path: root/arch/arm/mach-rockchip
2016-10-01rockchip: add boot-mode support for rk3288, rk3036Jacob Chen
rockchip platform have a protocol to pass the the kernel reboot mode to bootloader by some special registers when system reboot. In bootloader we should read it and take action. We can only setup boot_mode in board_late_init becasue "setenv" need env setuped. So add CONFIG_BOARD_LATE_INIT to common header and use a entry "rk_board_late_init" to replace "board_late_init" in board file. Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: move common function from board-file to rk3036-board.cJacob Chen
To keep it same with 3288 Signed-off-by: Jacob Chen <jacob2.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: rename board.c to rk3288-board.cJacob Chen
2016-10-01Disable SPL_MMC_SUPPORT if ROCKCHIP_SPL_BACK_TO_BROM is enabled.Sandy Patterson
Default SPL_MMC_SUPPORT to false when ROCKCHIP_SPL_BACK_TO_BROM is enabled. Acked-by: Ziyuan Xu <xzy.xu@rock-chips.com> Signed-off-by: Sandy Patterson <apatterson@sightlogix.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: Fix SPL console output when ROCKCHIP_SPL_BACK_TO_BROM is enabledSandy Patterson
Move back_to_bootrom() call later in SPL init so that the console is initialized and printouts happen. Currently when ROCKCHIP_SPL_BACK_TO_BROM is enabled there is no console output from the SPL init stages. I wasn't sure exactly where this should happen, so if we are set to do run spl_board_init, then go back to bootrom there after preloader_console_init(). Otherwise fall back to old behavior of doing it in board_init_f. Signed-off-by: Sandy Patterson <apatterson@sightlogix.com> Acked-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-10-01rockchip: rk3288: sdram: fix DDR address rangeXu Ziyuan
The all current Rockchip SoCs supporting 4GB of ram have problems accessing the memory region 0xfe000000~0xff000000. Actually, some IP controller can't address to, so let's limit the available range. This patch fixes a bug which found in miniarm-rk3288-4GB board. The U-Boot was relocated to 0xfef72000, and .bss variants was also relocated, such as do_fat_read_at_block. Once eMMC controller transfer data to do_fat_read_at_block via DMA, DMAC can't access more than 0xfe000000. So that DMAC didn't work sane. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-09-22rockchip: rk3288: skip lowlevel_init processXu Ziyuan
lowlevel_init() is never needed for rk3288, so drop it. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-09-22rk3288: add arch_cpu_init for rk3288Kever Yang
We do some SoC level one time setting initialization in arch_cpu_init. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-22rk3399: syscon: add support for pmugrfKever Yang
pmugrf is a module like grf which contain some of the iomux registers and other registers. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-09-16Convert CONFIG_SPL_DRIVERS_MISC_SUPPORT to KconfigSimon Glass
2016-08-12drivers/sysreset: group sysreset driversMax Filippov
Create drivers/sysreset and move sysreset-uclass and all sysreset drivers there. Signed-off-by: Max Filippov <jcmvbkbc@gmail.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-05rockchip: add support for rk3288 miniarm boardXu Ziyuan
Miniarm is a rockchip rk3288 based development board, which has lots of interface such as HDMI, USB, micro-SD card, Audio etc. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-08-05rk3399: add basic soc driverKever Yang
This patch add driver for: - clock driver including set_rate for cpu, mmc, vop, I2C. - sysreset driver - grf syscon driver Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: add support for rk3288 PopMetal boardjk.kernel@gmail.com
PopMetal is a rockchip rk3288 based board made by ChipSpark, which has many interface such as HDMI, VGA, USB, micro-SD card, WiFi, Audio and Gigabit Ethernet. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: add basic support for fennec-rk3288 boardjk.kernel@gmail.com
Fennec is a RK3288-based development board with 2 USB ports, HDMI, micro-SD card, audio and WiFi and Gigabit Ethernet. It also includes on-board 8GB eMMC and 2GB of SDRAM. Expansion connectors provides access to display pins, I2C, SPI, UART and GPIOs. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31rockchip: rk3288: move evb board to rockchip folderjk.kernel@gmail.com
The 'evb-rk3288' is not a vendor name, change it to 'rockchip' which is the real vendor name. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-31Revert "rockchip: Move the MMC setup check earlier"jk.kernel@gmail.com
