path: root/arch/arm/mach-rmobile
2016-08-17ARM: rmobile: r8a7795: Add MMU layoutNobuhiro Iwamatsu
This add MMU layout for R8A7795 of Renesas ARM64 SoC. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17arm: rmobile: Add BLANCHE board supportmasakazu.mochizuki.wd@hitachi.com
BLANCHE is development board based on R-Car V2H SoC (R8A7792) This commit supports the following periherals: - SCIF, Ethernet, QSPI, MMC Signed-off-by: Masakazu Mochizuki <masakazu.mochizuki.wd@hitachi.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support salvator-x boardNobuhiro Iwamatsu
Salvator-x is an entry level development board based on R-Car H3 SoC (R8A7795). This commit supports SCIF only. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support R8A7795Nobuhiro Iwamatsu
Renesas R8A7795 is CPU with Cortex-a57. This supports the basic register definition and GPIO and framework of PFC. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Add support R-Car Generation 3Nobuhiro Iwamatsu
This adds supporting R-Car Generation 3 (Gen3) as Renesas ARM64 SoC. Signed-off-by: Hiroyuki Yokoyama <hiroyuki.yokoyama.vx@renesas.com> Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Create R-Car 32bit (Gen1 and Gen2) for KconfigNobuhiro Iwamatsu
This creates Kconfig of R-Car 32bit for Kconfig of R-Car 64bit (Gen3). Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: Rmobile: Rename CONFIG_RMOBILE to CONFIG_ARCH_RMOBILENobuhiro Iwamatsu
2016-08-17ARM: rmobile: Move SoC headers to mach-rmobile/include/machNobuhiro Iwamatsu
Move form arch/arm/include/asm/arch-rmobile/ to arch/arm/mach-rmobile/include/mach/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
2016-08-17ARM: rmobile: Move SoC sources to mach-rmobileNobuhiro Iwamatsu
Move from arch/arm/cpu/armv7/rmobile/ to arch/arm/mach-rmobile/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
