path: root/arch/arm/mach-stm32mp/include/mach/gpio.h
2018-12-07gpio: stm32f7: Move STM32_GPIOS_PER_BANK into gpio.hPatrice Chotard
To allow access to this define by other driver, move it into gpio.h Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-12-07gpio: stm32f7: Add gpio bank holes managementPatrice Chotard
In some STM32 SoC packages, GPIO bank has not always 16 gpios. Several cases can occur, gpio hole can be located at the beginning, middle or end of the gpio bank or a combination of these 3 configurations. For that, gpio bindings offer the gpio-ranges DT property which described the gpio bank mapping. Signed-off-by: Patrice Chotard <patrice.chotard@st.com>
2018-03-19arm: stm32: add new architecture for STM32MP familyPatrick Delaunay
- add new arch stm32mp for STM32 MPU/Soc based on Cortex A - support for stm32mp157 SOC - SPL is used as first boot stage loader - using driver model for all the drivers, even in SPL - all security feature are deactivated (ETZC and TZC) - reused STM32 MCU drivers when it is possible Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
