At this point, the remaining places where we have a symbol that is
defined as CONFIG_... are in fairly odd locations. While as much dead
code has been removed as possible, some of these locations are simply
less obvious at first. In other cases, this code is used, but was
defined in such a way as to have been missed by earlier checks. Perform
a rename of all such remaining symbols to be CFG_... rather than
CONFIG_...
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Move form arch/arm/include/asm/arch-rmobile/ to arch/arm/mach-rmobile/include/mach/.
