path: root/arch/arm/mach-socfpga/freeze_controller.c
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-08-23arm: socfpga: Fix delay in freeze controllerMarek Vasut
Based on observation, this udelay(20) was apparently too high and caused subsequent failure to calibrate DDR when U-Boot was compiled with certain toolchains. Lowering this delay fixed the problem. Instead of permanently lowering the delay, calculate the correct delay based on the original comment, that is, obtain EOSC1 frequency and use it to calculate the precise delay. Signed-off-by: Marek Vasut <marex@denx.de>
2015-05-07ARM: socfpga: move SoC sources to mach-socfpgaMasahiro Yamada
Our recent trend is to collect SoC files into arch/arm/mach-(SOC). Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