Boot Rom wouldn't initialize sdmmc while booting from eMMC. We need to setup sdmmc gpio, otherwise we will hit an error below: =>mmc info blk_get_device: if_type=6, devnum=0: dwmmc@ff0c0000.blk, 6, 0 uclass_find_device_by_seq: 0 -1 uclass_find_device_by_seq: 0 0 - -1 -1 - -1 0 - found uclass_find_device_by_seq: 0 1 - -1 -1 - -1 0 - not found fdtdec_get_int_array: interrupts get_prop_check_min_len: interrupts Buswidth = 1, clock: 0 Buswidth = 1, clock: 400000 Sending CMD0 dwmci_send_cmd: Timeout on data busy dwmci_send_cmd: Timeout on data busy dwmci_send_cmd: Timeout on data busy dwmci_send_cmd: Timeout on data busy This reverts commit 6efeeea79c880d3dd262e0dca9da2687f0ab68c9. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-by: Simon Glass <sjg@chromium.org>
2016-07-31configs: rockchip: remove no use MACROKever Yang
The CONFIG_ROCKCHIP_COMMON and CONFIG_SPL_ROCKCHIP_COMMON are no use now, remove them. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: sdram: Fix register layout for LinuxJohn Keeping
The ChromeOS kernel reads the RAM settings from PMU_SYS_REG2 and expects the bootloader to store the necessary information there. We're using the same register to pass the same information between the SPL and U-Boot but in a slightly different format. Change this to use the format expected by the Linux DMC driver so that the system doesn't hang in Linux by misconfiguring the RAM. This is almost the same as commit b5788dc ("rockchip: rk3288: correct sdram setting") which was reverted in commit b525556 ("Revert "rockchip: rk3288: correct sdram setting"") but parenthese have been added to apply the mask correctly when reading the "bw" setting and a couple of minor style issues have been fixed to keep check_patch.pl happy. Signed-off-by: John Keeping <john@metanate.com> Reviewed-by: Tom Rini <trini@konsulko.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25ARM64: rockchip: add support for rk3399 SoC based evbKever Yang
RK3399 is a SoC from Rockchip with dual-core Cortex-A72 and quad-core Cortex-A53 CPU. It supports two USB3.0 type-C ports and two USB2.0 EHCI ports. Other interfaces are very much like RK3288, the DRAM are 32bit width address and support address from 0 to 4GB-128MB range. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: Use rockchip_get_clk() to obtain the SoC clockSimon Glass
The current code picks the first available clock. In U-Boot proper this is the oscillator device, not the SoC clock device. As a result the HDMI display does not work. Fix this by calling rockchip_get_clk() instead. Fixes: 135aa950 (clk: convert API to match reset/mailbox style) Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2016-07-25rockchip: Add a way to obtain the main clock deviceSimon Glass
On Rockchip SoCs we typically have a main clock device that uses the Soc clock driver. There is also a fixed clock for the oscillator. Add a function to obtain the core clock. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: rk3288: rename rkclk_configure_cpuHeiko Stübner
The function is very specific to the rk3288 in its arguments referencing the rk3288 cru and grf and every other rockchip soc has differing cru and grf registers. So make that function naming explicit. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25cosmetic: rockchip: sort socs according to numbersHeiko Stübner
Having some sort of ordering proofed helpful in a lot of other places already. So for a larger number of rockchip socs it might be helpful as well instead of an ever increasing unsorted list. Signed-off-by: Heiko Stuebner <heiko@sntech.de> Reviewed-by: Andreas Färber <afaerber@suse.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: rk3288: add fastboot supportXu Ziyuan
Enable fastboot feature on rk3288. This path doesn't support the fastboot flash function command entirely. We will hit "cannot find partition" assertion without specified partition environment. Define gpt partition layout in specified board such as firefly-rk3288, then enjoy it! Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: Exclude rk_timer for ARM64Andreas Färber
It conflicts with the generic_timer. Cc: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: Clean up CPU selectionAndreas Färber
In preparation for RK3368 and RK3399, which need to select ARM64, don't select CPU_V7 at the ARCH_ROCKCHIP level but at the SoC level instead. Cc: Kever Yang <kever.yang@rock-chips.com> Signed-off-by: Andreas Färber <afaerber@suse.de> Acked-by: Simon Glass <sjg@chromium.org>
2016-07-25board: move all the rockchip board in one folderKever Yang
