path: root/arch/arm/mach-socfpga
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2018-02-26ARM: socfpga: Add new CycloneV SoC Devboards DBM-SoC1 boardMarek Vasut
Add support for a new boards from devboards.de , the DBM-SoC1 . This board has one ethernet port, one USB OTG port and USB UART. Signed-off-by: Marek Vasut <marex@denx.de>
2018-02-07spl: eMMC/SD: Provide one __weak spl_boot_mode() functionLukasz Majewski
The goal of this patch is to clean up the code related to choosing SPL MMC boot mode. The spl_boot_mode() now is called only in spl_mmc_load_image() function, which is only compiled in if CONFIG_SPL_MMC_SUPPORT is enabled. To achieve the goal, all per mach/arch implementations eligible for unification has been replaced with one __weak implementation. Signed-off-by: Lukasz Majewski <lukma@denx.de> Reviewed-by: Marek Vasut <marex@denx.de> Reviewed-by: Stefano Babic <sbabic@denx.de> Acked-by: Michal Simek <michal.simek@xilinx.com> (For ZynqMP) Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
2018-01-26ARM: socfpga: Convert callers of cm_write_with_phase for wait_for_bit_le32Tom Rini
Now that we have and use wait_for_bit_le32() available, the callers of cm_write_with_phase() should not be casting values to u32 and instead we expect a const void *, so provide that directly. Fixes: 48263504c8d5 ("wait_bit: use wait_for_bit_le32 and remove wait_for_bit") Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2018-01-26Merge git://git.denx.de/u-boot-spiTom Rini
2018-01-26SOCFPGA: clock manager: implement dw_spi_get_clk functionEugeniy Paltsev
Implement dw_spi_get_clk function to override its weak implementation in designware_spi.c driver. We need this change to get rid of cm_get_spi_controller_clk_hz function and clock_manager.h include in designware_spi.c driver. Reviewed-by: Marek Vasut <marex@denx.de> Signed-off-by: Eugeniy Paltsev <Eugeniy.Paltsev@synopsys.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-24wait_bit: use wait_for_bit_le32 and remove wait_for_bitÁlvaro Fernández Rojas
wait_for_bit callers use the 32 bit LE version Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com> Reviewed-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Reviewed-by: Jagan Teki <jagan@openedev.com>
2018-01-09arm: socfpga: Guard commands with CONFIG_SPL_BUILD testsTom Rini
In order for these commands to not be included in SPL we need to guard compilation with CONFIG_SPL_BUILD checks. Reorganize some sections of code slightly in order to avoid new warnings and mark the command functions as static as they should have been before. Cc: Marek Vasut <marex@denx.de> Signed-off-by: Tom Rini <trini@konsulko.com>
2017-11-21socfpga: boot0 hook: adjust to unified boot0 semanticsPhilipp Tomsich
With the updated boot0 semantics (i.e. giving the boot0-hook control over when and where the vector table is emitted), the boot0-hook for the socfpga needs to be adjusted. Signed-off-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2017-10-04treewide: replace with error() with pr_err()Masahiro Yamada
U-Boot widely uses error() as a bit noisier variant of printf(). This macro causes name conflict with the following line in include/linux/compiler-gcc.h: # define __compiletime_error(message) __attribute__((error(message))) This prevents us from using __compiletime_error(), and makes it difficult to fully sync BUILD_BUG macros with Linux. (Notice Linux's BUILD_BUG_ON_MSG is implemented by using compiletime_assert().) Let's convert error() into now treewide-available pr_err(). Done with the help of Coccinelle, excluing tools/ directory. The semantic patch I used is as follows: // <smpl> @@@@ -error +pr_err (...) // </smpl> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Reviewed-by: Simon Glass <sjg@chromium.org> [trini: Re-run Coccinelle] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-09-23ARM: socfpga: fix duplicate const specifier warningMasahiro Yamada
GCC 7.1 warns: duplicate ‘const’ declaration specifier [-Wduplicate-decl-specifier] Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2017-07-26arm: socfpga: Add FPGA driver support for Arria 10Tien Fong Chee
Add FPGA driver support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-07-26arm: socfpga: Restructure FPGA driver in the preparation to support A10Tien Fong Chee
