path: root/arch/arm/mach-socfpga/wrap_iocsr_config.c
2015-08-23arm: socfpga: Switch to filtered QTS filesMarek Vasut
2015-08-23arm: socfpga: Move wrappers into platform directoryMarek Vasut
Move the wrappers for QTS-generated files into platform directory out of the board directory. The trick here is to add -I to CFLAGS such that it points to the board directory in source tree and thus the qts/ directory there is still reachable. Signed-off-by: Marek Vasut <marex@denx.de>
