path: root/arch/arm/mach-s5pc1xx/reset.S
2015-11-30arm: s5pc1xx: move SoC to mach-s5pc1xxMinkyu Kang
move arm/arm/cpu/armv7/s5pc1xx to arch/arm/mach-s5pc1xx Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