Move FPGA driver which is Gen5 specific code into Gen5 driver file and keeping common FPGA driver intact. All the changes are still keeping in driver/fpga/ and no functional change. Subsequent patch would move FPGA manager driver from arch/arm into driver/fpga/. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-07-26arm: socfpga: Remove unused passing parameter of socfpga_bridges_resetTien Fong Chee
Remove parameter from socfpga_bridges_reset(), and keeping this function for single purpose which is just triggering reset on bridges. socfpga_reset_deassert_bridges_handoff() can be called for releasing reset on any bridges based on the bridge setting defined in fdt. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Reviewed-by: Ley Foon Tan <ley.foon.tan@intel.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-05-22Convert CONFIG_SPL_BOARD_INIT to KconfigLey Foon Tan
This converts the following to Kconfig: CONFIG_SPL_BOARD_INIT Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com> [trini: Update the Kconfig logic] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-18arm: socfpga: Enable build for Arria 10Ley Foon Tan
Update Kconfig and Makefile to enable Arria 10. Clean up Makefile and sorting *.o alphanumerically. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add SPL support for Arria 10Ley Foon Tan
Add SPL support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add misc support for Arria 10Ley Foon Tan
Add misc support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add pinmux for Arria 10Ley Foon Tan
Add pinmux support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add sdram header file for Arria 10Ley Foon Tan
Add sdram header file for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add system manager for Arria 10Ley Foon Tan
Add system manager register struct and macros for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add clock driver for Arria 10Ley Foon Tan
Add clock driver support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add reset driver support for Arria 10Ley Foon Tan
Add reset driver support for Arria 10. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Add A10 macrosLey Foon Tan
Add i2c, timer and other A10 macros. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Restructure misc driverLey Foon Tan
Restructure misc driver in the preparation to support A10. Move the Gen5 specific code to gen5 file. Change all uint32_t_to u32. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Restructure system managerLey Foon Tan
Restructure system manager in the preparation to support A10. No functional change. Change uint32_t to u32. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Restructure reset manager driverLey Foon Tan
Restructure reset manager driver in the preparation to support A10. Move the Gen5 specific code to gen5 files. Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-05-18arm: socfpga: Restructure clock manager driverLey Foon Tan
Restructure clock manager driver in the preparation to support A10. Move the Gen5 specific code to _gen5 files. - Change all uint32_t to u32 and change to use macro BIT(n) for bit shift. - Check return value from wait_for_bit(). So change return type to int for cm_write_with_phase() and cm_basic_init(). Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-04-25arm: socfpga: add cyclone5 based de10-nano boardDalon Westergreen
Add support for the Terasic DE10-Nano board. The board is based on the DE0-Nano-Soc board but adds a larger FPGA and an HDMI output. Signed-off-by: Dalon Westergreen <dwesterg@gmail.com> Reviewed-by: Dinh Nguyen <dinguyen@kernel.org>
2017-04-14arm: socfpga: Convert Altera DDR SDRAM driver to use KconfigLey Foon Tan
Convert Altera DDR SDRAM driver to use Kconfig method. Enable ALTERA_SDRAM by default if it is on Gen5 target. Arria 10 will have different driver. Signed-off-by: Tien Fong Chee <tien.fong.chee@intel.com> Signed-off-by: Ley Foon Tan <ley.foon.tan@intel.com>
2017-04-14ARM: socfpga: Rename MCVEVKMarek Vasut
The board is now manufactured by Aries Embedded GmbH , rename it. Signed-off-by: Marek Vasut <marex@denx.de>
2017-04-14ARM: socfpga: boot0 hook: remove macro from boot0 header fileChee, Tien Fong
Commit ce62e57fc571 ("ARM: boot0 hook: remove macro, include whole header file") miss out cleaning macro in this header file, and this has broken implementation of a boot header capability in socfpga SPL. Remove the macro in this file, and recovering it back to proper functioning. Fixes: ce62e57fc571 ("ARM: boot0 hook: remove macro, include whole header file") Signed-off-by: Chee, Tien Fong <tien.fong.chee@intel.com>
