path: root/arch/arm/mach-socfpga/wrap_pinmux_config.c
2015-08-23arm: socfpga: Make the pinmux table const u8Marek Vasut
Now that we're actually converting the QTS-generated header files, we can even adjust their data types. A good candidate for this is the pinmux table, where each entry can have value in the range of 0..3, but each element is declared as unsigned long. By changing the type to u8, we can save over 600 Bytes from the SPL, so do it. This patch also constifies the array. Signed-off-by: Marek Vasut <marex@denx.de>
2015-08-23arm: socfpga: Switch to filtered QTS filesMarek Vasut
2015-08-23arm: socfpga: Move wrappers into platform directoryMarek Vasut
Move the wrappers for QTS-generated files into platform directory out of the board directory. The trick here is to add -I to CFLAGS such that it points to the board directory in source tree and thus the qts/ directory there is still reachable. Signed-off-by: Marek Vasut <marex@denx.de>