The 'evb_rk3036' and 'kylin' is not a vendor name, let's replace them to 'rockchip' which is a real _vendor_ name, and meet the architecure 'board/<vendor>/<board-name>/'. More boards from rockchip like evb_rk3288, evb_rk3399 will comes later. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Eddie Cai <eddie.cai.kernel@gmail.com>
2016-07-25rockchip: add basic support for evb-rk3288 boardXu Ziyuan
evb-3288 board RK3288-based development board with 2 USB ports, HDMI, VGA, micro-SD card, audio, WiFi and Gigabit Ethernet. It also includes on-board 8G eMMC and 2GB of SDRAM. Expansion connector provide access to display pins, I2C, SPI, UART and GPIOs. This add some basic files required to allow the board to output serial messaged and can run command(mmc info etc). evb-rk3288 also supports booting from eMMC or SD card, the default is eMMC. Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-07-25rockchip: add option to change method of loading u-bootXu Ziyuan
If we would like to boot from SD card, we have to implement mmc driver in SPL stage, and get a slightly large SPL binary. Rockchip SoC's bootrom code has the ability to load spl and u-boot, then boot. If CONFIG_ROCKCHIP_SPL_BACK_TO_BROM is enabled, the spl will return to bootrom in board_init_f(), then bootrom loads u-boot binary. Loading sequence after rework: bootrom ==> spl ==> bootrom ==> u-boot Signed-off-by: Ziyuan Xu <xzy.xu@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org> Fixed up spelling of U-Boot, boorom, opinion->option, Rochchip: Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14rockchip: sdram: Update the driver to support of-platdataSimon Glass
Add support for of-platdata with rk3288 SDRAM initr. This requires decoding the of-platdata struct and setting up the device from that. Also the driver needs to be renamed to match the string that of-platdata will search for. The platform data is copied from the of-platdata structure to the one used by the driver. This allows the same code to be used with device tree and of-platdata. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14rockchip: sdram: Move all DT decoding to ofdata_to_platdata()Simon Glass
It is more correct to avoid touching the device tree in the probe() method. Update the driver to work this way. Note that only SPL needs to fiddle with the SDRAM registers, so decoding the platform data fully is not necessary in U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14rockchip: syscon: Update to work with of-platdataSimon Glass
The syscon devices all end up having diffent driver names with of-platdata, since the driver name comes from the first string in the compatible list. Add separate device declarations for each one, and add a bind method to set up driver_data correctly. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14rockchip: Don't use spl_boot_device() with of-platdataSimon Glass
This function cannot look at the device tree when of-platdata is used. Update the code to handle this. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-14rockchip: Move the MMC setup check earlierSimon Glass
When the boot ROM sets up MMC we don't need to do it again. Remove the MMC setup code entirely. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-07-11rockchip: Use 'select' instead of defaults in KconfigSimon Glass
Rockchip uses driver model for all subsystems. Specify this in the arm Kconfig rather than as defaults in the Rockchip Kconfig. This means that boards cannot turn these options off, which seems correct. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-06-26common: Pass the boot device into spl_boot_mode()Marek Vasut
The SPL code already knows which boot device it calls the spl_boot_mode() on, so pass that information into the function. This allows the code of spl_boot_mode() avoid invoking spl_boot_device() again, but it also lets board_boot_order() correctly alter the behavior of the boot process. The later one is important, since in certain cases, it is desired that spl_boot_device() return value be overriden using board_boot_order(). Signed-off-by: Marek Vasut <marex@denx.de> Cc: Andreas Bießmann <andreas.devel@googlemail.com> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@konsulko.com> Reviewed-by: Andreas Bießmann <andreas@biessmann.org> [add newly introduced zynq variant] Signed-aff-by: Andreas Bießmann <andreas@biessmann.org>
2016-06-19clk: convert API to match reset/mailbox styleStephen Warren