2017-02-17SPL: add support to boot from a partition typeDalon Westergreen
the socfpga bootrom supports mmc booting from either a raw image starting at 0x0, or from a partition of type 0xa2. This patch adds support for locating the boot image in the first type 0xa2 partition found. Assigned a partition number of -1 will cause a search for a partition of type CONFIG_SYS_MMCSD_RAW_MODE_U_BOOT_PARTITION_TYPE and use it to find the u-boot image Signed-off-by: Dalon Westergreen <dwesterg@gmail.com>
2017-02-08arm: socfpga: set the mpuclk divider in the Altera group registerDinh Nguyen
The mpuclk register in the Altera group of the clock manager divides the mpu_clk that is generated from the C0 output of the main pll. Without this patch, the default value of the register is 1, so the mpuclk will always get divided by 2 if the correct value is not set. For example, on the Arria5 socdk board, the MPU clock is only 525 MHz, and it should be 1.05 GHz. Signed-off-by: Dinh Nguyen <dinguyen@kernel.org>
2016-12-06qts-filter.sh: strip DOS line endings and handle continuation linesBill Randle
Some Altera Quartus generated files have long lines that are split with a '\' at the end of the line. It also wOn Windows, rites files in DOS format, which can confuse some of the processing scripts in this file. This patch solves both issues. Signed-off-by: Bill Randle <bill.randle@gmail.com> Cc: Marek Vasut <marex@denx.de>
2016-12-06ARM: socfpga: Add boot0 hook to prevent SPL corruptionMarek Vasut
Valid Altera SoCFPGA preloader image must contain special data at offsets 0x40, 0x44, 0x48 and valid instructions at address 0x4c or 0x50. These addresses are by default used by U-Boot's vector table and a piece of reset handler, thus a valid preloader corrupts those addresses slightly. While this works most of the time, this can and does prevent the board from rebooting sometimes and triggering this issue may even depend on compiler. The problem is that when SoCFPGA performs warm reset, it checks the addresses 0x40..0x4b in SRAM for a valid preloader signature and header checksum. If those are found, it jumps to address 0x4c or 0x50 (this is unclear). These addresses are populated by the first few instructions of arch/arm/cpu/armv7/start.S: ffff0040 <data_abort>: ffff0040: ebfffffe bl ffff0040 <data_abort> ffff0044 <reset>: ffff0044: ea000012 b ffff0094 <save_boot_params> ffff0048 <save_boot_params_ret>: ffff0048: e10f0000 mrs r0, CPSR ffff004c: e200101f and r1, r0, #31 ffff0050: e331001a teq r1, #26 Without this patch, the CPU will enter the code at 0xffff004c or 0xffff0050 , at which point the value of r0 and r1 registers is undefined. Moreover, jumping directly to the preloader entry point at address 0xffff0000 will also fail, because address 0xffff004. is invalid and contains the preloader magic. Add BOOT0 hook which reserves the area at offset 0x40..0x5f and populates offset 0x50 with jump to the entry point. This way, the preloader signature is stored in reserved space and can not corrupt the SPL code. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Chin Liang See <clsee@altera.com> Cc: Dinh Nguyen <dinguyen@opensource.altera.com> Cc: Stefan Roese <sr@denx.de> Tested-by: Dinh Nguyen <dinguyen@opensource.altera.com>
2016-12-06socfpga: add support for Terasic DE1-SoC boardAnatolij Gustschin
Add CycloneV based Terasic DE1-SoC board. The board boots from SD/MMC. Ethernet and USB host is supported. Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Marek Vasut <marex@denx.de>
2016-10-31Fix spelling of "resetting".Vagrant Cascadian
Cover-Letter: Fixes several spelling errors for the words "resetting", "extended", "occur", and "multiple". Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-10-27ddr: altera: Configuring SDRAM extra cycles timing parametersChin Liang See
To enable configuration of sdr.ctrlcfg.extratime1 register which enable extra clocks for read to write command timing. This is critical to ensure successful LPDDR2 interface Signed-off-by: Chin Liang See <clsee@altera.com> Cc: Marek Vasut <marex@denx.de> Cc: Dinh Nguyen <dinguyen@opensource.altera.com>
2016-09-16Convert CONFIG_SPL_WATCHDOG_SUPPORT to KconfigSimon Glass
2016-09-16Convert CONFIG_SPL_LIBDISK_SUPPORT to KconfigSimon Glass
