the R40. The changes are based on released DRAM code and comparing register dumps from boot0. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Set PLL lock enable bits for R40Chen-Yu Tsai
According to the BSP released by Banana Pi, the R40 (sun8iw11p1) has an extra "PLL lock control" register in the CCU, which controls whether the individual PLL lock status bits in each PLL's control register work or not. This patch enables it for all the PLLs. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Fix watchdog reset function for R40Chen-Yu Tsai
The watchdog found on the R40 SoC is the older variant found on the A20. Add the proper "#if defines" to make it work. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Enable AXP221s in I2C mode with the R40 SoCChen-Yu Tsai
The R40 SoC uses the AXP221s in I2C mode to supply power. Some regulator's common usages have changed, and also the recommended voltage for existing usages have changed. Update the defaults to match. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-20sunxi: Add initial support for R40Chen-Yu Tsai
The R40 is the successor to the A20. It is a hybrid of the A20, A33 and the H3. The R40's PIO controller is compatible with the A20, Reuse the A20 UART and I2C muxing code by adding the R40's macro. The display pipeline is the newer DE 2.0 variant. Block enabling video on R40 for now. Signed-off-by: Chen-Yu Tsai <wens@csie.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-05sunxi: introduce Allwinner H5 config optionAndre Przywara
The Allwinner H5 Soc is bascially an H3 with high SRAM and ARMv8 cores. As the peripherals and the pinmuxing are almost identical, we piggy back on the shared MACH_SUN8I_H3_H5 config symbol. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05sunxi: prepare for sharing MACH_SUN8I_H3 config symbolAndre Przywara
The Allwinner H5 is very close to the H3 SoC, but has ARMv8 cores. To allow sharing the clocks, GPIO and driver code easily, create an architecture agnostic MACH_SUNXI_H3_H5 Kconfig symbol. Rename the existing symbol to MACH_SUNXI_H3_H5 where code is shared and let it be selected by a new shared Kconfig option. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-05sunxi: DRAM: add Allwinner H5 supportAndre Przywara
The DRAM controller in the Allwinner H5 SoC is again very similar to the one in the H3 and A64. Based on the existing socid parameter, add support for this controller by reusing the bulk of the code and only deviating where needed. These new bits set or cleared here and there have been mostly found by looking at DRAM register dumps after using the H5 boot0 and comparing them to what we set in the code. So for now it's mostly unclear what those bits actually mean - hence the missing names and comments. Also add the delay line parameters taken from the boot0 and libdram disassembly. Register setup differences between H5 and H3 are courtesy of Jens Kuske. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-05sunxi: provide ARMv8 mem_map for every ARM64 boardAndre Przywara
Every armv8 board needs the memory map, so change the #ifdef to ARM64 to avoid enumerating every single board or SoC. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-04-05sunxi: simplify ACTLR.SMP bit set #ifdefAndre Przywara
Instead of enumerating all SoC families that need that bit set, let's just express this more clearly: The SMP bits needs to be set on SMP capable ARMv7 CPUs. It's much easier in Kconfig to express it the other way round, so we use ! CPU_IS_UP and ! ARM64. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com>
2017-04-05sunxi: fix ACTLR.SMP assembly routineAndre Przywara
If we take the liberty to use register r0 to perform our bit set, we should be nice enough to tell the compiler about it. Add r0 to the clobber list to avoid potential mayhem. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Acked-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: A64: enable SPLAndre Przywara
Now that the SPL is ready to be compiled in AArch64 and the DRAM init code is ready, enable SPL support for the A64 SoC and in the Pine64 defconfig. For now we keep the boot0 header in the U-Boot proper, as this allows to still use boot0 as an SPL replacement without hurting the SPL use case. We disable FEL support for now by making its compilation conditional and disabling it for ARM64, as the code isn't ready yet. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: DRAM: fix H3 DRAM size display on aarch64Andre Przywara
Fix the output of the DRAM size on AArch64 SPLs. Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Alexander Graf <agraf@suse.de> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: H3/A64: fix non-ODT settingAndre Przywara
According to Jens disabling the on-die-termination should set bit 5, not bit 1 in the respective register. Fix this. Reported-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: A64: use H3 DRAM initialization code for A64 as wellJens Kuske
The A64 DRAM controller is very similar to the H3 one, so the code can be reused with some small changes. This refactoring does not change the code size for the existing H3 part. [Andre: rework from #ifdefs to using socid parameters in static functions, minor fixes, merging in fixes from Jens] Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: clocks: Use the correct pattern register for PLL11Philipp Tomsich
Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Acked-by: Maxime Ripard <maxime.ripard@free-electrons.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: H3: add DRAM controller single bit delay supportJens Kuske
So far the DRAM driver for the H3 SoC (and apparently boot0/libdram as well) only applied coarse delay line settings, with one delay value for all the data lines in each byte lane and one value for the control lines. Instead of setting the delays for whole bytes only allow setting it for each individual bit. Also add support for address/command lane delays. For the purpose of this patch the rules for the existing coarse settings were just applied to the new scheme, so the actual register writes don't change for the H3. Other SoCs will utilize this feature later properly. With a stock GCC 5.3.0 this increases the dram_sun8i_h3.o code size from 2296 to 2344 Bytes. [Andre: move delay parameters into macros to ease later sharing, use defines for numbers of delay registers, extend commit message] Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2017-01-04sunxi: H3: add and rename some DRAM contoller registersJens Kuske
The IOCR registers got renamed to BDLR to match the public documentation of similar controllers. Signed-off-by: Jens Kuske <jenskuske@gmail.com> Signed-off-by: Andre Przywara <andre.przywara@arm.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
