path: root/arch/arm/mach-rmobile/include/mach/r8a7791.h
2016-08-17ARM: rmobile: Move SoC headers to mach-rmobile/include/machNobuhiro Iwamatsu
Move form arch/arm/include/asm/arch-rmobile/ to arch/arm/mach-rmobile/include/mach/. Signed-off-by: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