The following changes are made to the clock API: * The concept of "clocks" and "peripheral clocks" are unified; each clock provider now implements a single set of clocks. This provides a simpler conceptual interface to clients, and better aligns with device tree clock bindings. * Clocks are now identified with a single "struct clk", rather than requiring clients to store the clock provider device and clock identity values separately. For simple clock consumers, this isolates clients from internal details of the clock API. * clk.h is split so it only contains the client/consumer API, whereas clk-uclass.h contains the provider API. This aligns with the recently added reset and mailbox APIs. * clk_ops .of_xlate(), .request(), and .free() are added so providers can customize these operations if needed. This also aligns with the recently added reset and mailbox APIs. * clk_disable() is added. * All users of the current clock APIs are updated. * Sandbox clock tests are updated to exercise clock lookup via DT, and clock enable/disable. * rkclk_get_clk() is removed and replaced with standard APIs. Buildman shows no clock-related errors for any board for which buildman can download a toolchain. test/py passes for sandbox (which invokes the dm clk test amongst others). Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-27dm: rockchip: Enable CONFIG_BLKSimon Glass
Enable CONFIG_BLK to move to using driver model for block devices. This affects MMC booting in SPL, as well as MMC access in U-Boot proper. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-05-26Rename reset to sysresetStephen Warren
The current reset API implements a method to reset the entire system. In the near future, I'd like to introduce code that implements the device tree reset bindings; i.e. the equivalent of the Linux kernel's reset API. This controls resets to individual HW blocks or external chips with reset signals. It doesn't make sense to merge the two APIs into one since they have different semantic purposes. Resolve the naming conflict by renaming the existing reset API to sysreset instead, so the new reset API can be called just reset. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-05-02Revert "rockchip: rk3288: correct sdram setting"Vagrant Cascadian
This reverts commit b5788dc0dd9570e98552833767f4373db965985d. Ram size is incorrectly reported as 512MB on a firefly-rk3288 board with 2GB of ram. Reverting this patch displays the full amount of ram. Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-14dm: Use uclass_first_device_err() where it is usefulSimon Glass
Use this new function in places where it simplifies the code. Signed-off-by: Simon Glass <sjg@chromium.org>
2016-03-10rockchip: rk3288: correct sdram settingChris Zhong
The DMC driver in v3.14 kernel[0] get the ddr setting from PMU_SYS_REG2, and it expects uboot to store the value using a same protocol. But now the ddr setting value is different with DMC, so if you enable the DMC, system would crash in kernel. Correct the sdram setting here, according to the requirements of kernel. [0] https://chromium.googlesource.com/chromiumos/third_party/kernel/+/ chromeos-3.14/drivers/clk/rockchip/clk-rk3288-dmc.c Signed-off-by: Chris Zhong <zyw@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-03-10rockchip: make configure_emmc() empty for Firefly-RK3288FUKAUMI Naoki
on v2016.03-rc3, size of SPL image compiled by gcc 5.3.0 is too large for Firefly-RK3288. (it's fine for Rock2) $ gcc --version gcc (Ubuntu/Linaro 5.3.0-3ubuntu1~14.04) 5.3.0 20151204 Copyright (C) 2015 Free Software Foundation, Inc. This is free software; see the source for copying conditions. There is NO warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. $ ./tools/mkimage -n rk3288 -T rksd -d spl/u-boot-spl-dtb.bin u-boot-spl-dtb.img Warning: SPL image is too large (size 0x80d0) and will not boot to reduce size of SPL image, this patch makes configure_emmc() empty for Firefly-RK3288 as same as Rock2. Signed-off-by: FUKAUMI Naoki <naobsd@gmail.com> Acked-by: Simon Glass <sjg@chromium.org> Tested-By: Vagrant Cascadian <vagrant@debian.org>
2016-03-10rockchip: rk3036: change ddr frequency to 400MLin Huang
emac may use dpll as clock parent, and it request the clock frequency multiples of 50, so change ddr frequency to 400M. Signed-off-by: Lin Huang <hl@rock-chips.com> Signed-off-by: Jeffy Chen <jeffy.chen@rock-chips.com> Acked-by: Simon Glass <sjg@chromium.org>
2016-01-21rockchip: Add support for Raxda Rock 2Simon Glass
This board includes an RK3288 SoC on a SOM. It can be mounted on a base-board which provides a wide range of peripherals. So far this is verified to boot to a prompt from a microSD card. The serial console works as well as HDMI. Thanks to Tom Cubie for sending me a board. Signed-off-by: Simon Glass <sjg@chromium.org>
